jessejames
Members-
Days Won
4
Content Type
Profiles
Blogs
Store
Everything posted by jessejames
Trying to mount engine and transmission. Using the apex engineered for the transmission mount. The dry sump pump is making contact with the cross member. The transmission is alittle lower than I like.
Not a alot of progress. Dry sump kit is missing pulley. Hopefully will here back from the vendor soon. Some pictures of assembled motor to make motor mounts.
Nothing to exciting to report. I've attached a picture of the new turbo, intake manifold and brake kit. The picture with the sr20det is how it sits. That motor should be out by the end of the weekend.
Hello, so I'm starting a new project. I'm pulling the Sr20det out and swapping in a Honda K24A2 turbo engine into my 1973 240Z. This is a list of the basics: 2006-2008 Honda k24a2 2.4L vtec Cd009 Nissan 370z transmission Efr8474 twinscroll turbo Haltech elite 1500 Ecu. This is my first attempt to do a build log.
Im always here, lurking and reading. I just don't post very often. I often reference the site.
https://bringatrailer.com/listing/1971-datsun-240z-124/ Sold for $310,000!!!
I just installed Sparco QRT-R's with planted seat brackets. The wings are a little to wide and need to be trimmed to fit in the seat. I used sparco side mount brackets with the planted seat bracket. I tried using Sparco sliders, however the seat sat too high for me and would not allow me to use a helmet. The seats are very comfortable for me. I'm 5'11 and 170lbs. They are snug around my waist. Unfortunately the logo doesn't match on my two seats. I'll be dealing with that later this week.
Underwhelming Lap Times
jessejames replied to Twisted46's topic in Brakes, Wheels, Suspension and Chassis
Too many variables to know for sure. Some questions though: 1) Is mid Ohio a high speed track ? if so, your aerodynamics might not be as good as your Subaru. 2) I didn't see anything about your brakes. Maybe you were able to brake later with the Subi? 3) Sliding is not the fastest way around a track. Theres lots of info on the site about setting up alignment specs. I know when I was at the track, my lap times got faster, the slower i entered a corner. I'm no track expert, so take my advice with a grain of salt. -
DZ-Start Push button Ignition Kits F/S again
jessejames replied to HLS30-08077's topic in Vendor's Forum
Yeah both leads are dead ends. Anyone know how to make one of these kits?- 26 replies
- DZ-Start
- Push button
(and 1 more)
Tagged with:
Are these still available. I would love to buy one with rfid.- 26 replies
- DZ-Start
- Push button
(and 1 more)
Tagged with:
I might have a spare Sr20 harness.
I just purchased these from SKILLARD. com I'll post a review once I have it installed. https://skillard.com/products/240z-260z-280z-camber-plate-covers
problem Whining on acceleration
jessejames replied to youztheclue's topic in S30 Series - 240z, 260z, 280z
my car makes a similar noise. I believe its the diff. I've changed the fluid, it made no difference.- 6 replies
- 260z
- transmission
(and 1 more)
Tagged with:
T3 and arizona z brake kit
jessejames replied to jessejames's topic in Brakes, Wheels, Suspension and Chassis
Have you had any issues with them, since they dont have dust seals? -
I'm going to be upgrading my brakes soon. I'm leaning toward getting the t3 front and rear kit. Part of me was thinking about getting the arizona z front kit and using it with the t3 rears. I like that the Arizona z kit is a slightly larger rotor. Does anyone know if they use the same calipers? Is anyone running the arizona z front and t3 rear?
My 1973 240z was parked in the rain for a few hours. When i moved it inside I noticed the right side of the drivers side footwell was soaked. The windows were closed. I cant tell where the water came from. The cowl drain appears unkinked and dry. The area near the door was dry. The area under the dash was dry. There was some moisture at the base of the windshield but no where near the quantity of the water on the floor. Is there a common area for water to leak in from? Thank you.
I cant wait for more pictures! Looks great so far
T3/T4 Turbo that spools like stock?
jessejames replied to AlbatrossCafe's topic in Turbo / Supercharger
I'd recommend the efr6258 for your power goals. I use it on my sr20. Spools fast, and you'll hit your power goal easily. -
What spring rates is everyone running?
jessejames replied to CruxGNZ's topic in Brakes, Wheels, Suspension and Chassis
I'm running 375lbs front. 325lbs rear. I have the St away bars as well. -
What about EFR 7064? Its one sale...
jessejames replied to turbogrill's topic in Turbo / Supercharger
I'm running the efr 6258 on an SR20DET. I'm using an ebay manifold. I made 289 whp on a low reading mustang dyno st 16psi. I'm running it on crappy canadian pump gas. -
I will use a t4 twinscroll. -
I have the Efr 6258. The EFR 7064 was essentially replaced by the efr 7163. It spools faster and makes the same power. Its been a great turbo. My tuner tells me i'm not getting full use out of it as i'm only running 16psi. The turbo can easily handle 25 psi. I don't plan on running E85. What i don't think you can see on the paper is how it feels to drive. Its the fastest spooling turbo i've ever felt. The wheel of the turbo is made out of a titanium blend. Sorry I cant add much more. I recommend you email Full Race and speak to the staff. They were very helpful when i was trying to decide which turbo to go with. I plan on swapping to the 7163 down the road. -
Hey ZTR any luck with the pictures?
Hey Suchfun240z I have an sr20det swapped 240z. I live in Vancouver BC. If your ever up this way I could show you my z. I haven't had a chance to take my z to Ridge motorsports yet. Maybe some time this summer i'll be down your way.
