Everything posted by Project1
Cobra imola pro fit ...don't fit ..motha €@#£ER. I think I'm going to smash that hump down a bit and make a custom bracket. But they sure are not a quick bolt in.
280z Full Restomod with custom body kit & RB26
Project1 replied to redlinevo7's topic in Nissan RB Forum
dang thats a lot of great work!! Thanks for posting. Helped me figure out some sizing for some fuel stuff I'm working on.- 110 replies
- 280z
- restoration
(and 8 more)
Tagged with:
dang!! is that rescue green. thats suck a sick color for a Z. looks great man.
bumble ... (Yes I know this post is stupid old), Dang! That was a really awesome post. I have a 75 280z with an 83 zx motor. I really learned a ton and so many of my questions about the stock EFI was addressed in your post. Thank you for posting that up with pic! Luke
New to forum, need experienced advice Please
Project1 replied to Project1's topic in Nissan L6 Forum
Did some transmission swapping. Put in the 5 speed but it needs a rebuild. The 4 speed I have was just rebuilt so I decided to run that. Got a new exedy clutch. Finally did the first drive, went ok. My rear Ebrake is locked shut but the motor did ok. If I can figure out how to post a video I'll post one of the motor running, it sounds really good. And it sure feels a ton different than the last motor. It reves through the midrange really nice. :-) added gps tracking today. Totally worth it. There's an app for that . Just click on the app and see where your car is at. So you can tell the police where to find the bodies ... I mean the car .. The body of the car of corpse ..I mean of course. -
Really nice build man Edit: just saw your close. I'm in fl
Finally,, this thing is running !!!! Went for a test drive ... But the clutch wouldn't engage ... Mer... So I read about the new clutch I got with the motor and from what I read the baring was the same for both clutches. I used my old barring and the new clutch. After bleeding this thing abut 100 times and full clutch adjustment with no signes of improvement, I'm guessing it has to be the barring.... .... c@$& sucker mother f&@$(? ....I guess I'll have to pull this d@$? Thing back out and swap the clutch. I gave my factory clutch to a friend too. ... Edit a day later: Got rid of most of the fuseable links today, put the ac on a relay switch so I can control it manually, and jacked this thing up. Putting the 5 speed in and have a new clutch in the mail. It already has a zx master cylinder and slave. So since I have to take this thing out anyways and the motor is running well I figured I'll just swap the 5 speed in with a new clutch now. I ended up going with a exedy stage 2 clutch because I read good things, it's a very strong and streetable clutch, and the price was right. I think my current problem is I used a barring for a 225mm clutch and used a 240mm clutch, which I didn't think was the case at the time, but it's the most likely problem. -
I think the smoke is decently burn off from the header paint. I can see it turning brown and burning off. I hope I'm not running too hot? My coolant temp gauge is not work, reading about that right now. -
Thanks man Yea that's probably true. I just thought I would see this tread through with the motor swap. I have been posting too for other people down the road. I have spent a lot of time trying to understand stuff I just couldn't find a clear or definitive answer to from reading online. So if someone else had the same issues maybe this tread would clarify some stuff for them, like useing an 83 dizzy w/75 computer and running it off an msd. But maybe I'll start a build thread, I do like reading other people's builds a lot and I'm looking forward to working on this Z a bunch and making this my DD. -
Merr .. So you thought I was crazy when I said I should put the fire department on stand by .... Anyways, tach is not working. I probably just need a tach adapter, the 8920 I think. I'm getting s bunch of smoke from the exhaust. The timing seems good, but maybe it's getting too much fuel and it's incomplete combustion. Or maybe it's just stuff burning off but more likely too much fuel. It seems to be running awesome thought other than looking like its on fire. The smoke does increase rapidly as I rev it up. Idk ... Merr ... -
Well, as evidence by I am the only person who has posted on this page I'm probably just talking to myself..., which is fine. I think the rule is its ok to talk to yourself, or subvocalize, as long as you don't respond to yourself. Yes that's right .. Wait .. Merr ... Never mind. Anyways, I figured out the problem and the motor cracked up today. It actually surprised me, it started right up and sounded awesome! I had a crack in the thermostat housing and it was spraying coolant. I changed that and did some other stuff but didn't crank it again. A few more things left. Hopefully soon I can let it run for a bit and take it for a ride. If all goes well, I'll dive it for a bit and then get the MS set up and ditch the stock efi. So that was the problem I was having, the stock efi wasn't getting the pulse to fire the fuel injectors. It was kinda a tricky issue because the stock set up has the blue wire from the coil pulse the efi to fire the injectors with a single 12v pulse. However the 400v msd puts off multiple pulses to fire the coil and doesn't work with the stock efi. I knew the voltage was an issue so I never hooked up the blue wire to the coil thinking it only was a tach wire, I didn't realize it also went to the ecu. So what I ended up doing was running a wire from the msd tach hookup to the tach and the ecu and it cranked right up without a single hesitation. So I guess I'll have to see if under load the signal stays strong enough to run the tach and the ecu, if not adding a tach adapter should boost up the signal and get it firing. -
Well, turns out it was the starter. Replaced the starter and got a crank! ... .. But no spark ...merr. Long story short now I have a good spark. I also am getting fuel, but I'm still not starting .... I'll keep reading but any suggestions are welcomed -
Still can't get the starter to get power. I'm thinking it's the old viper alarm -
Finished the motor today!!! The pic is from the start of the day not the end, but it's done. All that's left is the switch panel in the interior and turn the key. So tomorrow ... We'll see what happens. Well, it's not getting power to the starter? Idk .. Has fuel pressure. Msd seems in order. I think is the pos alarm system that was on the car. Not sure, but I'll keep on it...merrr -
Really really nice job
Was out of town for a bit for some races, had a super good time. Made a bit more progress, sorry for the night pics. It's pretty close. I would say less than 12 hours of work before I give the key a turn and see what happens. All that's left is the vacume system, plug wires, fuel lines, electric fans and a few switches. -
Ok, update ! Don't do anything I posted in my first post, as its all wrong and exploded. The way it ended up working was I got rid of all the factor wiring to the ignition all together. I also scraped the E12-80. I ran the wires (red +/green-) inside the distributer to the magnetic pickup ( violet/green) on the msd. When doing this don't use the white wire, just cap it off. Heavy red/black right to the battery. I really would like to fuse this, I called msd and they said it absolutely isn't necessary because it's run from a switch and a fused relay, however I would feel safe if it was. Orange and black to the coil. And the small red to a switch. I ran mine from the fuse box to a switch board I built in my dash, if you want to run it to the factory ignition (12v from the key) it is the black wire with the white stripe. I used the factory cap to the positive on the coil. I read a bit about this and it's a really good idea, actually I think it's worth getting a good cap for the coil and at some point I will grab a good one. Well, ok there you go. That's how you use a 83zx distributer, 75 ecu and wiring, and a msd. I will post some pics later Edit: So still wasn't working but I figured it out. So that was the problem I was having, the stock efi wasn't getting the pulse to fire the fuel injection. It was kinda a tricky issue because the stock set up has the blue wire from the coil pulse the efi to fire the injectors at s single 12v pulse. However the 400v msd puts off multiple pulses to fire the coil and doesn't work with the stock efi. I knew the voltage was an issue so I never hooked it up thinking it only was a tach wire, I didn't realize it also went to the ecu. So what I ended up doing was running a wire from the msd tach hookup to the tach and the ecu and it cranked right up without a single hesitation. So I guess I'll have to see if under load the signal stays strong enough to run the tach and the ecu, if not adding a tach adapter should boost up the signal and get it firing.
Rota Shakotans.... anyone running them?
Project1 replied to ComicArtist's topic in Brakes, Wheels, Suspension and Chassis
Pics already -
Thank you for the advice. I'll keep it posted how it goes, might help someone else in the same spot. I blew an MSD a long time ago from doing something with hooking it to the battery. I have to read about that. I don't know why the power wire from the battery to the msd doesn't have a visible fuse that can be changed? I might add one. Would a 30amp work?
