Days Won
2
Content Type
Profiles
Blogs
Store
Posts posted by rk2334
I have already started and pulled the motor and trans out.
Hi forum,
I have z300 1989 with rb25det,I decided to swap 2jz. Found 2jzGE full built.
- 1
with ps6266 you can run higher psi than stock turbo 12psi. I think its ok to run 24psi with limited rpm to 7k because of weak oiling system.
Thanks for comments. I will make holes in shroud. There is a seal tape between shroud and rad to close the gap, also planning to install one 12inch slim puller fan.
Hi everyone,
I have swapped rb20 into 280zx 1983turbo. The stock speedometer was straight forward mechanical outputs, but I don’t know how to modify stock tachometer to take a rb20 signal .
Any advice is appreciated as always
Hi everyone,
I have upgraded my 240z brake booster with electrical vacuum pump, connected direct to brake booster, works great no issue
I bought rb25 pan and modified it Check my building
http://forums.hybridz.org/topic/123114-golden-rb-240z/?do=findComment&comment=1151028
better to go with R33gts or s14 crossmember, approximately 2inch wider
Blue z 89 2jz
in Z31 Series - 300ZX
Posted
converting to electrical power steering for Prius
