#1 |
Junior Member
![]() Join Date: Oct 2005
I keep hearing everytime a someone brings up swapping in a VG30DETT into a Z31 "the VG30ET and VG30DETT are basically the same in performance so you might as well stay with the VG30ET" or something in the lines of that. Whomever supports this statement, can you please back it up? What will make the VG30ET "Just like" a DETT? Are we talking about NOS here? If we are then lets end this. NOS, in my opinion, is in its own category. We can blow up all kinds of engines but we dont call em' Ferrari's. So far, I have searched and searched and found that the most an ET can kick out is 243HP(generous estimate) with lost and lots of mechanical upgrades and work and sets us back around $3grand(Parts and labor). Is there ANY thing else that can make the ET 300HP so that it can MATCH the DETT stock 300HP? Hopefuly this can turn into a comprehensive thread. Anyone here have a 300HP+ VG30ET (NO NOS)? Write ups? Links? Pictures? |
#2 |
Posts: n/a
this is my bone stock VG30ET with 260K miles on it, and valvetrain issues. At 10PSI it made 307RWHP, 383RWHP at 18PSI and VERY conservative timing. Nothing has been touched, the engine was pulled out of a junk car and stuck in my car after my flywheel blew up taking out my good engine. The only modifications are a larger turbo, intercooler, maf and 420cc injectors.
http://www.redz31.com/images/dyno/jason84na2tdynosm.JPG The BIGGEST (and main) advantage to the DETT is the fact that it comes with better electronics from the getgo, like a maf that meters 480hp (instead of 300) or 370cc injectors (instead of 259cc) or intercoolers (instead of none), or an awesome fuel pump (instead of one that can barely do 300whp). As for your question: "What will make the VG30ET "Just like" a DETT". The above, reground cams and a really good port job combined with a good valve grind will make ET heads flow almost as well as stock DETT heads. The ET will always have a torque advantage, but the DETT will always have a flow (and hence horsepower) advantage. With all those points fixed, the VG30ET can almost perform on par with the VG30DETT, but loses out in maximum HP because the DETT heads simply flow that much better. Both of the engines have stout bottom ends with pistons that fail about the same point (before 500ish whp). IMO the DETT is over-hyped, the ET gives you a MUCH better bang/buck overall. Not to mention the ET was used in the Electramotive IMSA GTP cars making 800-1000HP on stock blocks (until they cracked) and stock (though modified) heads. Last edited by Jason84NA-T; October 5th, 2005 at 02:27 PM. |
#3 |
Junior Member
Thank you so Much.
You know whats funny? I always count on you and your website. You give the best replies, your not immature and I always end up referencing your site. Weird. Ok, that sounded weird Anyways Yeah for reals, I'm going to start an NA->Turbo project soon. My N/A wont last more than a year the way it is so I'm going to do it as I rebuild. I'm planning to pull a turbo engine from the junk yard. Any tips on signs to stay away from would be helpful. |
#4 |
Member
![]() Join Date: May 2000
Nothing wrong with a vg30et.
Intercool it, add a boost controller, add an adj fpr, and run a 3" exhaust, and bingo 300hp is there! Want more? Upgrade the fuel pump (on z31's), add a larger turbo, add larger injectors, and an ecu to handle them, and wala 400hp is easily attainable. Want more? Port/polish heads, polish/balance, nitride, shotpeen rods and crank, get some forged pistons, make sure she is mechanically perfect, crank the boost and try and shoot for 800hp! Or use the vg30dett, and brag that you have a vg30dett! other than that, its all good!
__________________
![]() If BOOST could be addictive I'd be in trouble.....uh oh.. 1978 280Z VG30ET Intercooled T3/T4, MS&S, 300RWHP 350ft/lbs OZC Member #002 |
#5 |
Member
![]() Join Date: Jul 2005
I hit 390hp and 440 ft-lbs in my z31 at just under 20psi.
Kept blowing the HG in the same place if you ran more than 18psi for long, though. I never got around to putting the new heads (as opposed to the current spare heads that weren't resurfaced) on to see if I could get 400hp. Sold it, sadly. Loved that engine. So easy to work on. Tryin to get my hands on an s30 shell... |
#6 |
Member
![]() Join Date: Jan 2004
Man its too bad it's so hard to fit one into an s30. Do you suppose a 480rwhp vg30det swap in an s30 would be cheaper than an RB25/26 with the same power?
__________________
73 240z 3.1L Turbo Stroker Forged Arias Total Seal Rings TS04/T58 HPI FMIC Greddy Type R bov HKS Ext. WG Haltech E6X RC500cc inj P90 Full P'N'P ARP studs HKS1mm hg 75 intake 240sxTB Cust surge tank JSK Fuel Rail Aeromotive fpr Walbro GSL 392 280zx 5spd 3in. turbo back exhaust , ACT 6 puck |
#7 |
Ludicrous speed, GO!
![]() ![]() Join Date: Feb 2001
1sickZ has made 651rwhp with his Z31.
__________________
71 240z 2JZGTE TH400, 76mm turbo, 3.36 R200 rearend - 8.915 @ 153.60 TechnoToyTuning 2.94 geared R230 rearend - 9.038 @ 152.14 (so far) http://album.hybridz.org/showgallery...00&ppuser=7981 http://videos.streetfire.net/video/a...e90005d70d.htm 02 IS300 Sportcross (daily) 07 Solar Orange 350Z Roadster (wife's car) 03 Ford Excursio-saurus 4x4 Diesel A really bad want is a justifiable need ... |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| so you wanna swap an rb eng? here ya go | stony | Nissan RB Forum | 133 | Yesterday 08:11 PM |
| Power antenna | CruxGNZ | Miscellaneous Tech | 0 | May 26th, 2003 12:50 AM |
| Need ideas for potential V-8 swap | tx84ae | Gen I & II Chevy V8 Tech Board | 3 | March 13th, 2003 01:18 PM |
| Ok, need some SERIOUS help with info concerning my swap!!! | KraZeeZX | Gen I & II Chevy V8 Tech Board | 8 | September 26th, 2002 11:51 AM |
| 75' 280z- N47 head swap Power tuning?? | LIghtningZ | 6 Cylinder Z Forums | 1 | June 28th, 2002 10:41 AM |
