Update...I did end up changing my fuel pump shortly after I bought the car. I have now finally got a chance to get my hands back on this thing and work on it. I bought a good, rebuilt distributor for the engine a while ago because last I noticed the wiring for the distributor had been chewed in half. I just got done installing the replacement distributor today and the engine still will not start. I have confirmed that the fuel pump is working and pumping fuel up to the fuel filter and out into the rubber supply line going to the metal line that feeds the injectors. With the solenoid disconnected at the starter and turning the key to start you can hear the pump run. I can hold the key in this position for one whole minute and the pump runs that whole minute. Are the injectors supposed to make a clicking noise when you unplug and then plug them back in? I am getting no sound...and with cranking the engine as much as I have I know I have air. Pulled #1 spark plug out of the head, plugged the wire back in, and checked for spark against the valve cover. I had it while cranking, so I have spark, air, and what I believe to be fuel. What could be the problem here? Thanks for any help.
