Leaderboard
Popular Content
Showing content with the highest reputation since 12/10/04 in Posts
Don't tell my wife Like I tell other people. some like to fish, some like to bowl, I like to make.5 points
He's saying although we are launching a DOHC head in 2024 we readily admit it will be pale in comparison the mighty KN20 from Datsunworks. At least that's what I'm hearing.4 points
4 points
**UPDATE Went to court yesterday and basically played dumb. Told the judge that "I went to the state ref and he told me since the car is so old that he couldn't do anything to certify it. So how do I go about taking car of this ticket. The vehicle is a pre smog vehicle so I've never had to SMOG it" The judge said "Ok so what Im going to do here is dismiss the case cuz it seems like your car doesn't qualify for an inspection. Sorry about the inconvenience Mr. Soto" I tried to play it cool but I was so happy. After reading all the horror stories from other people about having to revert to stock and all that I was lucky I guess Hope this thread helps someone going through something similar4 points
Greetings Everyone, Due to the increase in spammers HybridZ, registration has changed from being automatic to manual. That means one of the Admins will need to approve any new registrants. If you ask or tell someone about HybridZ (please do) let them know registration isn't automatic anymore. We'll do our best to stay on top of any additions and hopefully you all will see a lot less spam. Thanks, The HybridZ moderation team4 points
Unfortunately, it is too late. Maybe for round 6 in a couple of years Got the shirts in and will start breaking things down and shipping things out next week. This week is busy with work travel, so appreciate your patience while I get a few out each day on my lunch breaks.3 points
They received all of the shirts without backorders and are starting on printing this afternoon!3 points
I really wish things would swing back towards the forums. I can't tell you how many times I know the answer to or could add to a post on FB but I don't since it really has no longevity. I always felt like I was adding to the overall knowledge base when I posted here. I can go on and on but I really hate it.3 points
First start up since starting the restoration. Kind of shocked she started right up on the first go. Was expecting something on the MegaJolt to need fixing, but it worked great. Went with Magnacor wires, but they made a mistake and did not fit them up with the right coil boots. Being remade and shipped, so I am using 05’ ford explorer NGK wires for now. Went with a “7” heat NGK plug on account of the 10:1 CR. It’s raining this weekend, but just need to dial-in some crude alignment and she will be road worthy IMG_2339.mov3 points
Just wanted to say again a HUGE "Thank You" to @cockerstar for doing this (a FIFTH time)!!!! Really appreciate all his time and effort to make this happen. You da' man, Ryan!!! 👍👍3 points
3 points
I want to thank all of you here for giving me inspiration for my build. I have adopted the Hybrid Z name for my build years ago since this site provided a lot of information that I consider priceless. I was able to meet some great people at ZCON, some that know my build and others that just wanted to say hello and compliment me on my build. When I built this car I built it as my version of what a Z should be therefore I know a lot of people were not going to like it since it was my vision and nothing else. Taking my car to ZCON for the 1st time and walking out of there with these awards it’s just incredible, especially with all the awesome cars I was competing against. It’s great to see the judges appreciate all the hard work and effort that has gone into it. These are the awards I received. 1st Place in Ultra Modified Best Engine Gold Cup- This was totally unexpected and shocking it was given to a Z with and LS3 since most of these guys are Nissan purists. Again, thank you all for your support and keeping this site alive.3 points
It's not the votage drop that matters it's what the voltage drop indicates. No spark will be created if the current through the coil is not stopped. You could also disconnect the coil negative at the coil and check the wire for continuity to ground, key off. Disconnect the wire, put one meter probe on the end and the other probe on a good bare piece of metal or the engine block. You should get OL or infinite/huge ohms on your meter.2 points
well yes , stock guides , just to make lower axes in the block, and the stock cover is modified to make some space, electric water pump ( davis Craig ) , and tensioner on the right side, in place of the water inlet ( spring and lock without oil pressure ) no need for oil pump drive or distributor for i put dry sump pump system and megasquirt ignition and injection EFI with yamaha bike itb's So simple and cheap , just a little of brain storming ! oh ! and a little joke for the head cover !! Lol !2 points
There is no swap hardware to put the Z transmission behind a V8. It wouldn't handle the torque anyway. The 260Z engine is about 158 cubic inches, compared to 350 for a SBC. The old Z transmission bearings are typically ready to fall apart besides that, not uncommon even with the stock engines. It would probably last about one pull. I haven't done it myself, but I wouldn't even try it just based on what I've learned.2 points
Yes, with the carbs you can get rid of the ECU and EFI parts. The complete EFI harness can be removed. The guys that know on the site (from the past) say that the exhaust system is restrictive and opening it up helps a lot (see John C posts from the past) , and that if you decide to use a performance cam go big (see JMortensen posts from the past). The typical "Stage" 1 or 2 cams don't add much, apparently. So, the simple and effective way to add some power is with a better exhaust system and a big cam. Cams are more expensive than they seem because you need to buy lash pads and rocker arms along with the cam. The collection of parts costs can add up. But it's a pretty simple operation to get it done. Many people like the lighter flywheel. It takes more finesse on the clutch pedal but they say it's worth it. Fidanza is a good choice. For street driving an LSD doesn't add much. You might wait on it and see if you have traction problems. There is a ton on the site from the old-timers, around the 2000 to 2015 time range. Things have slowed a lot on the site as people have moved on. But their contributions are still here. Many of the guys were racers and/or engineers/mechanics/machinists and spent a lot of time and money on their projects. Today's car hobbyists really only know turbos and EFI since that's what they were raised on. Good luck.2 points
Even if 100 people commited to purchase, its still tiny small numbers vs an OEM production. Its got to be done out of passion and at least not to lose money. This is why this is such a huge acomplisment for someone like Derek, We are fortunate the passion runs deep. I cant imagine the hours of "un-billed" time2 points
2 points
Well, after more testing, it seems to be a user error. Was able to drive for a good hour today without and bucking/shudders. I think it's a combination of a new clutch and upgraded transmission/rear end that I have to get used to. The car seems to like higher rpms when starting from a stop, and a different clutch engagement that what it was before. Car is much more fun with the new parts. Not a fast car, but a fun one.2 points
No, you just pull the bearings off of the front of their shafts. The countershaft bearing is pretty tight to the gear and takes some trickery. The mainshaft bearing needs a puller with long arms. You can push the rods back to get more room. The transmission will have multiple gears engaged but it won't matter. When you reinstall the front case put it in a single gear (one rod moved) to avoid locking up the transmission by accident. Here's a decent video about the countershaft bearing, different tranmsision but same concepts. He did the same thing I did, clamping a two jaw puller in to the gap, otherwise the jaws pop off. The mainshaft is a more normal operation but the length of the shaft has to be managed. It takes some work. If you have friends that have pulled bearings or gears it might be worhtwhile to get some more ideas and tools on-hand. Notice the odd combination. Go to 4:00 if it doesn't start there.2 points
4th gear doesn't use the countershaft, it's direct drive. That's a good clue. Sounds more like the countershaft bearing. Looks like you'll need to split the cases, so you might as well do the mainshaft/input shaft bearing also. It's not a super-finesse job. Just needs some ingenuity. It's fun. Part of Z ownership. Here's a good illustration of the parts you'll be looking at. I'm sure that there are "how-to" videos out there somewhere. You can get a factory service manual on the internet that shows how to take it apart. Good luck. https://www.zhome.com/ZCMnL/tech/240SX5spd/Transmission2.htm2 points
"Grinding" is not very specific. Can you add details? Have you driven it? Is it the same in every gear? 71B's are known for destroying the adapter plate bearings. Did you find any metal on the drain plug magnet? If you've been driving it you might drain the fluid and see how it looks. Might also be worthwhile to lift the car and get underneath with the engine running to see if you can locate the noise. Replacing the main and countershaft bearings is not very difficult. You only have to split the cases and pull the bearings off of the ends of the shafts. The adapter plate bearings are more difficult.2 points
Order is with the screen printer and will keep you guys posted when I get an ETA on delivery.2 points
Finally got this thing tuned right, kept fighting an issue where the car would break up on quick throttle changes and in boost. Engine had NGK b6es-11 plugs, I went to a NGK bpr7es and all my problems disappeared. Engine is leaking oil pretty bad though from what looks like where the timing cover and cylinder head meet, l am genuinely amazed at how much oil can come out of there. The stock head gasket was torn there, and I RTVed it up a lot after the fact. Maybe my PCV valve is faulty and pressurizing that area under boost? Once I get this oil leak handled Ill take it to the dyno.2 points
@calZ, I spoke with John yesterday and I'm going to do another round. 36 item minimum from my print shop, but I think we can hit that!2 points
I am still around, I don't check regularly. I still have my Z. I joined here when I was 15, I am about to turn 38.2 points
Hi All It has been a while and I have been racing e36's, TA2's V8's hard. But that Datsun bug bit me again, (It helps to have one sitting in your barn the last 11 years!!!!) Over that time there have been periods I have done several things to it, but campaigning the other cars always meant to revivals short lived. However selling after selling the Sprint race car and just having an endurance car it started to itch. And to be fair I first went on racecarsdirect before I figured that was a stupid waste of money and knowledge. So without too much fuzz... She is back. Here is a link to the original thread: I think it is a blessing in disguise that I haven’t finished it sooner, racing from 10 years means you learn allot on what is smart and what is not. And over the years allot of 'spares' have found their way to the chassis, like a Tilton pedal box, fuel cell etc etc And times change so supplies do to, there a solution for the rear control arms by these guys https://www.apexengineered.com/ So ill put in my order for a front and rear subframe for the car. Here are some pictures of the body as it sits now: First it has been blasted Then powder coated Saturday ill start with mounting some small stuff like the pedal box. For an engine it will run an L28 with forged internals, kameari chain drive, isky cam, worked head, race oil pan and probably ITBS over the set of Dellortos i still have. I might go dry sump but that has pros and cons, the con is it ads weight.2 points
2 points
I welded 4x 1.75" wide 0.06" thick strips from the roll hoop to the body, two on the sides right below the window frame and two to the roof support .75" outboard of the dimple die holes. I cannot believe how much quieter the car is and how much better it handles bumps, hard accelerations, sharp turns, etc. Its really incredible, wish I'd done this a year ago.2 points
There was some conversation in other topic about blade type rollbar. So, i have one like this. 32x3mm cro-mo tube and 260mm blades. Blades are 35 to 25mm wide and 6mm thick, steel of course. Bar itself is more just a link between blades. This type rollbar works mainly with blades, i.e tube is stiff and blades are flexing (if they do) It depends how they are adjusted. If blade is vertical, it´s very stiff, horizontally they are pretty flexible. Any position between those, are something between, ofc. To adjust, just loose bolt (most left head of blade) and tur to desired position. Or attach cable and make remote control.2 points
For this build I decided to jump in with both feet and learn how to build fiberglass. I found out early on that I would need to build up a custom air dam so I decided to build out a door as a trial to learn the process. I have done plenty of small FG projects but never something large that involves building a mold tool. You can see the process in the pictures. First sanding and waxing the door (plug) and applying mold release. Then a layer of gelcoat and then laying down multiple layers of heavy matt until the mold has enough strength and rigidity not to break when pulling the final part. The only mistake I made was not smoothing out the original door. I thought it looked fairly straight but it turned out to have some waves in it. It also had some small flaws I thought would be easy to correct in the mold. I was dead wrong. It would have been much easier to correct the flaws on the original door than to work on the mold. You can see the final surface on the mold. Then I prepped the mold, laid in some layers and a new door popped out. It's hard to tell in the pictures but the surface finish turned out great. I added some cardboard rolls in the back to make it stiff. It is attached to the car with push button locks and pins on the bottom. For the final touch I 3d printed a door handle.2 points
thanks! Gosh I’m not sure how to adjust the res of the photo’s uploaded here. I can try e-mailing them to myself and uploaded from a computer instead of from my phone. The pictures themselves are huge files on the iPhone. Here is a vid I posted on IG today. Got my rear suspension in thanks to the helpful folks here at HybridZ @JMortensen, @jhm, @Ben280 And more IMG_5985.MP42 points
It would be helpful certainly, but I think in general, Apex and Techno (to name a few) aren't making parts which require that level of explanation. Quick steer knuckles, adjustable sway bars and RCA blocks are about as intense as anyone has gone until Apex started doing their subframes, allowing for roll center adjustment. Otherwise, listing a spec as "Up to 4* more camber over stock" or "3" wider front track than stock" or "Stronger!" are just, to my mind, stating the obvious. As a counterpoint, GKTech who makes a huge variety of drop knuckles and extremely modified components does a fabulous job detailing their R&D and decision making: https://blog.gktech.com/blog/gktech-rear-suspension-uprights/ I think if companies for the Z were making parts like this, it would make sense to detail choices.2 points
So I made a laser alignment tool based on a few Ideas I gleaned from the forum. I made a slip collar that fits over the CD009 output shaft that holds a 45ACP laser bore setter. I'm using this for the horizontal alignment. Works well. I made a target that has a couple of alignment lines. The bottom is parallel/perpendicular to those lines so you can use a level to get it plumb. I then proceeded to drill so many holes in it that it's almost useless:) The key word here is almost. That was a far over to centerline as I could get it. I need to rework either the Diff mount or the trans mount to get it any further but it's only about a half a degree so I may live with it. I'm running the Technoversions RT mount and I switched to the top mount instead of the stock bottom. This brought the pinion angle down to 2.8 degrees. The transmission is at 2.9 degrees so I'm pretty satisfied. Hard to tell if it made much of a difference but the math says it should.2 points
The plan was to do some track days this year, so I needed some brake ducts and an oil cooler. I sold/bartered a set of series 1 scooped backing plates I had for a set of normal ones. No need to cut up the rare stuff. Took the new backing plates, cut them to 8" diameter, took a 3" exhaust collector and modded it to fit the cut down backing plate. Welded, drilled holes in the duct hole and then used cut off wheel and die grinder to open the hole in the backing plate up. Also took a section of the rim of the stock backing plate and welded it on for stiffness and to close the gap between the backing plate and the rotor vents. Doesn't look all that wonderful but I think it's going to work well. 1 down, 1 to go, then can modify my front end for the scoops and hook up the tubing.2 points
2 points
Hey Guys, I have been trying to figure out what I wanted to do for color uniformity on my datsun. I really wanted to get the car sand blasted and do a complete overhaul, but after swapping a l28et in the car, building and installing the megasquirt, and all the other tid bits... I was way over budget to say the least. To be cost effective I decided to do a vinyl wrap. 3m vinyl to do the whole car was only 500 bucks! The car itself was in no shape for vinyl. It had chips, dings, rust, you name it. I had to do all the body work to straighten it out. Here is some before pictures. The paint had to be sanded or removed to metal and bondo was applied. First time ever really doing body work and it looked OKAY. I did have a professional come and do the final things to the driver's side fender and door. Lots of chipping paint that needed to be sanded. After things were sanded and looked pretty good, spray can primer was sprayed on the trouble spots, then sanded, then black rustoleum, then sanded. Finally I wet sanded the car with 1000 grit and made sure all surfaces were smooth. Then the fun began. Vinyl took around 20 hours to finish in a weekend. This did not include the headlight buckets, turn signals, or cowling which I am still trying to figure out. The car being unibody caused issue. The rear bumper section is 1 piece which is then overlapped 1 inch by the quarter panel which is then overlapped by the roof. Knifeless tape was key to get smooth lines. The hood is harder then it looks because of the round center bubble. Really have to stretch and pull to get in on right. Also getting the vinyl to stick properly on the back required cleaning all edges and even applying loctite super glue.... I know not the right way, could use primer 94, but actually works! Just don't get that near any exterior surfaces or you will leave marks on the laid vinyl. Fenders are one of the easiest. Tucking around the wheel arch was a little tough. Make sure to clean these back areas so that no dirt is in between were you want the vinyl to stick on the inside. This is were I started to notice that my rusto paint would start to peel if we kept taking off and re-applying the vinyl. There are spots were you can see this for sure, but oh well.... it cost 500 dollars. Also you would get specs of shit for the same reason, small pieces of paint peeling up. Moral of the story. Only works on really good paint or paint that is strong against the body. Should have spent more time in that regard. Rear bumper area was pretty easy just a flat piece. The quarter panels were the most difficult. Trying to get around the rain gutter was a challenge. We accidentally cut the vinyl and had to pivot to a new plan regarding the roof. Paint was peeling up if we removed it so we went with what we got. If we were to peel it off... I would have to sand the whole quarter panel over again. Made it work, just needed to add an intermittent piece between the quarter panel and roof. Getting around the back taillight area was a little hard as you really need to stretch it. I assumed the inner edge would mostly be hidden by the taillight panel, but more is exposed then I thought. Might try to adjust this better. Roof and hatch were also pretty difficult. If you have old shitty gaskets around the glass. CHANGE THEM. Tucking underneath that shit would have been way harder than it already was. I got new rubber were needed and it was way worth it. If you mess up on a part like that... there goes 70 bucks in vinyl to redo it. Tucking worked best with knifeless tape in my opinion. Don't forget the sides of the windshield... I used a small inlay for that. Also the bottom area below the door is an inlay. Here is the vinyl result.... get it... vinyl result Might keep the windshield wiper area black... its scary when you see all the spots were it needs to be cut! Here is a picture of how we did the inlays from quarter panel to roof. It turned out pretty damn good if I say so myself. I have learned a lot about this process as I went because there is not too much info about unibody cars. I would say that this is a pretty difficult job and very tedious. Details are important, missing a cut or making a mistake can make it look bad. We had mistakes, bumps, paint chips you name it, but the point of this was to get the car looking good for a couple years for cheap until I am ready to get the car painted. What I would suggest if you want to do this... - Make everything really smooth. - If painting, take your time and get it to stick well. Paint peeling and sticking to the vinyl was the biggest issue I experienced. - Have a friend. My dad worked the whole time with me.... I can't thank him enough. I did a trial hood before all this on my own and it took 2 times as long and looked way worse. - Plan out all the cuts before you apply. Thought I would share my experience. If you have any questions about it let me know. I hope to reassemble the car in the next 2 weeks.2 points
an LS is also vastly more expensive then a traditional 350 swap. He should do whatever he wants to do.2 points
Semantics is a big deal on this forum. It is one way that separates us from other forums. Making sure an item is called the correct name that people recognize will go a long way. If you want I can edit the title of your post which directly asks for a workaround to the combo switch. Semantically it seems to be called a multi-function relay. The relays themselves seem to last quite a while, I'm still using several stock ones in my 71 that was in use till 2010. I would suspect as miles pointed out it may be the switch contacts on the stalk going out. The hazard lights switch has its own set of wiring so it may be acting as a red herring if you are using that as the reasoning in your train of thought. I suggest taking a breath, people are here to help of their own accord, it may be frustrating to seemingly answer the same question or when someone is caught on a seemingly unrelated point, but realize we need clarity to try and help. It may serve to help their train of thought, and it may seem tedious, but given the free help, maybe try being accommodating? It may serve better to have a post where you clarify exactly what you are looking for that you or others can refer to someone asking a question in the post. I can't answer as I've only looked at the early Z wiring in detail, but it seems odd for the blinker wiring to go through the floor so I can identify with others as to the confusion. I'm finding a note that the part number was used for a fuel pump relay, might be something else to check. I do know the pins are a standard spade connector so you could wire in a modern relay if you can pin out the contacts and make little adapter lengths, I've done that for some older plugs before. Identify power, ground, switch ground, switch power, and output. Then you can use any modern automotive relay.2 points
katman? Where the hell has he been for the last 10+ years? Oh, that's me, back from the dead. That thread may have been on improvedtouring.com. Assuming your friend also has to run the stock drum brakes, here's how we made brakes last in an ITS car, which at the end of its development was probably as fast as any CP vintage car. I don't know what compound Carbotech has today, but back then the HT-9 was the only thing that would hold up to the heat on the front. The HT-10's that replaced them were not as good, but that was about the time that SCCA pissed me off by outlawing remote reservoir shocks so I quit thinking about Z brakes. I ran both the Nismo rear shoe, and the relined Carbotech shoe, I think. We cryo treated rotors and drums. We ran the parking brake so we could adjust the rears during the course of a race. That and having an adjustable prop valve so you can make the rears take their share of the load is critical. If you aren't turning the friction surface of the drums blue, then you ain't there yet. Scour the junk yards and find every Z drum you can find and have them turned and expect to rotate in a new set every weekend. Up front, don't fall into the trap of using a pad that maximizes the pad material, in other words instead of this | | , you want this \ /. The outer radius of the rotor runs hotter because its going faster (linearly) and wears the pad faster. Nothing worse than having to pump the brakes every corner to take up the slop from tapered front pads, maladjusted rear shoes, and expanded rear drums. We drilled holes in the backing plate on the rears for some cooling, but not much else you can do back there. Up front we ran three 3" ducts on each side, one to the hub area of the strut to cool the bearings, one to a custom "can" that blew air on either side of the rotor, and one that blew into the caliper overtop of the pads. That one was tricky to make as there isn't a lot of clearance between the caliper and a 14" wheel that we had to run. I also drilled a series of small holes around the periphery of the pistons just behind where they contact the back of the pads so air could circulate behind the pads from the aforementioned duct over the pads. PM me and I'll send you some pictures.2 points
It's a spacer for the flex plate. You need to remove it anyway to mount your flywheel. Pretty sure it just pries off easily. Then the seal will be exposed.2 points
I noticed some traffic on my web site from HybridZ and was pleasantly surprised to see a thread opened on the CV axles. Thanks John! Mods, I'm new to this 'vendor' role, please let me know if I'm breaking procedures etc... I'll keep this theme to simply answering some of the questions raised above. Please don't hesitate to add questions and I'll continue to answer as best as I can - w/o giving up too much R&D. "...he seems to be quite a regular in the "Dime" community" - that I am. For the past 7 years I've been a proud owner of a 1972 Datsun 510 2 door, orange. I also own a 1976 280z that currently being built up into another fun toy and R&D test bed for future products. Much of my involvement on 'The Realm' has been sharing in my experimentation (Yamaha R1 carbs on a KA24e and MegaJolt EDIS ignition etc...) and learnings. "..I wonder if he is just cutting flanges off old u-joint axles and welding them on to "CV" axles..." - nope. I manufacture brand new adapters/flanges, accurate up to 4 thousands of an inch on centering/mounting to make them dead smooth. The flange's bolt-hole placement is left to CNC machining for repeatable accuracy. "...Not sure that they're much better than a u-joint axle though. What's the benefit?" - Several benefits: As the U-joints in our axles fail, finding replacements has been difficult, at least for me. Also, with lowered Datsuns, the larger angles within the axle exaggerates a U joint's inability to rotate at a constant speed. These newer CV axles (short for Constant Velocity), can rotate at more consistent speeds with larger angles. The end result is a noticeably smoother ride - even for Datsuns with seemingly fine stock axles. Another reputed benefit is more drivetrain efficiency and a couple percent increase power to the wheels. "I wonder where the came up with the torque limit. Breaking welds? " : A LOT of engineering went into these CVs - down to shear calculations, metals selected for the adapters and how it interfaces with the CV, impacts from tempering, redundancy in fastening etc... Calculations showed that the fastening/welding technique is ~20-30% higher than the stubs at their weakest point. Back to the question, the torque limit was placed because that's the approximate OEM limit that the axle is designed for, and I wanted to limit anyone trying these axles on over the top machines. As previously posted the axles are comparable to the Subaru STI which are quite capable. My guess on the weakest link now lies in either the axle splines or the shoulder/D bolts themselves. " Being that the stub axle is such a weak spot..." - I'm not sure where on the stub you are referring to but I do offer an integrated stub CV where an OEM STI stub is directly fastened onto the CV housing - in 3 different manners (it's NOT coming off!). It's really slick with only 4 bolts to fasten the axle onto a clip-in diff setup. A similar R200 version is in the plans for this spring as well. I hope that answers the questions. My CV axles are designed to fill a niche market and not directly compete with existing products/vendors. There are already several options for owners with massive HP and/or heavy track duty needs. My CVs, and frankly the basis of all my future products, are intended to be an affordable & original solution that offers a level of reliability (read: lack of maintenance) you expect from a street car, be it stock or with a moderate swap/upgrade powerplant.2 points
2 points
2 points
Quite a few things wrong with that Tune. No wonder you are having issues with AE. Made some revisions to. 1: AE settings. No where near correct. Made several changes there that should be positive. 2: Target AFR table far too lean at low RPM. VE table greatly affects transition off idle. Going too lean creates a bog. With proper Ve Table, less AE is required. 3: You were running Alpha N. MS3 has a special Fuel algorithm for ITB's. I have enabled that. 4: Spark Table needed some work 5: I've noticed that you have your O2 feedback control disabled. I have enabled it but set proper settings and filters on it. Send me a PM with your E-mail address and I will send you a touched up Tune. This is just a Baseline . but should be an improvement. I also do Remote Tuning and offer full Tunes built for your particular engine specs.2 points
I know everyone knows this already but 250hp/300ft-lbs is handled easily by the stock R200 long nose. Until the 8.8 became the hottest topic, the long nose R200 was considered just fine for all mild V8 swaps and some fairly upgraded ones too. Drag racers have run the R200 well into the 11s without issue (other than the lack of LSD options/ratios).2 points
Machine work finished! I can relax a little:) Just got done with their first bath. Still need de-buring and edge finishing but the majority of the work is done. The VCT holes are drilled and tapped but they haven’t been drilled all the way through. Easily opened up with a drill if needed. The head has provisions for three sub plates. Timing chain idler, upper tensioner and a slack side guide pivot. The idler and tensioner are connected to the oil system and o-ringed. It is getting really crowded in there with all the oil passages, head bolts and cam tower bolts. Next stop vacuum resin impregnation.2 points
With all do respect newzed you have contrbuted nothing new to the solution of the problem that I had not already addressed many weeks back with DSS. I may not be using terms that agree with you.... I said “bind and won’t turn” and you prefer “won’t spin”. Your suggestion of filing off a dust cap is impossible as we are talking about solid billet machined parts that are meant to be to spec. You just can’t take a file to this stuff and call it good and I don’t own a lathe. I purchased these parts at great cost per DSS selling them as bolt on and in regularly use on many S30 Z’s. They have since admitted that they have NEVER had this stub axle on 240Z and admitted that there stub axle was previously copied off of an unknown Datsun stub axle they were told was an S30. I have supplied them all of the measurements using my mics and calipers for the risers so the bearing would fit per spec. Unfortunately, the first riser was not machined to measurements I provided so they did them a second time, this time per my measurements and they are perfect. Great, however the billet machined shoulder then cam into contact with the housing and again would not spin. Soooooo I sent them a stock 240Z OEM stub axle along with their axles with the understanding that DSS would machine into the billet stub axle the proper recess and width allowing the stub axle to fit as OEM with the stock stamped dust cap. DSS sent the axles back to me with shoulder machined down but without the necessary recess. I called them concerned they still would not fit however, per their instructions, bolted them back up as they were “within .005 tolerance of OEM”. I bolted them back up and they continue to press against the housing and will not spin. I called DSS with the bad news and they said “sorry, we didn’t think the recess was that important”. My response was “why didn’t you just machine the axle to match the OEM one I sent”? There Response- “Im not sure i need to talk to the machine shop”. As of this afternoon, DSS has requested I send it all back one more time and they will make it right. I’m going to give them that opportunity again as I am to far into this to just turn back. So, after month of emails, pictures, and sourcing hardware to fit (since the supplied hardware hits the differential on the adapter side of this conversion) I am again hoping that DSS machines these stub axles to OEM spec. Keep in mind, this is advertised as a “bolt in no modification kit”. Im really not offended that I’m not making sense to you. I’m offended and ticked off that I was sold a product that has never actually been bolted on to a 240Z and that I have been patiently (admittedly sometimes not so) trying to help them produce a useable product from the other side of the U.S with phone calls emails and pictures. The final straw is sending them an OEM axle with the instructions “make a copy of this” and it still came back machined wrong. Every point you have made regarding bearings and risers and clearance I agree with fully and in fact I communicated to them to fix those issues as they arose. It’s been a long process. I’m sorry I can’t satisfy your deepest need for every piece of communication and I honestly can’t tell you why they keep getting it wrong. Funny thing is, they can’t explain it either, but they sure as heck are not blaming me. Lee thanked me for my patience with all of DSS mistakes. Getting into a war of words is not my bag. I’m bummed out this crap is clogging up the forum. I apologize if I offended you. I’m really just a hard working guy that loves Z’s and gearhead culture in general. I’ve been building and racing for most of my 50 years of life (first kart and motorcycle age 5) and building cars in my garage is my therapy..... supposed to be fun. Given all my frustration with this purchase, i just needed a place to vent and I really want others to avoid the same. So hearing that I’m a whining complainer that doesn’t know what the hell he is saying and is incompetent to turn a wrench hits where it hurts to be perfectly honest. Agree to disagree is cool with me, time to let this squabble go. With respect, Jim2 points
2 points
