nathaninwa
nathaninwa last won the day on December 5 2015
nathaninwa had the most liked content!
About nathaninwa
- Birthday 05/24/1976
Gender
Male
Location
Aberdeen Wa
Interests
Welding and general fabrication. Drag racing
Recent Profile Visitors
3309 profile views
nathaninwa's Achievements
Project Rex Killer, 240z LS3
nathaninwa replied to nathaninwa's topic in Gen III & IV Chevy V8Z Tech Board
https://youtu.be/jmoMYCe9x7A Finally got back to the 1/4 mile this year after my winter upgrades. Nothing crazy but man the results are impressive This is at PIR in Portland on there street grudge night/test and tune I made 4 passes doing some testing on Wastegate pressures and starting to turn it up Major changes this year are a Glide versus the 80e I had, a2a versus a2w cooler and some random weight savings Setup is still soft on the launch as Portland isn't usually that great with the prep First pass. 4lb spring, 3400 launch. 10.46@145 Second pass. 10lb spring, 3400 launch. 9.76@152 Third pass. 10lb spring in low gear, ramped in 14lbs in high gear, 3400 launch. 9.39@165 Fourth and final pass. 10lb spring ramped to 14psi in low gear, ramped from 14 to 18ish lbs in high gear, raised the two step 4000. Car mustard an 8.86@171.7 And to be honest, like how we all datalog in our heads, it could have taken more power in low gear, and a bit more in the top of high gear. I could feel the car nose over near the finish and it may have taken more two step as well. But I was happy it made a clean pass and it drove on to the trailer! The last pass was a medium soft, 1.5x sixty foot with a 5.9x@131 1/8th mile time. The car picked up 40mph on the back half! -
Got this just about sorted. Pulled the cross member, welded on new slotted rack mounts, slotted the control arm mount and ended up fabbing my own caster rods. Turned out alright, and initial garage alignment shows 1/16 toe in at ride height and at rebound height I get 1/4 inch toe in I'll make a few 1/8 mile hits on this setup, collect some data and get the car aligned proper
My pics are not loading for some reason. But I just did some more testing. Raised rack and no LCA spacer it went all wonky again So I took the bolt out of the LCA pivot and put a pc of 1/8 rod in there and raised it, and toe for the one side went 1/4 in and out So I lowered the pivot point, and now it's 1/8 toe in compression and rebound Maybe more low would work. I'll see about more testing
Ok. I'll post a shot in bit after a cup of coffee I don't have any plot data, just a bunch if info written down on paper of static position, versus compressed and the rebound hieght my car travels at down the track I currently have a 14 inch, 125lb spring up front which maybe helping with nose lift after the launch. That's combined with a 90/10 drag strut. I have some material to make a splitter to help with bringing the front down, and I can get some 70/30 struts for my application. I'm running 3rd gen comaro struts, but can't fit the adjustables from how I mounted them. So I'm ordering some 12 inch 150lb coils for some testing I am running an LS, but it's setback in the chassis, and the manual pinto rack has tons of clearance And I have reamed my steering arm for the pinto balljoint. But from the overall width of the pinto rack, I'm not sure there is enough thread on the inner tierod, versus getting the bump steer kit installed safely In the beginning I wanted power steering, so I installed the Forester rack, but then decided that I wanted the manual system back. Since the 240 rack was gone, and buying one used and rebuilding it was more money than the pinto rack, I installed the pinto setup. After looking at pics I thought I was close to the stock position when welding in the mounts So yesterday I spent most of the time trial and erroring different spacing and positions. My initial setting would give me almost 3/4 inch toe out on the rebound hieght the car drives. I then spaced the balljoint down, the LCA arm down in various positions. Finally I found a setup that gets me 1/16 toe in and 1/16 toe in at both positions of compression and ride height rebound That setup is, pinto ball joint in positions with no spacers bolted up. LCA is spaced 1/2 inch down. I moved my rack up as far as I could within the bushing slot I can fix the rack positions easy, I'm at the point of either buying a 1 inch LCA spacer and machine it down to a 1/2 inch or just Drill a new hole in the cross member for the LCA pivot and bolt the arm to the spindle again. I can't really drill the member in the car, so it needs to come out. Running a full 1 inch spacer gives me 1/16 toe in on compression but 3/16 toe in on rebound
Hey guys, I spent most of today mocking up and cycling my suspension to cure a huge bump steer problem. I've installed a mustang 2 rack and thought the initial setting was good, till I started having issues at the track over 150mph My initial reading gave me darn near 15/16 tow out under power. So after looking st the data and finding the static, braking and non launch acceleration height I was able to plot all this. I found raising my rack and adding a 1/2 ball joint strut spacer netted me the best results at 1/16 toe in, in both directions So my questions is, if I drill or slot the cross member for the raised position that 1/2 inch, will it be the same as the mockup spacer I have and I'll be able to take it out?
Well, got this project track ready. Racing begins next weekend with a local 1/8th mile top ten series Borrowed some scales from a friend and all my hard work paid off over the winter. I was rewarde with a 2152lb race car with it 2326 with all safety gear and me in it -
Got all this put together today. Caliper ended up perfect after I had to shim the inner bearing out. The hearings are closer together on the gm stuff so the outer bearing was binding on the spindles taper just before getting tight enough. So I found .030 worth of shim for a pinion, this was enough to get proper preload without bearing binding and proper caliper alignment I'm pleased with the results, you can actually feel the weight difference in just spinning the rotor. -
Recently I picked up a 280z to have a driver, so this car is being more straight up race car built instead of dual purpose. I'll still be able to take it down to the local coffee meets and car shows, just not the driver type I was wanting it to be. So it's all about weight this time. 2600 race ready is my goal and with as much power as I have I'm sure I'll be asked for more cage this year! -
I forgot to cross post. Here is a post from a thread that got moved with my 8.50 pass Hi guys. After a summers worth of test and tunes, new parts and modifying old ones, ran a new personal best yesterday The run was clean and straight, very happy with the results https://youtu.be/m6_jfZbFEm8. Video from outside In car video [/url] -
Been doing some work on this car. Updated some stuff up front, redid radiator and shroud along with moving it forward, dropping some weight too. Also updated to the borg warner race cover on the turbo Got a kirkey seat installed, saved a bunch of weight there and moved me down about 5 inches Working on a new alum dash setup and wiring up the efi a little tidier with all the add ons I did over last season Powerglide parts are on the way And what I'm excited about. Doing some googling I read on Hybridz that gm hubs will bolt onto the s30 spindle. After looking at a PDF of all the hubs, I chose the mid 80's G body hub. Replacing the 300z hub i setup everything around this hub is almost a drop in with rotor placement 1/8 closer and the wheel moving in 1/16. The 3rd gen Camaro would put the rotor in the same location for me but move the wheel out 1/16. Some minor matching of my own rotor hat and wheel spacer can solve this but over happy with the bolt on rotor and wilwood stocks a seal that fits the spindle too The rotor no longer bolts to the back as it does on the 300z setup, rather its sandwiched between the wheel and hub. Getting the correct the rotor fitment means a 3/4 wheel spacer for me to keep the 300z wheel mounting surface location. I'll use 3 inch studs to make all this happen as one unit -
I was able to draw one up tonight
Hey guys, did some searching with my goto places, but no real luck. I'm looking for a 240Z or just a Z logo in dxf format Is there anything out?
Very nice. What size it that setup?
It's a drag car first and wanted more room for my turbo kit. Plus the weight transfer. My bellhousings mating surface is about 1/4 inch behind the firewall
