Days Won
1
Content Type
Profiles
Blogs
Store
Everything posted by 98blackbell
Nice!
Datsun 260Z Turbo S15 6 Speed TechnoToyTuning
98blackbell replied to tooquick260's topic in S30 Series - 240z, 260z, 280z
Found a plug at Pep Boys. Got that plugged up then had oil leak. The an -4 90 onto the turbo was leaking at the hose. Went to tighten and snapped it off. Back to Pep Boys. They had 2, can you believe that. Back on and runs , no leaks. Need to put some miles on it before taking it to the track. Still need to finish the trunk area where we hung the fuel cell. I think tooquick is going to take the 88 Volvo rally cross in the dirt Saturday in Macon Ga. We swapped the cam out rigged up a cold air intake with a new alternator. Hillarious watching the car drifting. Stay tuned. -
Onto next mods. We are unhappy with the fuel system;tank, lines, pump Currently using the stock metal lines for supply and return. Msd2225 fuel pump. We are having fuel starvation on low fuel level and vacuum issues from poor venting. New plan is to remove fuel tank, remove spare tie wheel well and mount a fuel cell. Run -8 AN lines and fittings. Canister fuel filter. New fuel rail and fuel regulator. Run -8 fuel lines for supply and return. Just to add more work we are removing the 38mm tial blow off and adding a turbo smart blow off valve. Adding a hybrid t3/t4 turbo. Updating the exhaust, moving the oil cooler from between the radiator and inter cooler. Process and pictures are coming. -
That's respectful! Close to your goal with a few more things to work on. Now drive and enjoy! Well if you are like us your never totally satisfied.
Great build, How are engine temps? Wondering because we set up our oil cooler between the inter cooler and radiator like yours. Having some temp issues when hot lapping at events.
ANy issues with that hood? Alignment, latch or hinge bolts? Are you using the stock hardware?
I did all that. Ended up going diy megasquirt.
Fantastic. Great build, if my son and I could find time to work on ours.
Sorry Tony D! Thieves are the worse low lifes. My son (tooquick260 on here) had his first car stolen from our driveway, 1995 240sx wit out full coverage insurance. He worked McDs for 4 years to build it. S15 swap, 6 speed, a/c, body kit. Stolen at 3am Sunday 10/30/2010 morning (neighbors kid saw them) police found the car Monday night striped to the bone. We found the thieves but cops did nothing. Parts were spread out all over Florida! Now the Datsun is marked uniquely on all special parts real hard to disguise! We work to hard for this to happen, hope you have some justice.
Yeah you up to cruising to Savannah? Cars and coffee Saturday Mornings? We will meet you with tha datsun and wife's g35 coupe?
Looks great
https://youtu.be/baDfCgJmjlk In memory of the ones we lost. Visited Ft McAllister in Richmond Hill GA. -
Where did you mount your aftermarket fuse block?
98blackbell replied to Marduke's topic in Ignition and Electrical
Moved battery to rear and used that space for coil pack, and 2 fuse blocks. -
Stole the kids car for the day. https://www.youtube.com/watch?v=NhujyXuK920 -
I have chopper wheel. $50 shipped. I have a couple ecus, let me look and make sure they are not burnt. Had the flash tuned.
L26 conversion to fi with a turbo.
98blackbell replied to Dawtson's topic in S30 Series - 240z, 260z, 280z
Ditto. Look at our build. Did the p90 head with z31 ecu. Then hurt the motor, rebuild with megasquirt. We thought we had 8.9 to 1 but really closer to 9.1, so little agressive. Went back with thicker head gasket. Good luck. The details are the devil or the devil is in the details. Have fun. -
Newhy rebuilt turbo on the way. -
- 6 replies
- ms3pro
- megasquirt
- (and 4 more)
I would start a new thread but keep a link in your signature. Good luck with new build , please keep us up to date.
'72 240z RB25DET, no more ITB
98blackbell replied to winstonusmc's topic in S30 Series - 240z, 260z, 280z
Looks good. -
I have a set of 850cc high impedance.
Plans to go with new Garrett turbo with external waste gate to hold boost bettter. T3/T4e 50 trim should get to 400 hp. Don't want that much but would be nice to have a driveable 300-325 hp.
