tube80z
Super Moderators
  • Content count
    1189
  • Donations
    25.00 USD
  • Feedback
    0%
tube80z last won the day on October 16
tube80z had the most liked content!
Community Reputation
18 Good
About tube80z
  • Rank
    Super Moderator
  • Birthday 11/04/1966
Contact Methods
  • Website URL
    none
  • Gender
    Not Telling
  • Location
    Rickreall, Oregon
Recent Profile Visitors
Enable
  1. I'm probably just piling on info you already looked at but did you see these, (https://www.hotrod.com/articles/venting-to-cure-crankshaft-pressure/, https://www.yellowbullet.com/forum/showthread.php?t=609182&page=5)? Is that how you plumbed things? I saw a number of people claiming on road race LS motors you need half inch (-8 AN) or larger lines to deal with the problem. Before I did any of this I'd make sure you don't have excessive blowby/leakdown from a broken ring. I should add that all this disappeared when we dry sumped Kipperman's engine. His locost that had a wet sump LS2 had some vented breathers that ran to a catch can and it was always having some oil mist come out. If you do want to think more about the dry sump I did my complete system using NASCAR take off parts for around $1300. Cary
  2. There's been a lot of good replies to your question of how to build your car. I wanted to share some hindsight from a number of projects I've been involved with over the years. In the end you'll decide if any of this is useful or not. 1. One of the toughest decisions you'll be faced with is do you want a street car that can tracked or a track car that's street legal. Those may sound like the same thing but they are from from it. The first involves adding performance using the Z chassis for the most part similar to the Green Hornet mentioned above. The latter is much more like building a chassis and dropping the Z body onto it. This gets you more to a car like the Fairlady Z06 mentioned above. This also determines if you start with a solid chassis or you use one that's nothing more than the roof and doors. 2. Research, research, research. I'm not trying to be funny but you need to have the entire build plan figured out before you start. Then create a checklist and start crossing of items. This research and list will help you build a budget for the car. It may end up being a lot more expensive than you imagine (nothing wrong there) and you may never want an SO to see this spreadsheet. But if you've done your research and stick to your plan you won't but parts two or three times to get the right item. It will also keep you from having to figure certain things out along the way, which really adds up time wise. And lastly it will keep you from having scope creep. The latter can be a real killer of projects. 3. Determine/buy the drivetrain parts last. This is engine, transmission, wheels & tires, etc. If your project takes more than a year to build it's often possible better items will come along or prices in scrap yards will get better. The only time I'd say you can break this rule is if you have determined their is a specific drivetrain you're going to use and it's not going to get any cheaper and in fact may be harder to get later on down the road (L28ET for instance). 4. For the things you can't do find a good professional that can help you. While it's often tempting to use a buddies buddy or someone doing this from their home I've seen a lot of projects get stalled this way. This is generally around body and pain but could also be around having a roll cage built. For any vendors you plan to use take a look around to make sure they have a good track record. I wish you luck and good fortune on building your car. In the end there's nothing better than something you built yourself, well at least to me. Cary
  3. I'd recommend Susprog3D. It's nothing fancy but gives you all you need to solve the DIY pick-a-part suspension designs. That's what I'm using to see if we can figure out a simple approach to reduce scrub on Jon's car. Cary
  4. tube80z
    V10 240Z build on YouTube
    This won't be no project Blinky, that much is for sure.
  5. That's a really good thread to read through even if you don't decide to go into that depth of detail. It will help make you a much better purchaser of suspension and help with what to ask for. Inverted monotubes are nothing special really. They are just an upside down shock and what looks like the large rod in the top of the strut is really the insert body. Bilstein or a good example of this. They are often used/hacked to create one off setups. There are a number of good threads around using them as a base. Hope that helps, Cary
  6. Since this is a racing car you should really not be thinking about some off the shelf solution. I would either work with someone who can help you pick a setup for your car based on sprung/unsprung weights and the available grip you expect to have or go through the exercise of calculating that yourself. I would look very hard at inverted monotube designs as they have a much larger shaft to bushing ratio that helps with not only how long things will last but the amount of compliance that you'll see in cornering. You may want to check the rules you race under to see if there are any issues you might run into on that front. Don't get in a rush and end up buying the same thing twice. A little work/research up front will help you save dollars in the long run. Cary
  7. tube80z
    Tim's 302Z
    One thing I might suggest. If you look at a new car and compare the chassis to the Z you'll find a connection from the rocker to the frame well in the front wheel well. This is the same area that saw a lot of work in the B&W pictures you linked to previously. And on our race cars we often put tubing into the rockers to make the floor stronger. At the front wheel end this was connected to the TC box. Very similar to some of the photos you have shared. Props to all the work to save this one. At some point these cars will be rare enough this will be commonplace. I'm glad I live where they don't salt roads. Hope this helps, Cary
  8. tube80z
    aviation fuel mix with gasoline?
    Did you notice this is a ten year old thread?
  9. That could easily be solved with using an oversize bung and adjuster added so you can change length on the car. I never bothered with my set as they were made in a jig matched to the arms that came off the car.
  10. Rather than weld the mustache bar to the drop links you can make a new setup that's one piece and bolts in. Here's some pics of what I'd do for the inner frame. While this does use a mustache bar I'd replace that with tubing that connected to the uprights out to the mustache bar outer mounts. Then some simple triangulation would make it very stiff. Rather than use the H style control arm I'd move to one of the toe-link style arms that have been built by a number of people. In case you're curious these are the rear suspension pics from John Thomas' national championship winning FP car. Hope you find them inspirational, Cary
  11. tube80z
    240Z Pro-Touring Build
    My advice, from screwing up this a number of times, is to get the engine and tranny last. You never know how long it will take to complete these projects and what looked awesome now may be a lot less awesome in years to come. Not to mention potentially cheaper. Cary
  12. A friend who runs a EP car used the CFR 4 bolt variety and there wasn't any problem. They broke one too and then changed to the CFR part. I put one of them in and they looked nice and used good hardware for the studs. Cary
  13. tube80z
    ABS in a 240Z?
    Sounds like you're well down the road with the Teves unit then. I'll be curious to see how that works with slicks. I was going to suggest another option is the Ford FR500 unit that is programmed for slicks. Install is very similar but Ford motorsport has a much cheaper harness option. Cary
  14. tube80z
    Base model 280zx project
    Yeah, photobucket seems to have screwed almost all the car threads and other forums I view. It's understandable but it would have been nice if there was an easy way to migrate but then they couldn't hold people's pictures hostage.
  15. tube80z
    Pikes Peaks 2016
    I know we all like to fly the Z flag but if you do have to start over a newer platform could be a better move. Not only suspension is better but you get a stiffer chassis often and much better aero. Sure you can get there with a Z but you're going to need to do a lot of work rebuilding much of the car. So my vote from a racing results standpoint would be to look at some other platforms. Cary
