Days Won
4
Content Type
Profiles
Blogs
Store
Posts posted by socorob
It's easy to adjust, just turn a POT.
Apex Engineered
I have the Bruno knob controller and Saturn steering box. When you 1st start the car, it takes a second or 2 to come on, but after that, I have never noticed anything weird feeling about it. I have it set really low.
There is a guy that sells a kit on one of the Z facebook pages that has all those parts to rebuild the hinges.
Just push it as far up as possible and use a block to scribe the shape of the bottom of the car to it. Then get out the grinder.
What kind of files are they?
I used the eastwood on my car. It has the consistency of water, so cover under the car when you spray it because it will start coming out of all the holes, seams, cracks, etc.
- 1
What kind of speed and range do you think you'll get?
Hybridz facebook page for the chit chat? The forum for the data and info?
Maybe someone on the Dastun Makers Group on facebook may have some?
I just got some peel and stick closed cell from the hardware store that was the right thickness.
I think this year was the pinnacle, I'm sorry I had to miss it because it will probably never be this good again. It was at a time of year with decent weather, not when its 150 outside, combined with Znationals and at Road Atlanta... what could possibly top that?
Get a flat steering wheel with no dish, that's probably a good 2" right there.
Theres a guy on youtube I saw a while back that says he road races his corvette. He had a nice setup, said it works well. All I can remember was he used this cap.
If I can find the guys vidoes, I'll post it here.
Can you show a picture or drawing of that routing?
78 280z. Bought the TTT setup and had 250 front , 300 rear on konis. Felt too soft, swapped to 300 up front. It is slightly stiff but feels much better than the 250s. 250s are way too light for the rear. The shocks are probably around 2/3 compressed at ride height. Just bought 350s, haven't installed them to know if they are going to be too stiff, but at 1620 rear weight with me, spare, full tank, etc. it should be around 1/3 compressed at ride height.
I also added flex pipes at the same time as the cats. 1 after each header, and i where it Ys back into single exhaust by the diff. I wish I would have cut my 3 bolt flange off and welded on V bands to my headers before I installed them. Without the flex pipes, the flange bolts would always loosen up on me. I would have to tighten them up several times a year. The flex pipes seem to have lessened that. I put V bands before the front flex pipes and after the rear one, so I can drop out the whole center section of the exhaust.
I put 2 magnaflow high flow cats on mine, and it did cut down on the raspiness/drone and quieted the car slightly. Also lowered how much I smell like fumes after driving around in the car all day. Don't get a flowmaster muffler, these drone a lot.
Thats what I meant
I copied the following from the sloppy mechanics on facebook, so don't know personally for sure this will work:
Someone used everything off the saturn but like 6" of the spline part that goes into the steering box. I used a NRG 177h steering wheel adapter (fits the saturn steering wheel spline) and aftermarket steering wheels. and for full disclosure- i had to trim off part of the nrg adapter, all the outer lip where the nrg logo is at on the amazon pic. but it was due to the housing that encloses my turn signal/wiper stalk assembly
These are for the earlier Z wipers that you just change the blades on.
Techno Toy Tuning or Apex Engineered have the tie rods. I got TTT to make mine longer so I could get as much camber as I would ever want. With the stock tie rod ends, I could barely get -1.5 camber with just maybe 1/2" threads left in the tie rods. I wasn't comfortable with such little engagement so I got the others and had them made longer. I'm sure apex would probably do the same if you ask.
The only thing about the Hoke kit is if you ever want to use the apex engineered cross member, I think you'd be out of luck. Or if for some reason you wreck your crossmember and his goes NLA.
Vintage Air blower unit space
in Interior
Posted
look around march 2014 posts. I ran the flexible lines around the back on a 78 280. Very tight, but it can be done.
