oatmilk
  • Content count
    110
  • Donations
    0.00 USD
  • Feedback
    0%
Community Reputation
0 Neutral
About oatmilk
  • Rank
    Member
Contact Methods
  • MSN
    oatmilk
  • Gender
    Not Telling
  • Location
    Los Angeles
Recent Profile Visitors
2735 profile views
  1. oatmilk
    Exciting news! I just got a 240Z race car!
    Type 1 for me. Nice car.
  2. oatmilk
    Headlight/ turn switch
    early 72 or late 72? Curious if it will fit a 1973 240Z. PM me if it will fit.
  3. oatmilk
    2JZ engine build question
    By the way im in west la so not to to far away if u ever want to see mine.
  4. oatmilk
    I would go with a JDM 2jzgte vvti motor that includes the non-mobilzer ecu and oe jdm maff with a complete uncut engine harness. I would do a timing belt kit on it, change the valve stem seals, valve cover gaskets, rear sump oil pan conversion. Get the Driftmotion kit that allows you to remove the A/C and P/S. Make or buy your own motor mounts and tranny mounts. Get a 7MGTE starter FYI: Trans wise you can get brand new R-154's here:https://www.driftmotion.com/. Cheaper Toyota option would be a W58 instead of a R154 or look all the other options mentioned in previous posts Get whatever 1jz clutch kit of your choosing. Custom driveshaft. Save money where you can by buying the parts below used if available. Just my $0.02 Parts list: 2jzgte vvti engine (Complete)- http://www.ebay.com/itm/TOYOTA-JDM-2JZGTE-ARISTO-SUPRA-TWIN-TURBO-MOTOR-VVTI-ENGINE-AT-TRANS-ECU-CHIP-/152658829321?hash=item238b2ce009:g:YVMAAOSw7cVZjPGh&vxp=mtr New R-154 5spd transmission - www.driftmotion.com/ Rear sump kit - http://www.ebay.com/itm/Lexus-SC300-Toyota-Supra-OEM-Rear-Sump-Oil-Pan-Kit-Hardware-Dipstick-1jz-2jz-/332333215813?hash=item4d609a7045:g:GyUAAOSwAYJZhgvT&vxp=mtr 240z 2jzgte swap kit - http://www.ebay.com/itm/Engine-Transmission-Mounts-Swap-Kit-For-Nissan-Datsun-S30-240Z-260Z-280Z-2JZ-GTE-/331430355287?hash=item4d2ac9e157:g:cLcAAOSwMpZUoiCh&vxp=mtr Timing Belt Kit - http://www.ebay.com/itm/93-98-Toyota-Supra-Turbo-3-0L-Timing-Belt-AISIN-Water-Pump-Tensioner-Kit-2JZGTE-/151787026615?epid=12002633641&hash=item23573638b7:g:pg0AAOSwd0BV1hiJ&vxp=mtr 2jzgte gasket/seal kit - http://www.ebay.com/itm/OEM-Toyota-full-gasket-kit-for-2JZ-GTE-2JZGTE-engines-JZA80-JZS161-04111-46056-/282365877095?epid=658943624&hash=item41be515b67:g:4YcAAOSwnKFYRfHw&vxp=mtr Gates racing timing belt (Optional) - http://www.ebay.com/itm/GATES-93-98-Toyota-Supra-2JZGE-3-0L-L6-2JZGTE-Blue-Racing-Timing-Belt-RB-ea-/291153431758?hash=item43ca18ccce:g:ie0AAOxy7nNTV0bN&vxp=mtr 1jzgte clutch kit - http://www.ebay.com/itm/QSC-Stage-3-Clutch-Kit-Race-Flywheel-Supra-Soarer-SC300-1JZGTE-2JZGTE-R154-Swap-/282043672100?hash=item41ab1ce624:g:tWwAAOSwpRRWpqoI&vxp=mtr A/C & P/S delete kit (Optional) - http://www.driftmotion.com/product-p/dm2082.htm Upgraded Oil pump (Optional) - http://www.ebay.com/itm/Titan-Motorsports-Modified-Oil-Pump-Toyota-Supra-2JZ-2JZ-GTE-MKIV-1993-98-/122083020388?epid=531625707&hash=item1c6cb70e64:g:pbsAAOSwMtxXrpqj&vxp=mtr Starter motor - http://www.ebay.com/itm/1986-1991-Toyota-Supra-Turbo-7MGTE-Starter-Manual-Turbo-Transmission-28100-45050-/112498862774?hash=item1a31746ab6:g:g0wAAOSwcj5ZUyDG&vxp=mtr Radiator - http://www.ebay.com/itm/3-Row-Champion-Radiator-For-1970-1975-Datsun-Nissan-240z-260z-With-Shroud-Fans-/192081821525?epid=1017767761&hash=item2cb8f7ff55:g:OR8AAOSw9N1Vv4tx&vxp=mtr Intercooler kit - http://www.ebay.com/itm/CXRacing-Bolt-on-FM-Intercooler-kit-For-Nissan-RB20-RB25-RB25DET-240Z-260Z-280Z-/331124936642?hash=item4d18958fc2:g:DtsAAMXQzH9SGBmO&vxp=mtr
  5. oatmilk
    My 240z 2JZ-GTE swap
    Make shift set-up to see that it actually runs. Next up is running PTFE fuel lines from the ATL (with internal fuel sump containing dual Bosch 044's) fuel cell to the fuel rail View My Video
  6. oatmilk
    Better pic.
  7. oatmilk
    If u can find it I put a pic and the first start-up video (poor quaity) in the members gallery called: OG 240Z-2JZGTE I will make a better quality first start-up video later on. Thanks. P.S. Yes it turned into a much longer project but then I had expected. Im sure my first drive and smile on my face will quickly erase all the years it has took.
  8. oatmilk
    OG 240Z-2JZGTE
    My long term Z car project
  9. oatmilk
    will try to get it home this weekend or next at the latest. Forgot how to post pics and vids. Will do soon.
  10. oatmilk
    Believe it or not this project is still alive. I just wrote a huge long essay detailing every bit of this project and a tribute to johnc whose fingerprints are all over my car and wouldn't you know I accidentally closed the page and my whole disertation was gone in a blink of an eye. Suffice to say, I'm proud to say its actually running for the first time. Betwen johnc and Vildani I've had the best working on my car. Can wait to finish it and bring it out to some shows.
  11. oatmilk
    T5 Trans with MGW shifter
    Will this drop into a 1973 240z without modifying the shifter opening? Same regarding the drive shaft. Thanks
  12. oatmilk
    Good 280Z Fuel Injection Diagnosis article
    Well I'll try this again. Link is below as I'm writing this post so if it disappears as soon as I hit the "Post" button i must be doing something wrong. Thanks http://www.import-car.com/ecu-diagnostics/# www.import-car.com/ecu-diagnostics/#
  13. oatmilk
    I accidentally double posted and now the article and link is gone. Not sure what happened. PM me if you want it I guess. Bummer. Not sure if a posting rule was broken or not, surely wasn't intentional.
  14. oatmilk
    1983 280 zx turbo
    PM sent
