I recently bought my first Z, a 1972 240z with a pre-done L28 swap that, according to the PO, is stroked to 3.0 liters with forged internals and an upgraded cam. It's been a great car, however it runs on the original L24 carbs which have trouble supplying the necessary fuel throughout the rev range, and completely maxes out at 5,000 rpm. It is frustrating having an engine with so much potential for decent power that is held back by the carbs, so I'm curious as to what direction I should go with this project. I read on some long-winded article that I can either modify the carbs with larger needles and other components, have rebello bore them out, or go with an EFI system. I like the idea of EFI because I live in, and will most likely be going to college in a cold climate and starting the car is a difficult task. As I understand it, the engine was built with low compression by the PO for the eventual addition of a turbo later on (which I plan to do too, just a few years from now) and I'm told that adding a turbo to EFI is easier and more reliable to run than turbo+carbs. The PO also has a "manifold and actual rail and body for injection" that he is willing to give me a discount on should I go that route. So, I'm curious as to how difficult and costly it would be for me to make the switch from carbs to EFI, and whether or not the current carbs would be able to be modified to work with the current engine demands without a liberal amount of work. Also which would be the best in the long run for the eventual addition of a turbo?
Thanks,
Jack
