Gender
Male
Location
Sydney, Aus
Interests
Working on my Z. Golf.
Recent Profile Visitors
3374 profile views
andypurce's Achievements
0
Excellent thanks!
- 2 replies
- windscreen
- rear window
(and 4 more)
Tagged with:
Does anyone know where I can purchase the corner pieces for the chrome window locking trim for both front and rear screens on my Z? I have searched known sites but to no avail. Thanks
- 2 replies
- windscreen
- rear window
(and 4 more)
Tagged with:
Techno Toy Tunning Front LCA
andypurce replied to EvilC's topic in Brakes, Wheels, Suspension and Chassis
Being unaware of this thread before today I am pleased (!!!) to come across it and find that the maddening three hours I have just spent trying to match up my TTT front LCA to my modified brake and hub setup was not an unusual occurrence. I had already turned over the ball joint when I first installed it on the LCA but then when I presented it to the assembled brake/coilover I came across the problem. As I am lowering the car overall and fitting Roll Centre Adjusters my arm "just" fits - but its a feeler gauge gap! My front setup is cropped & welded strut casings; Otomoto HSD coilovers 55mm, 6.5kg springs, helpers, Koni 1220 Sport shocks; Toyota 4Runner 4 pot callipers, TTT 5-lug aluminium hubs; BMW E36 Vented 280mm rotors. The Rotors sit quite a way back on the stub shaft to align with the 4Runner calliper centreline (the callipers are straight bolt-ons to the standard lugs and the Rotors required a very slight skim but still well within the tolerences). Hence the close fit to the LCA. I am going to grind them back a little to allow reasonable for full movement changes - hate doing it to a new part but ce'st la vie! -
Thank you very much all of you. Solved!
- 4 replies
- connections
- harness
(and 4 more)
Tagged with:
I am building a turbo L28 engine stroked and bored to 3.1 litres with an upgraded turbo. I have the 1983 CAS dizzy driving my Microtech ECU and Igniter box. I don't have the wiring harness for the dizzy that has the Green, black, red, white wires from the dizz going to Gr/Ye, Black, Bl/Wh, Gr/Bl wires in the EFI harness. I have read every post on this and there are some that describe the connections that correspond on the dizz end to the colours BUT there isn't one that correlates with another, in other words there are CONFLICTING posts. So I really need to get the correct way round. Here are the options I have seen. Looking at the dizzy four spade male connector box with the screw hole for fastening the harness on the top left corner.(see pic): One post says starting at top left going clockwise: Red, Green, Black, white. Second post says (same rotation) : Green, Red, Black, White. Also, if I am reading the FSM correctly it agrees with post one above. Can anyone Please help and confirm which is correct? Many thanks guys. Andy
- 4 replies
- connections
- harness
(and 4 more)
Tagged with:
I am fitting the Techno Toy rear end conversion to my 260z. I have sourced the donor components from a z32 300zx but decided to shorten the axles myself as the cost of sending over and back to US from Aus was prohibitive. I have read all I can about this subject but i get conflicting opinions from both the threads on here and elsewhere and as there are a number of different axles / spline assemblies it is very type specific. My setup has an R230 VLSD with the 5 spoke diff stub axle outputs. These match to the 5 spoke CV shafts which are different lengths due to the Diff offset in the 300zx (RHS is longer). I have found a shop which will make me up new shafts, not a problem (I can't re-use the shafts I have as they narrow down in the section where I would need to cut the new splines). My problem is dismantling the wheel side CV assembly. The diff side is no problem - snap ring off, turn the assembly, balls drop out etc... But the manual says the wheel side cannot be dismantled then proceeds to say it can be taken off the shaft by using a slide hammer pulling on the wheel stub nut to pull the assembly off the shaft. Now, I may be missing the point completely but I can't see any way looking at the assembly that this can be done without breaking the circlip that holds the splined end into the ball race? The assembly casing looks close welded to me. Does anyone know how this can be done? Also, how do you re-install it ? Does the casing come apart when you give it enough welly? This latter action is the only way I can see that the shaft can be exposed and the cir clip then taken off ( and re-installed) but I can't see a joint on the assembly. If this is a factory sealed unit and thus can't be taken apart at all then does any Z'der in Aus know a CV manufacturer who will make new complete axles? Pics attached. Thanks all.
I need the wiring, including connectors, for the output from a late 280zx. Turbo electronic distributor. This is the dizzy with the single circular 360deg plate with 6 x output marks at 60deg intervals which connects to the 280zx ECU and is driven by a splined driveshaft not a straight tongue. I need the 4 pin (female) connector for the dizzy end with it along with a length of the wiring. The other end is not important but preferable if you can split it out from the loom. Alternatively I would be happy to purchase a complete "engine section" wiring loom as I can use this in stead of adding bits to my 260z loom. Can pay by PayPal or EFT. Thanks Andy
I am looking for the 2 x plastic side panels that go into the rear compartment. Must be for a 2+2 (either 260z or 280z). They each have perforated holes in the lower corner and cut-outs to fit. I will take items with minimal damage as long as they are not split or cracked. Also, need them to be shipped to Australia. Thanks.
Bought a crank with pistons, rods and bearing from Dave Rebello. CLOSED
Datsun 260Z Turbo S15 6 Speed TechnoToyTuning
andypurce replied to tooquick260's topic in S30 Series - 240z, 260z, 280z
Thanks for the advice. Great thread BTW! Think i have settled on the Arizona setup along with moustache bar etc... Will let you know how it goes . -
Hi How did you settle on buying the techno LCAs? I am looking to buy also but am not sure which ones are the best / value for money and performance. The ArizonaZ ones look tremendous but as long as they do the job and provide the scope of adjustment needed then I am happy to get any type. What's your view? Thanks -
'74 260z F54 Upgrade - 2 Engines to build!
andypurce replied to andypurce's topic in S30 Series - 240z, 260z, 280z
E30 head coming on a treat now. Will hopefully be flow-benching soon. Building a flow bench setup using a vacuum cleaner for the suction!! Does anyone have flow figures for the E31/E88 and N42 heads?
