Go Back   HybridZ > Technical > Brakes, Wheels, Suspension and Chassis
Brakes, Wheels, Suspension and Chassis Discussions of technical related subjects pertaining to performance suspension, wheels, brakes and chassis.
Reply
Thread Tools Display Modes
Old March 30th, 2005, 12:25 PM   #1
JAMIE T
Posts: n/a
Default Basic Strut vs. Shock question
What is the differance between a strut and a shock? Also inlude Coilover Shocks. Coilover shocks support the complete weight of a car as does a strut some times right? What conditions must be present to need one or the other?
Or, would a coilover shock be interchangable with a coilover strut given the right mounts are added?
Old March 30th, 2005, 02:11 PM   #2
JMortensen
HybridZ Supporter
JMortensen's Avatar
JMortensen has a spectacular aura aboutJMortensen has a spectacular aura aboutJMortensen has a spectacular aura about
Default
A strut bears load. A shock does not. So in a Z for example, you can't remove the struts and set the car on the ground. In a pickup truck you can remove the shock and it set the truck down with no problems.
As to the second part of your question I think the answer is yes. In a 510 for example you have rear shocks, but some people use a strut that incorporates the spring, like the back of a 280ZX and then remove the separate spring, basically converting it from shock to strut.
__________________
Jon Mortensen www.m2differentials.com
No, we don't have any Z differential parts (yet). We have gears, lockers, limited slips, axles, etc for most American vehicles.
JMortensen is offline   Reply With Quote
Old March 30th, 2005, 02:41 PM   #3
johnc
Administrator
johnc's Avatar
johnc is a splendid one to beholdjohnc is a splendid one to beholdjohnc is a splendid one to beholdjohnc is a splendid one to beholdjohnc is a splendid one to beholdjohnc is a splendid one to behold
Default
A strut is an upper suspension locating member that is typically a vertically oriented metal tube that is connected to the hub.
A shock is a hydraulic device the dampens the motions of the suspension springs.
On a McPhereson and Chapman Strut suspension the strut has a coil spring located around it and the spring sits on a lower spring perch attached to the strut. In addition, a shock is installed inside the hollow tube of the strut with the shock body clamped in the tube and the shock shaft is attached to the vehicle body at the upper spring perch.
__________________
John Coffey
johnc@betamotorsports.com
BetaMotorsports, LLC
Once more unto the breach, dear friends, once more,
Or close the wall up with our HybridZ dead!
In deciding for those who cannot decide,
Or educating those who will not listen,
There's nothing so becomes a man
As modest stillness and humility;
But when the blast of indecision and ignorance blows in our ears,
Then imitate the action of the tiger:
Stiffen the sinews, summon up the blood...
...Follow your spirit, and upon this charge, Cry "God for HybridZ, Datsun, and Horsepower!"
johnc is offline   Reply With Quote
Old March 30th, 2005, 03:52 PM   #4
2126
Member
2126 will become famous soon enough2126 will become famous soon enough
Default
Jamie T,
To add to John's post.....a McPhereson strut is used in a steering application (front suspension) and a Champman strut is used in a non-steering application (rear suspension).
2126 is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Strut insulator question? deMideon Brakes, Wheels, Suspension and Chassis 14 June 29th, 2006 02:01 PM
Rear Strut on Hatch Question RedNeckZ Body Kits & Paint 1 December 14th, 2004 10:22 PM
another strut question... help fast! ON3GO Brakes, Wheels, Suspension and Chassis 3 September 7th, 2003 11:46 AM
Tokico shock set-up question John Greenslade Brakes, Wheels, Suspension and Chassis 4 November 19th, 2002 05:15 PM
Another shortned strut question 75Turbo Brakes, Wheels, Suspension and Chassis 1 April 12th, 2002 01:12 AM
Powered by vBulletin® Version 3.8.1
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
