| Non Tech Board Nontechnical discussions |
Thread Tools | Display Modes |
#1 |
Posts: n/a
So - are there any readily available, high revving, good sounding V8s? Sure you have the grunt of an SBC or SBF, but you're limited to what, 5-6.5K redline? If I were to go through the trouble of an engine swap I want it to sound exotic, not the run of the mill Mustang or Camaro. Give me a high output, high revvin V8 if Im going naturally aspirated. So any ideas? http://www.eisenhaus.com/video.php?v...ideo_355-1.mpg Inspiration. |
#2 |
The forum "Tease..."
![]() Join Date: Dec 2001
Vh45.
#3 |
Wanton
![]() ![]() Join Date: Jun 2003
The 3.9 V-8 found in the Lincoln LS and the new Thunderbirds is a lightweight, high-revving, decently powered V-8. I'd like to see what those are capable of.
__________________
82 280zx -- 355/t56/3.9 R200 *In Paint Jail* 1972 240zt - T4, 3.9, TEC II, etc. *Garage Queen* 1977 2+2 - ugly junker *In Paint Jail* 1975 280z - SC LQ4 370ci/t56/R230/widebody project *In Progress* 1983 280zx - L28et/T5 installed *In Paint Jail* 1976 280z - DCOE 40s/fidanza fly/3.9 R200 *Awaiting Interior Parts* Last edited by zeeboost; June 25th, 2006 at 10:26 AM. |
#4 |
Member
![]() Join Date: Feb 2004
Maybe I'm wrong but, doesn't the video clip sound like a V12? Seems that most of the exotic sounding Italian cars are V12s!
#5 | |
Member
![]() Join Date: Aug 2000
Quote:
__________________
'78Z, '83 L28ET, '86 ECCS 313 rwhp, 419 torque, 16psi, a mile high 12.86 @ 110.5 '83 Benz 240D turbo, 100% vegetable powered
#6 |
Member
![]() Join Date: Sep 2004
There are two ways an engine can make sound, thru exhaust and intake. When most people think the exhaust is totally responsible for the sound, in fact, the intake were a major part of the equation. The exotic engines have an intake that is acoustic engineered to give a certain characteristics. It's part of the marketing really. Some Porsche sportscars and some domestic truck have their intakes acoustically(?) engineered to give their distictive noises. So the real sound maker is not just the cylinders, but intake AND exhaust.
About flat plane crankshaft/cross plane crankshaft....cross plane crankshaft have two(out of eight) exhaust pulses unevenly spaced periodically while the flat plane crankshaft give evenly spaced exhaust pulses. The overlap exhaust is what gives the "American V8" it's distinctive grumble; The evenly spaced exhaust pulses are what make the exotic engine sound like two 4 cylinder engines. If you want a special sound like that of an exotic engine, you need more than just RPM. I think some aftermarket crank makers can do flat plane, now you just need some acoustic engineering Last edited by TheNeedForZ; May 2nd, 2006 at 12:46 PM. |
#7 |
Posts: n/a
well ive driven more ferraris then i can count and nothing sounds better then a 330 V12, 308GTB Comp V8, 360 F1, or my all time fav F40...
The F40 sounded much like a LS1 on boost does but more high pitched.. plus it just was fricken loud! closest i ever heard to a ferrari engine for a cheap price was a well built. lightened, tripple weber carbed L28 mike |
#8 | |
Member
![]() Join Date: Aug 2002
Quote:
you can also even out the exhaust pulses by running a set of 180 degree headers, this will essentialy do the same thing to the exhaust note a flat plane crank
__________________
"you can't be lost, if you dont care where you are" Alex Lowe ![]() www.yourfavoritedriversucks.com |
#9 |
Member
![]() Join Date: Sep 2005
I think my Z has a very good sound like an exotic italian car...jus a little more rumbly. I have a header, 2.5 exhaust and a turbo muffler at the back. I really like the sound of the Z but if it could sound a little more refined that would be sweet. It definitely sounds like a beast gong down the road playing with the redline like it was a suggested slowing point rather than an exploding point...My Z has topped out the stock tach once or twice...I need a rev limiter so 8k+ doesn't happen any more.
#10 |
Member
![]() Join Date: Jun 2006
Can anyone give a straight up comparison of exhaust note with diferent systems eg;balance pipes,pipe diameter,muffler types/baffeled/h-dog/glass filled,front or rear muffler.anything but without any other changes to engine.
In Australia the cheapest(under $1000.00)option for that sound your looking for is the lexus 4L v8 not a huge capacity but a great engine. Im thinking of using one, the main drawback is converting to manual box is expensive. col |
#11 |
Member
#13 |
Member
![]() Join Date: Mar 2002
In my opinion the best sounding ferrari, or any car for that matter. F50 GT. Wait until the camera 355 gets passed by hthe f40 and then the f50 comes. http://www.youtube.com/watch?v=9k7xh...&search=f50%20
__________________
![]() ![]() Z and G |
#14 |
Posts: n/a
you can forget the 1UZ-FE from toyota a 4.o that is capable of revving to 10,000 rpm..it my favorite so i thought id share
http://videos.streetfire.net/search/...5FB0148D73.htm |
#15 |
I need a hug...
![]() Join Date: Mar 2003
Alrighty.. let me chime in..
Formula One cars and Ferrari's sound sooo amazing simply because of the tremdously small pistons and small stroke... The Ferrari F40 for example is a 2.9L V8 with a 82mm bore and a 69.50mm stroke... this rev's up to 10,000 RPM... and produces some 478 hp Formula One engines and (quote from formula one.com) "the 'power battle' of the last few years saw outputs creep back towards the 1000 bhp barrier, some teams producing more than 300 bhp / litre in 2005, the final year of 3 litre V10 engines. From 2006, the regulations require the use of 2.4 litre V8 engines, with power outputs likely to fall around 20 percent. Revving to over 19,000 RPM a modern Formula One engine will consume a phenomenal 650 litres of air every second, with race fuel consumption typically around the 75 l/100 km (4 mpg) mark. Revving at such massive speeds equates to an accelerative force on the pistons of nearly 9000 times gravity. Unsurprisingly, engine failure remains one of the most common causes of retirement in races." The old turbo formula one engines were a 1.5L V10 .. thats right 1.5 L!! For 2006, the engines must be 90° V8 of 2.4 litres maximum capacity with a 98 mm maximum circular bore, which imply a 39.7 mm minimum stroke. They have two inlet and two exhaust circular valves per cylinder, are normally-aspirated and must have a 95 kg minimum weight. Thats right .. a 39.7mm stroke.. OMG
__________________
Currently on a rotisserie for a full restoration - L28 with 9mm rods, 88mm Ross pistons (3.0L), 8.5:1 CR, Schneider Stage II cam, Holset HY35W, Megasquirt, Suzuki GSXR ITB's and home made intake plenum, Z32 transmission, Fidanza aluminum flywheel, ACT stage II clutch and pressure plate, coil-overs, vented 4x4 front brakes, 240sx rear brakes, Corbeau FX1 Pro seat, (soon to be half cage) and still debating the paint.. hurm |
#16 |
Member
the angle of seperation between the cylinders seem to make a huge diference to sound as well.A flat 4 like suburu has a much deeper note than a straight 4 . I understand that timing of the pulse is diferent but why the deeper note?
#18 |
I need a hug...
Horizontally opposed engines sound distinct because of alternate firing..
In a two-cylinder, horizontally opposed engine, the pistons are timed so that one fires on one revolution of the crankshaft and the other fires on the next revolution -- so one of the two pistons fires on every revolution of the crankshaft. This seems logical and gives the engine a balanced feeling. To create this type of engine, the crankshaft has two separate pins for the connecting rods from the pistons. The pins are 180 degrees apart from one another. this diagram is similar to the subaru firing.. this diagram is a V6 though.. but you get the idea ![]() this diagram is for a even fire motor like a Honda.. NOT a subaruso in a 4 cylinder... one pistons fires for every 180 degrees of rotation.. like your Honda Civic or a Acura Integra etc etc.... ![]() Subaru's have ODD firing.. which gives it the rumble.. similar to a Harley Davidson http://www.epi-eng.com/ET-PistonExcit.htm this page has LOTS of info reguaring engine pulses and even firing or odd firing
__________________
Currently on a rotisserie for a full restoration - L28 with 9mm rods, 88mm Ross pistons (3.0L), 8.5:1 CR, Schneider Stage II cam, Holset HY35W, Megasquirt, Suzuki GSXR ITB's and home made intake plenum, Z32 transmission, Fidanza aluminum flywheel, ACT stage II clutch and pressure plate, coil-overs, vented 4x4 front brakes, 240sx rear brakes, Corbeau FX1 Pro seat, (soon to be half cage) and still debating the paint.. hurm Last edited by PrOxLaMuS©; June 25th, 2006 at 09:31 PM. |
#19 |
Member
Thanks for info on flat 4 col
#20 |
Member
![]() Join Date: Sep 2001
I don't mean to steal this thread , but I still get goose bumps when I hear this Z06, You can just feel the high compression of that motor!
http://videos.streetfire.net/search/...CB2ED3C957.htm.
__________________
Keep the rubber side down. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| The best street engine ever built... Could be! | Drax240z | Miscellaneous Tech | 18 | Yesterday 10:47 PM |
| LS1 -GEN III Facts and specs. | plainswolf | Gen III & IV Chevy V8Z Tech Board | 18 | November 11th, 2009 07:13 PM |
| Edelbrock crate engines, newbie help pls | Russ | Gen I & II Chevy V8 Tech Board | 20 | August 7th, 2005 06:11 PM |
| High Performance Engines | hyperformanceridez | Vendor's Forum | 0 | November 23rd, 2004 06:55 PM |
| grumpy, help with finishing | woodyhooten | Gen I & II Chevy V8 Tech Board | 7 | January 8th, 2004 10:39 PM |
