Everything posted by TomoHawk
I'd like to see if we can find those elusive GTORR newsletters! Does anyone know who has them? I have a very good scanner, and I can easily scan them in color or B&W. Does anyone at least know the date of the first newsletter? thxZ
s30 blower motor upgrade w/pictures
TomoHawk replied to 280zedxt's topic in S30 Series - 240z, 260z, 280z
I looked at an Optima fan while looking for Sportages. It "looked" similar to the Datsun fan, IIRC, but you'd have to take it out to see for sure. Anyway, the mounting holes from the KIA fan (mine is from a 2007 Sportage) were not the same, but I think you just need to egg-out the holes slightly to make it work. Otherwise, the fan assembly was larger than the Datsun one, about an inch in overall diameter. How much of the fan box can you grind away? You gotta take the glovebox out to have enough room back there. BTW- While you're behind the glove box, I'd suggest you pull off all those firewall connector and treat the terminals to a good dose of Deoxit 100...- 13 replies
- heater box
- fan
(and 1 more)
Tagged with:
This is interesting... There are lots of KIAs in the junkyards (duh...) so these should be easier to find than the 1988-91 Civics. BUT.... if you want to order one that's new, you need to know which model of Sportage, such as LX, EX... Autoparts store kids only know what their computer will show- IF they know what to put into the computer entry screen in the first place.- 13 replies
- heater box
- fan
(and 1 more)
Tagged with:
Can it spin 8,000 RPM?
Think that 12 cylinder engine is wrong for the car, IMO. It's too big and too heavy. A lightweight 3 Litre V-8 with a short stroke would be more fitting, IMO, as it would be closer to the original specification.
Does it stioll exist? I was going to add mine, but I don't think the GTORR is still online, for obvious reasons.
Boranni got their modern (hub) design from Dayton... You might say Boranni and Dayton wheels are essentially the same, because the only real difference is where the spoke go through the rim.
After all the work you did, are you ready for people to tell you the car is a "fake" or a "Nissan kit car?" There are basically no armchair car enthusiasts that will appreciate a well-made anything, especially when they expect to see a $50 million car...
I had the same thoughts. I think it would help, but the slot would make a weak spot in the chassis, and you'll end up driving a red banana. I think reinforcing the frame in the area would be part of the job.
Here's something for you problem-solvers.... Car manufacturers start using VIN number in the mid-1950s, bur they were not standardized, even for any particular manufacturer, like Ferrari. So, besides the chassis' individual serial number, did these cars have some sort of VIN? I was able to find some bits of information: Chassis designations: 400 SA: 538 U 250 SWB/SWB Cal/GTO: 539 250 GT Lusso: 539 U Paint Code: Rosso Cina paint code: 20456 S So if you wanted to build a USA-style of a VIN, you could. OTOH, each GTO was personally sold by the dealer to the owner, and probably new the owner very well, and there were only the few cars made, so if you if you needed anything, you didn't have to enter the VIN (into computer) to get a part... But I'm still curious to see what there was at the time...
Here's a new thing that I'd like to do this summer.... The Zed bonnet had the louvers, and the GTO wings have the vent slots, so can we make some kind of vent slots in the back corners of the engine bay? I think I can get in there with a 11/2 inch hole saw and make two holes in a vertical line, then connect them for a slot. Would that be a problem with the stock L28 engine? You wouldn't want to end up with a banana car. Otherwise, I'll have to rig up a kind of spacer to hold the bonnet open about 3 inches, so the hot air can get out while parked or idling; the open bonnet seems to attract attention.
I suppose you never saw a certain Interet add for an air bag-jack that is inflated by exhaust?
al the trophy shops in my area are only able to engrave flat things like trophy plaques and medalions. The best the could do for me is to engrave a metal disc and I would have to glue it to the wheel nut, which might even look like the Boranni nut. Getting the disk machined is another tall hurdle, unless you have the CNC codes to do the work. There aren't any small shops either- all the older guys that worked from the home shops are out-of-business or retired.
One thing that got lost during the conversion is the air coming from the lower (foot) vents. As far as I can tell, the air comes from a 'scoop' that's part of the lower front wheel splash guard. The air pressurizes the area inside the front fender and then flows through a passage to the lower vents. When you remove the front bodywork, you remove the air scoop and the large duct formed by the fender & splash guard, so you no longer get the forced air. The 240Z didn't have the air scoop at the lower part of the front fender, so they added the plastic elbows from the radiator support to the fender area. I used my shop vac to blow are into the lower vent and searched to see if the air came out somewhere, like the windscreen wiper linkage area, but that is for the intake of fresh air to the ventilation/heater system. If I ha done this before permanently fixing the front bodywork, I would have provided another air path, like a 1-inch hose from somewhere near the nose.The exact place where the air get to the lower vents would be nice to know.... So my question is, how can you get air to the lower vents? A long hose from the brake cooling intake holes? Air scoops on the sides by the engine vents? It would also be nice to have some forced air into the upper (dash) vents, but that is easily done by adding the hood scoops and short ducting, like you are familiar with.
What kind of jack do you all use? I've got the standard Zed scissor jack, and I'm wondering if it would cause damage to the bottom on the fiberglass rocker? I suppose I could glue on a shallow piece of channel in the four places where you'd put the jack. I think some kind of hard rubber would be better. Both metal or hard rubber channel could be manufactured, then attached with glue or fasteners. But faux jack hole covers for the antique Riganti jack would be a nice touch. Here is a Riganti jack and a jack hole plug. I'm surprised no one was killed using those jacks.
Those headlamp rings look nice. Are they metal? Do you make them yourself? I'm working on some now.
Here's a real example of how the cars were not 'normalized': This is definitely a 250 GTO. 4713GT, the only 250 GTO to with a body of the 330 LMB.
"Period seats" ought to be easy enough to make. You just bend some heavy aluminum into a curved seat back, then the same for the seat bottom, weld it together, and add a bit of K-Mart-quality (stadium seat pads?) to each, and some mounting legs to fit the floor. I suppose a stadium seat from a sporting goods store would make a good example of the shape. There were a few "Lusso" (luxury) interior cars, with the carpets & padding, which I think were the ones with the roll-up windows, so I kept that in mind when I decided to omit the sliding windows, which would probably drive me nuts anyway.Otherwise, everything was plain, but with a nice coat of paint. IMO, from my research, not every 250 GTO left the factory in the same condition or state of manufacture as every other, so it gives you some leeway in your interpretation of what you'd want to have yours like. Some were modified by the owners later, and the ended up with stuff like ROUND fog/spot lamps, or NO fog lamps (empty holes for "ram air?"), or a third cooling slot (330s had them, but some 250s needed them) and different gauge arrangements (like a Zed has.) My secret cockpit recorder (a digital memo gizmo) recorded people saying how the Zed seats were "crappy seats." I suppose said "GTO expert" knows the GTOs came with the fancy, moulded carbon-fiber Recaro racing seats? Heck, there's even stories of how the doors were different lengths. So much for hand-beaten bodies.... But, obviously, it all fit together in a good way, so the guys had everything "fixed" before the owner got the keys.
"I had never seen the interior of this one!! Thanks for sharing!!" The Moss car is probably the best example of how the cars looked when they were leaving the factory. They were simple, with no luxury, except for the demisting nozzles. To save weight, they even left of the door panel finishers, carpeting, ant most everything else. I think if you took it to a "car show" I'll bet people will get (offended) by how there is no 'interior' and the simple aluminium seats would be called "crappy seats" because they are not carbon fiber, with leather and not labeled Recaro. The lack of carpeting, door panels, and the visible tubes of the frame are just too simple for anyone not thoroughly educated on the design. Just in case, go here to see the photos.
There's no need to plate the stainless steel rings. You can simply polish them. OTOH, I'm not sure that you can make the trim rings and put them on any car, because there is no spec for attaching the headlamp covers. People put the little brackets where ever they please, and it seems like they are place in about the same place on each side, it's not a perfect mirror-image. Having made some templates from posterboard, I tried it on my car, and even though the shape will do, the screw holes don't match, so I will have to make them individually, but only place the tabs for the screw holes in the right places on each.
They are self-duping, mate. You only have to collect the cheque.
He made a replica of a 240Z NISSAN Datsun?
If you offered a set to me for free, I would turn you down. The reason is that these cars were just not that fancy, there was no ventilation fan, rear-window defogger, not even carpet on the floor, except for a few exceptions by the private owners. I've looked at photos of the door doors, and they were either plain, or bare- no metal at all; all you could see was the frame which is otherwise covered. on street cars. You need to stay with your goal of building a GT car or a race car. The race cars were bare-bones vehicles, but the GT car were sometimes afforded a bit of car or the diamond-pattern vinyl on the transmission tunnel. If you really wanted to put something there, I'd suggest just a flat piece of metal, cut from a sheet, (not bent, like the Datsun piece is) with the script OR the logo (be careful of putting the word FERRARI on it, unless you like lawsuits, but the Cavallino speaks lots.) a brushed texture would be plenty of 'fancy.' This photo is of the Sir Stirling Moss car:
Welcome to the world of Internet discussion forums.
