Go Back   HybridZ > Technical > 6 Cylinder Z Forums > Toyota L6 Forum
Reply
Thread Tools Display Modes
Old September 24th, 2009, 09:15 PM   #261
ShaggyZ
Terminator
ShaggyZ's Avatar
ShaggyZ is on a distinguished road
Default
Check it anyway. I've messed with some L28's that idled fantastic - or so it seemed - and then I found out the plug wires were incorrectly connected.
__________________
'77 280Z 2JZ-GTE in Progresso
'03 SV650S
ShaggyZ is offline   Reply With Quote
Old September 24th, 2009, 10:19 PM   #262
ARZ_
Member
ARZ_'s Avatar
ARZ_ is on a distinguished road
Default
Quote:
Originally Posted by mike321go View Post
i dont think so...when its warm it idols extremely smooth with no hicups or anything.
Don't "think so." KNOW SO!!! Check don't guess.
Quote:
I agree 100% that's why I mentioned it. When idling, an inline 6 has an amazing capacity for improper spark timing. You would be very surprised at how smooth your L motor idles if you swap 2 and 4. Don't believe me, TRY IT!
PLUS!!! you did not answer my question.
Did you do WOT in the video or were you easing into the throttle?
1. Dont answer all the questions.
2. Dont bother checking (for sure) the problems that people that have already done what you are doing.
3. Give extremely short responses, with no conclusion.
4. And make sure "all involved" know your not going to check that "cause you already did that when you installed it."
This is the quickest way NOT to get help.
__________________
1971 240Z 7MGTE 60-1 powered, 2505 lbs, 487 rwhp 473 torque @ 23 psi, 11.7 @ 125, it was my first and only time, they kicked me out. Build thread
1970 240Z 2JZGTE T76 powered sub 2100 lbs (Street legal track car in work=collecting parts)
ARZ_ is offline   Reply With Quote
Old September 26th, 2009, 12:29 PM   #263
mike321go
Member
mike321go's Avatar
mike321go is on a distinguished road
Default
In order to wire the coils backwards i would have to cut up my wiring harness and move the plugs around. the wiring harness on a 2jz is form fitted to the coils so plugging them in wrong is virtually impossible. As for the WOT question...no i was not WOT i was about 15% throttle.
mike321go is offline   Reply With Quote
Old September 26th, 2009, 01:46 PM   #264
stony
RB Moderator
stony's Avatar
stony is an unknown quantity at this point
Default
There should be an area in the computer that you set your firing order that's what I think we are talking about. If you know it's right then not sure what to tell you
__________________
Unnatural Aspiration....turbo lag was invented to give V-8s a chance
RB26DETT, T88-34D, 30 PSI, full tune JUN head, 280 Cams W/ 10.30 lift, 1.2mm cometic Metal head gasket, custom intercooler, HKS Fcon V Pro engine management, 2 speed powerglide, Fully built Dana rearend, Ladder bar suspension,
Best 1/4 to date 9.10 @ 147mph
4 link car in the chassis shop now more updates soon
http://smg.photobucket.com/albums/v2...ompilation.flv
stony is offline   Reply With Quote
Old September 26th, 2009, 04:24 PM   #265
garvice
HybridZ Supporter
garvice is on a distinguished road
Default
Can the AEM test outputs?
I can test all my Motecs outputs. I.E. I can tell which cylinder is firing/injecting without starting the car. Very good for double checking your wiring before you fire the car up for the first time.
You also said that you couldn't have wired it wrong because the loom is fitted to the coils, but didn't you splice in an AEM Loom? Couldn't you have spliced the wrong cylinder wires in?
If your computer doesn't support the testing of outputs, then remove your crank angle sensor (or get a second one) and spin it by hand while watching the spark plugs fire.
garvice is offline   Reply With Quote
Old September 26th, 2009, 04:55 PM   #266
garvice
HybridZ Supporter
Default
Or do a continuity test from ECU output plug to coil plug to determine which output is which.
Old September 27th, 2009, 03:11 PM   #267
mike321go
Member
mike321go's Avatar
Default
the aem system is plug and play so the only things i had to splice in were a map sensor and a air temp sensor
Old September 27th, 2009, 08:18 PM   #268
Scottie-GNZ
HybridZ Supporter
Scottie-GNZ is on a distinguished road
Default
What crank sensor are you using? I tried using the OEM crank sensor with TEC II and it failed miserably with similar symptoms. If you are not using the OEM setup, make sure the air gap is correct for the diameter of the trigger wheel. Since you are having RPM-related issues, that is where I would put the focus.
garvice is on the right track but I would go one step further and have someone put a scope on the crank sensor circuit.
__________________
Scottie
'87 RX7 / 2JZ Power - 9.51 @ 146.16
71 240Z / GN-powered
'84 911 Carrera Cabriolet
'97 E36 M3 Coupe/5-spd
'98 Sonoma Stepside - LM4 powered
Scottie-GNZ is offline   Reply With Quote
Old September 27th, 2009, 10:27 PM   #269
mike321go
Member
mike321go's Avatar
Default
there is another option then an oem crank sensor? all my sensors are stock with stock wiring harness..... Ya i think a scope is a good idea..at this point i have to bring it to a seriously skilled mechanic any suggestions around here??? im just north of san Francisco california.
Old September 28th, 2009, 11:28 AM   #270
Scottie-GNZ
HybridZ Supporter
Default
Not familiar enough with the AEM to tell you. The TEC II comes with a magnetic pickup that can be used with various diameter trigger wheels. Electromotive advertised a mod that could be done to the OEM trigger wheel to use the OEM pickup but it did not work. Engine would fire up and idle fine but break up badly as RPMs increased. Went to a 7" external trigger wheel and ran fine. You could have a bad OEM pickup and trying another should be easy.
I would go to supraforums and see who has a great rep for working with AEM, contact that person offline, and see if they can help. Start off by offering to pay for the service and see where it goes from there. You do not want to get into an open forum technical discussion there like you can do here.
__________________
Scottie
Old September 28th, 2009, 08:21 PM   #271
Vette Powered
Member
Vette Powered's Avatar
Vette Powered is on a distinguished road
Default
I have a SC300 with a AEM standalone setup. I'm a long ways from you but I know the guys a Boost Logic. They built my SC. Anyway, if you would like to call them and talk a bit they will be a huge help. They are very well known and advertise on the Supra/Lexus Forums. Let them know you talked to Tad and I said they might be helpful. Just tell them I have the white Lexus.
http://www.boostlogic.com/
Vette Powered is offline   Reply With Quote
Old September 28th, 2009, 08:59 PM   #272
garvice
HybridZ Supporter
Default
Do you still have the factory computer?
Could you plug that in and see if it still revs (I know your engine is a lot different then stock, but it should still rev past 2500rpm with the factory one). That will eliminate the computer or sensors.
Old September 28th, 2009, 09:02 PM   #273
stony
RB Moderator
stony's Avatar
Default
Not with 1000cc injectors installed.
__________________
Old September 28th, 2009, 09:07 PM   #274
garvice
HybridZ Supporter
Default
Good point, I retract my previous statement.
Old September 29th, 2009, 09:04 AM   #275
mike321go
Member
mike321go's Avatar
Default
today hopefully im going to try a buddys supra aem box and see what happons
Old September 30th, 2009, 08:03 AM   #276
Meph
Member
Meph is on a distinguished road
Default
Im running a 1jz on the stock 12 tooth trigger wheel with my Haltech system and it seems to be working fine, so I think it would all be fine. Try a second ecu, thats how i cured my 2 month no-start issue
__________________
Meph is offline   Reply With Quote
Old September 30th, 2009, 10:21 AM   #277
mike321go
Member
mike321go's Avatar
Default
Yesterday i was able to barrow a friend of mines supra aem ems. Plugged it into my car..did not change anything...and it revved to over 3500 rpms then started limiting...so at this point im almost positive its just tuning!!!!!!!!
Old September 30th, 2009, 10:22 AM   #278
mike321go
Member
mike321go's Avatar
Default
Old September 30th, 2009, 05:11 PM   #279
stony
RB Moderator
stony's Avatar
Default
Christ go pay 300 bux and get it on a dyno!!!! and be done with it.
__________________
Old October 1st, 2009, 09:21 AM   #280
mike321go
Member
mike321go's Avatar
Default
LOL STONY..... out here 300 bucks is prob 3 hours of dyno time and then you have to pay the tuner 100 bucks an hour on top of that
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Won't Start RockyB12 Nissan V6 Forum 9 December 19th, 2006 05:24 PM
Car wont start! Ran fine, now not so fine...HELP PLEASE! george.bryant Nissan L6 Forum 6 November 15th, 2006 10:16 AM
Sell and start over, keep and start over, keep and start another project. ON3GO Non Tech Board 12 February 28th, 2006 07:56 AM
STILL hard to start - getting interesting E.Murray Gen I & II Chevy V8 Tech Board 14 May 14th, 2005 03:49 AM
can't get the motor to start (the fun begins, stock 73' Z) 73Turbo240z 6 Cylinder Z Forums 0 January 13th, 2005 12:43 AM
Powered by vBulletin® Version 3.8.1
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
