dpuma8
About dpuma8
  • Birthday 10/26/1977
  • Gender
    Male
  • Location
    Yuba City, CA
  • Interests
    1975 Datsun 280Z L28ET
    550cc injectors, MS2, Aeromotive A1000, Carter P4070, Bosch 044, GT3076r .63
Recent Profile Visitors
6601 profile views
dpuma8's Achievements
Newbie
0
  1. Hey dude, did you ever get your EZ Wiring to work in your car? I'm in the process of doing the same.
  2. A lot of what I read is getting the maps to be fairly smooth so I have been autotuning to get near AFR goals but then I will manually smooth cells out. The problem I am having is my AFRs will vary 1 AFR when cruising. Obviously, the goal is to give the car what the car wants but what is more important when tuning is pretty close? Smoothing the tables and ignoring AFR swings as long as the engine will not be harmed? Or is hitting AFRs goals the best way to go? CurrentTune.msq 2019-11-13_07.48.07.msl
  3. Get a running car with no rust. As mentioned above, upgrade everything else and do the engine last. My first Z sat for 4 years in the garage because I tried to upgrade everything at the same time including the engine
  4. My 105 amp alternator is a 1 wire setup. Is there a general safe advance map for an L28et? I see some of the maps in the Megasquirt map sharing section of hybridz but I am not sure if any of them are safe or not. My voltage issues are better after rearranging things but not perfect. Now MS will read 12V at idle, increase to 14.2V while drivinjg with some moments where it drops to 12 again before raising up to 14.
  5. I used this diagram from 5thgenluder's 2010 build and it helped a lot. I do remember brakes being a problem and I think I just took one brake wire that came from the EZ fuse and routed it to the brake switch, took another non EZ wire and connected it to the other brake switch prong, routed it back to the brake lights. EZwiring Diagram 3.pdf
  6. Not sure why my voltage is so low and I am not sure where to start looking. I have a Z Specialties 105 amp alternator that needed to be rebuilt for bad bearings after not too much use. I don't have any extra accessories like a radio or anything like that. My car is wired with EZ wiring harness. My boost flutter issue has been fixed by rearranging my vacuum lines. My MAP sensor was hooked up to the #5 intake leg so I moved it to the port between #3 and #4. I still have an issue though where it feels really flat once I get over 4500 rpms so I can't tell if this is because my P90 cam is losing steam, my ignition timing needs more advancing, or because I have spark blowout. 2019-08-07_20.57.25.msl CurrentTune.msq
  7. Just an update. I smoothed out the tune a lot and now I can rev it without any issues like I had before. My problem now is fluctuating boost at WOT. My logs show boost is erratic up to 12psi meaning that it rapidly goes up and down 3 psi until I get to 12 psi near 6,000 rpms. Above 4500 rpms, the car sound slouder but doesn't feel much faster. My voltage is in the 12's and will drop to high 11's at higher rpms. So possibly a spark blowout? I am using an All-Star 81230 coil, magnecor wires, Tial MVS wastegate with 10psi springs, NXS manual boost controller, Greddy BOV on the hot side. The MBC and BOV share a vacuum line connected to the intake manifold.
  8. I have an L28et with GT3076r turbo and Megasquirt 2 3.57 with NGK R BPR6EY plugs that were gapped at .03. With this gap, I could not rev past 3200 rpms but after gapping the plugs down to .025, I now can rev my car to 4200 rpms before it happens again. Do I need new plugs or do I keep closing the gap on my spark plug? What is the smallest gap I can run? and I had problems with revving past 3200 rpms. I changed the gap to .025 and I can now rev to 4300rpms before I run into the revving wall.
  9. Awesome! Thanks for the link! So it looks like for me and the stock 280zx turbo distributor, the only change is I don't have to add a resistor on the B/W wire.
  10. Hi everyone, I had my L28et with Megasquirt II 3.57 for a while but I had problems with revving above 4,000 rpms and bad TPS noise. I ripped all the wiring out in October 2018 to redo my wiring routing to hopefully cut down on the noise. I am back at it again but I am wondering about the 280zx turbo dizzy wiring diagram we see on the internet from 20 years ago. Is this still the way to wire the distributor? If not, how should I wire it?
  11. I bought a 3000 CFM electric fan from eBay years ago for maybe $30 and it really helps sitting in 110 degree weather at a stoplight. I do not have a shroud either so maybe your fans are not strong enough or there isn't enough electrical power to really power them up? When mine come on, you can really hear them and the engine cools down pretty fast. Years ago I changed the radiator to my Nissan Maxima and I immediately had a problem with overheating so the fix was to let the car idle with the cap off to get the bubbles out. The radiator fluid would burp a little and then I would just add more fluid. Just an idea.
  12. How much did it cost you and what shop did you go to? Just wondering since I am 30 minutes away from the Sacramento area.
  13. My rear tire blew out so while the car was being towed backwards, the sunroof glass blew off so I am in need of a replacement. I am hoping to get a direct replacement rather than having to completely recut the hole for a new kit so I was wondering if there was a general kit or size that was installed back in the 70's. I know dealerships and not Datsun did these modifications but I still was hoping for an easy way to deal with this. When measuring the hole where the glass would have sit, I came out with measurements of 14 1/8" by 29 1/8". Is there a kit for this?
  14. Been busy with my kids' sports and family visiting but here is at least a picture of my setup. This all is mounted in stock location. The feed hoses are 3/8" and the outside return lines are 5/16". Removed both G3 filters.
  15. Hi guys, Let me clarify my situation better and what I am running. L28et with GT3076r, MS2 with relay board, RC Engineering 550cc injectors with inline resistors, and Aeromotive Fuel Pressure regulator. My fuel system is Tank>>Fram G3 fuel filter>>Carter Fuel Pump (wired to my EZ Wiring kit, no relay, 14 gauge wire)>>External Surge Tank with submerged Bosch 044 (Wired to the MS Relay Board)>> Engine>> External Surge Tank>> Tank. I set fuel pressure to be 36psi with the aeromotive FPR vacuum line off, reattached the vacuum line to the FPR, and then drove around to tune with Chickenman's tuning start points. I will drive around for an hour, turn the car off for 30 minutes, restart it, and then struggle home with fuel pressure at 10 psi. I am now adding a Bosch relay to my car and hooking the Bosch 044 directly to that rather than going through the MS relay board. The Bosch 044 was wired to the relay board with smaller gauge wire and the fuses did not pop. Since I have had the car in the garage for some time, the battery might be low so I will charge it tonight. My Bosch 044 came with a check valve but I did not install it with the pump.
