#41 | |
Posts: n/a
Quote:
Why even bother using 2 TB's on 3 runners?? Why not just a single big one? It would be the least amount of work. Isk |
#42 |
Member
![]() Join Date: Jul 2003
The angles and lengths on the runners to get 3 into 1 throttle body would suck allot and wouldnt be that efficient, plus I dont know if a bike's diameter throttle body would be big enough. Whats wrong with buying 2 sets of ITBs and using 6?
__________________
#43 | |
Member
![]() Join Date: Nov 2004
Quote:
Tyson |
#44 | |
Administrator
Quote:
__________________
John Coffey johnc@betamotorsports.com BetaMotorsports, LLC Once more unto the breach, dear friends, once more, Or close the wall up with our HybridZ dead! In deciding for those who cannot decide, Or educating those who will not listen, There's nothing so becomes a man As modest stillness and humility; But when the blast of indecision and ignorance blows in our ears, Then imitate the action of the tiger: Stiffen the sinews, summon up the blood... ...Follow your spirit, and upon this charge, Cry "God for HybridZ, Datsun, and Horsepower!" |
#45 |
Administrator
__________________
#46 | |
Member
Quote:
Tyson |
#47 |
Posts: n/a
Here's my idea on DIY - ITBs ...
Using 6 small Honda D-series [D15 used in most Civics] throttle bodies, mounted cleverly, and with an ingenious throttle actuation design, could prove quite gainful. The manifold itself would be designed around this TB setup idea. Now, for the most descriptive way to relay this idea to you ... pictures. ![]() ![]() Like it said in the first image, there will be a balance tube, which will most likely also house the MAP sensor to accurately monitor incoming air, unless I end up running an AFM or MAF setup [unlikely]. Also, the balance tube setup could be used as a vacuum source for power-assisted braking systems, or anything else that needs vacuum. By pulling on the throttle linkage, all 6 TBs will open at the same time [the use of threaded shafts, knuckles and joints would be used for adjustability]. I'm actually not sure which direction Honda TBs open, so this is a VERY RUDIMENTARY sketch of how it will work. If they open opposite of the above, the setup will be reversed, so still pulling the throttle to the left [in the pics] will open the TBs. I hope that made sense. So far, I don't see any inherent flaws. Let me know what you guys think. -Dave-O |
#48 |
Posts: n/a
It's been a while for me but that looks/sounds like what I was planning on. On thing I noticed in your posts is that you mentioned that you would be using an E31, E31's won't accept a N47 manifold W/ Injectors. You will need to use a FI head or do something about the injectors.
Why not use the injectors off the bike? I know on some of the newer CBR's they have some bad a$$ injection setups. What is the size of the TB's? Oh, I see they are 54mm. That's BIG. Is that right? I would think 54mm on even a 3.1 would be too much. But on a SBC!!! Isk |
#49 |
HybridZ Supporter
![]() ![]() Join Date: Dec 2004
Or you guys could always buy one of my units
#50 |
HybridZ Supporter
My system uses a Pot type 240sx TPS. My system also uses STOCK lingkage, so you can use your stock linkage bar, so NO modifying. ALL directy bolt on mechanicly anyways. This system has to be used with a MAP style based ECU, ie. Megasquirt, SDS, etc. TB's are 46mm, which will flow ALOT more than a DCOE 45, as there are no chokes
#51 |
Junior Member
does anyony have any sound clips, would love to hear what it sounds like,
__________________
Save the 2+2. |
#52 |
Member
![]() Join Date: Jul 2005
hey guys i thought you guys would wanna hear what ITBs sound like on a 4cylinder.
http://videos.streetfire.net/Player....AD7020C61A&p=0 this is Pacman from www.honda-tech.com he sounds like a dumbass but he knows his stuff... |
#53 | |
Member
Quote:
#54 |
HybridZ Supporter
For everything, IE. Air Cleaners, Velocity stacks, etc. DIRECT MECHANICAL bolt on, is about 1600.00. Price does vary with Runner size, etc.
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| gsxr throttle bodies on a v8 | peej410 | Gen I & II Chevy V8 Tech Board | 21 | November 8th, 2006 04:07 PM |
| Individual Throttle Bodies vs. one HUGE one | xero | Miscellaneous Tech | 16 | November 10th, 2003 08:19 PM |
| Weber DCOE throttle bodies | QuasiMondo | Fuel Delivery | 16 | July 14th, 2003 10:25 PM |
| Try these individual throttle bodies! | Tim78zt | Fuel Delivery | 0 | April 2nd, 2003 11:49 AM |
| TWM's individual throttle bodies | D83ZXT | Miscellaneous Tech | 0 | September 1st, 2002 10:39 PM |
