tube80z
Super Moderators
  • Days Won
    25
Posts posted by tube80z
  1. 4 hours ago, AydinZ71 said:
    @tube80z
    are you considering dropping-in a Tilton pedal assembly with an adjustable mechanical bias knob? That’s what I have on the car now. I take notes on how many turns either direction will lock-up the front or the back.
    If you have a logger/dash and front and rear brake pressure sensors you can set it by pressure in the pits.  Instead of turns.  Turns are also hard to keep track of when you come running up to a corner.  I have a Tilton pedal set and their bias adjuster already.  I'm looking at changing from turns to a linear system of steps to easily change from max front to max rear. I've seen two systems I like.  During the Schumacher era at Ferrari they created a stepped system so Michael could change brake bias between corners.  Triple Eight racing (V8 Supercars) created a system like an ARB adjuster for their drivers and that's another option.  I have had too many runs that rain started falling and I would have loved to be able to change bias and ARBs quickly.  I'd like a Bosch motorsports ABS but it's too expensive to justify for me.
  2. On 3/28/2024 at 11:24 AM, Drums4Rum said:
    Hey everyone! I'm Ryan and I'm finally starting my childhood dream resto, the 280z. It's a completely stock 1978 280z with the L28 I6 motor (N47/N42 combo) with a 5 speed and R200 diff. I've already gotten it mostly down to the shell except for the dash and suspension.  Before I start the motor rebuild, I wanted to ask some of you up here some suggestions instead of sifting through this entire site's worth of forums. I want the motor to have some kick and some top end but I don't think I'm gonna bore over any or get a turbo. I wanted to possibly give it an upgraded cam, port and polish, switch it to triple weber, exhaust, light weight flywheel and swap the diff with the STI diff. With switching to carbs, would i be able to delete the computer? I'm hoping you guys can give me some suggestions on good quality/size cams or any other performance tips/parts to bring this beauty back to life while also maintaining reliability as well as power. I've been turning wrenches since I was 10 but never built a motor.  Any help would be greatly appreciated. Thank you guys!
    You have packed a lot into your intro.  There's some good advice below to consider in the posts to your question.  But I have to ask you what is it about the 280 you love?  I don't mean that coyly or as some flippant remark.  What is it you really like?  I'll give you why I like the Zs.
    I grew up around them when they were new, my uncle was a general manager of a Datsun dealership so we got to try out the new cars.  We raced with my uncle at autocross and hillclimbs (I was a kid so I just went along).  Back then the Z cars were fast and sounded awesome (I have the hearing loss to prove it), and were amazing at cutting through the corners both stock and modified.  Our local racing club had about 10 people driving stock to all-out racing versions.
    50 years pass and a lot of that coolness has mostly worn off except for the look of a lowered S30 with an airdam and rear spoiler.  I have to admit the sound of a modified Z makes me happy when I hear it.  But this site exists to help people get the most out of them.  And the reality of that is as cool as the L28 engine is you're looking at spending a lot of money and you'll have an engine that makes 200 to 250 HP.  Sure you can get more but then all the other parts that connect to that engine are starting to get pushed past their limits given the age.
    While I don't disagree with any of the posts below you should still read about a lot of the mods and why they were done.  You'll find that in many cases they were driven by it costing too much, parts NLA, etcetera.  A bit of advice from me.  Never by an engine, transmission, or rear end unless you plan to use it within a few months.  Even if you plan to use it that's not the same as ready to bolt in.  If you want a street car with a certain coolness and triple Weber carbs, then build it.  But when you spend 10K on an engine and find it's somewhat finicky to drive but cool all the same.  But for less, you could have 350 HP V6 in the DI Chevy LV3.  It won't sound the same as the L-motor but it's lighter, a lot newer, and will get excellent mileage, It will start anywhere if it's hot or cold by the sea or at altitude.   This site has a ton of info on how to do the same for the suspension and how to get a cheaper rear diff, especially if you want an LSD.
    I could write a lot more but this is probably too long as it is.  Welcome to Z ownership.
    Cary
    • Like 1
    • Thanks 1
  3. Here's the Mustang GT-4 camber plate I mentioned
    Here's a slightly better picture.
    You can see they moved the center a bit.  You could make something like this but has a square shape or even just a flat edge and easy shim adjustment awaits.  I was looking at this for being able to make faster adjustments between runs when testing for autocrossing.  Having to jack up the car wasn't going to help make it faster.  In some of the events I run, we may get 10 minutes between turns.  You need to add in looking at the data to see if it helped if the lap time doesn't seem to show an improvement.
    I have a long list of items I want in my next car.  At the top is a lever adjustable brake bias with presets.  So while driving I can change between slow corners and fast corners.  Drive adjustable ARBs, and externally adjustable ride height.
  4. @AydinZ71 I'm not sure that bending the strut will work for Konis as they are generally tight.  I've heard rumors but never seen them in person about a certain BMW team that had a jig that mounted in a hydraulic press to bend in some extra camber.
    Getting the tube out of the is going to be some work but I think that might be the best way to go.  Another option would be to build a custom strut and use Nascar hubs 5x5s I think are called.  That will help with pad knockback.  Another option if you haven't used them is 280Z struts.  They are thicker and should flex less. Or you can show up with some DTM inspiration :-)
    Cary
  5. On 3/23/2024 at 2:49 PM, AydinZ71 said:
    Drilling new holes or slotting the towers is OK. Welding-in a camber plate to replace the strut landing in the tower was NOT considered OK.
    It's funny how certain rules are set in stone and others are ignored.  You could make a custom camber plate that is mounted to the top of the strut using the tower edges.  There would be no more center hole in this design as it would all be covered.  If they challenge it you could argue that you wanted to be able to swap springs more quickly out the top.  Take a look at rally car service videos and many of those cars come out the top.
    My personal choice for camber plates would be a square/rectangle design where you can shim for camber or caster/strut angle (rear).  Ford has a really cool design I meant to steal but couldn't find it again on their GT4 Mustang.
    Hope that helps, or inspires some rule bending.
  6. 5 hours ago, AydinZ71 said:
    @clarkspeed thanks Clark!
    lesson learned… if you buy “bolt on” parts, even if the reason is to meet class rules, it’s safer to assume they were designed for the street crowd. I no longer believe any of these companies, T3, Apex, Ground Control, have designed or tested their parts for anything other than a street car. I’m sure there are exceptions, and recognize im frustrated. I will only de adapting universal parts designed for Motorsport in the future.
    To be fair to GC the plates aren't intended to be used with that much track increase.  You may need to back that off to stay legal in EP rules.  I don't have a GCR so I'm not sure what you can or can't do with the shock tower and camber plates.  When I widened the front track in my car, I moved the camber plate to almost under the fender mount.  I've also used a porta power to add some positive crash damage but that needs to be done before you tie into the roll cage.
    Cary
  7. 4 hours ago, zev said:
    Wow, mostly pro-injection!!  Anyone else who wants to contribute I’m all ears.
    also one other question… if my Webers are 45 with 38mm venturis should the ITB’s be sized at 45 also?
    I have a long history with sidedrafts and used to have tons of jets, emulsion tubes, etc.  The advantage you'd see on just a 45 mm throttlebody is that you don't have the auxiliary venturi and the chokes.  So you'll see more airflow with EFI than with the carbs.  Do you need a larger throttlebody is the question?  Do you currently see a vacuum in the manifold?  If your engine makes over 300 HP then I'd be inclined to look at a 50s or 55s.  I'd call Rebello and ask him for a recommendation as he'd know best.
    Cary
  8. Look up used NASCAR parts on eBay for some stuff (window nets, fire suppression, etc.).  I'd check local club newsletters for used parts and any of the facebook groups for used racer stuff.  But you probably already know all that.  And you can ask around at some of the races/track days to see if you can find anything.
    Cary
    • Like 1
  9. On 2/22/2024 at 8:54 AM, Sanchez said:
    I think I remember a thread not too long ago about the possibility of “frenching” the windshield by having glass made a little larger in the dimensions and deleting the gasket entirely for sealant. It might have some more information about using sealant.
    If you want to do a modern flush mount look this is probably what you need to do.  I'm half-assing it with a different method for my car, at least at first.  And that's gluing the windshield and then using RTV to fill the gap and smoothing it.  I saw this back in the 80s and 90s on a few of the IMSA cars.  I asked a pit member how they did this and that's what he told me.  I'm also thinking about a 3D-printed rain gutter bridge to make air flow down the side of the car better.
    Cary
  10. On 2/22/2024 at 12:48 AM, munters said:
    Or go a complete new way of tuning with Keith Frank
    at https://vintagetechnologygarage.groups.io/g/sidedraft/topic/100219752#4322
    He has a big knowledge of the DCOE carbs and helps to the end of tuning.
    I went his route and find them way better and easier to tune compared to the original weber.
    Can you give a summary of what this method is?  I went to that link, which required a signup and only found a group with a ton of emails.
  11. 1 hour ago, Sanchez said:
     heavy duty sealant that is used for glass install can be hardened to the point that when the chassis flex’s a bit it can crack the glass. Now depending on where you live or the cars purposes you may have flat roads all the time, but in the Midwest I can definitely see how some of these potholes on the road could easily cause that to happen.
    A friend built an endurance car (Chumpcar/Lucky Dog) and was going to use a new Nissan gasket.  I talked him into gluing the windshield and was amazed at the results.  The difference between this and a normal gasket was the same having a strut bar or not.  This car has been used hard, ridden some large curbs, and never cracked a windshield.  I'm not saying it can't happen on the street but I'll be gluing in my street car's windshield when we get to that point.
    Cary
    • Like 1
  12. Hard to say.  The only L-series engine I weighed was a friend's race car long block and nothing but a Peterson dry sump, Alloy crank pulley, and dry sump drive.  That was 325.  So I don't know if that is going to be 50 lbs, but it's probably very close.
  13. 13 hours ago, Mikelly said:
    Of course, cameras are a part of the mix, and you can spend a small fortune integrating a system to utilize the data overlays for the cameras (I'm looking at you, AIM). One of the things that Garmin does well is integrate the data and video together for easy review and uploads to SM.  For those still using go-pros (I am one), Racerender is a nice way to stitch the data together with the video, if you are patient and have the desire.  The instructions can be a little clunky and if importing AIM data, you need to convert the channels to CSV first.
    Hey Mike, great to hear from you.  I'd also take a look at https://www.race-technology.com/gb/gopro software for pulling data on most newer gopro cameras.  And if you want to be able to mix and match data Track Attack is nice software to use.  It also can integrate most action cameras into a feed with overlaid data.
    Cary
  14. On 9/28/2023 at 11:48 AM, AydinZ71 said:
    Seems silly to replace the drum cylinder now just to remove them again after j a few months, so it looks like I’ll have to do the rear disk conversion now.
    @clarkspeed dusting off your really helpful e-mails on the rear brake design and brake setup. I’ll make an initial plan and look forward to your feedback.
    primary concern now is to ensure I don’t go TOO big in the rear so my brake bias is not too lopsided.
    Hey Aydin,  I would do one small mod that will save you down the road.  Use a small section of flexible brake lines that goes from the masters to a block on the firewall that terminates the hard lines and has a high spot for a bleeder (one with a check valve).
    When I got this advice I thought it was stupid until I needed to fix a master that was leaky.  I had it removed, new one installed, and blead in about 5 minutes.   When a friend had a similar issue the hard line kept leaking and this similar process was a half hour or more.
    Cary
  15. The LV1 only came in vans as far as I know.  The LV3 is more widely available but has displacement on demand (DOD) that needs to be removed.  You can pull the balance shaft out and they work fine from what I've read.  For some reason these are super pricey, which seems odd as there should be a bunch on the used market.  They came in a number of trucks and small SUVs.
    The LV1 and LV3 are 100 pounds lighter than the equivalent V8.  Scoggin Dicky has some dyno videos where they used a pulled LV3 with DOD delete and a new cam and it made 368 HP and had over 300 ft-lbs of torque at 2 or 2.5K.
    • Like 1
  16. On 8/13/2023 at 4:49 PM, AydinZ71 said:
    thats a neat ideal! Il do some research. I ditched the linkages for a lokar cable so il need to fabricate one anyways.
    Almost all the new throttlebodies have them as a cam and you can either borrow one or make something similar.  If you wanted to do it so that the linkage looked stock you probably could hide this under the dash or put the same on the firewall for the cable from the pedal would wrap onto.
    I think you could make different options to fine tune the response to where it works best for you.  I stole the idea from John DeArman (sp?) who used to have a Z car technical magazine.  And was a prolific poster on the old. alt.hotrod Usenet news channel.
    Cary
  17. 19 minutes ago, AydinZ71 said:
    I bought the ITB's over a year ago. At the time, I didn't recall if they had another L-series option other than 50mm. Agreed, its going to be a tight throttle margin. Should pair nice with the Stahl header with the 41mm primaries.
    One thing you can try to make the ITBs more drivable is to create a progressive throttle cam so the throttle moves a lot less on the initial pedal movement.  I had a car with light-switch SUs and this helped add some drivability to the car.
    Cary
  18. Hi Randall,
    I added your unbanned your old account (Randall/K12) and you should be good to go.  I probably screwed up and banned you by mistake.  We've had a lot of problems with spammers and scanners lately so all the forum admin tasks are manually done edited rather than allowing them to be automated we switched to manual.  This helps keep accounts from spamming after they site dormant for a while.
    That shouldn't have bothered you with an existing account so I'm not sure what I did make this happen.  I'm sorry for any inconvenience this caused. If you have any problems getting back into the account please let me know.
    Thanks,
    Cary
  19. On 7/29/2023 at 10:19 AM, calZ said:
    Haltech is a pretty good option with almost Motec features without the Motec price.
    Also check out the MaxxECU range.  Andy Whittle has many nice things to say about them.  They have a lot of inputs/outputs that can be configured any way you want.  Andy is the MLVHD facebook admin and has been dealing with club racer tunes and hardware for years.  I like that he's always looking for deals and using OEM parts for sensors rather than the $$$ branded versions.
    Cary
