| Gen I & II Chevy V8 Tech Board Discussions of technical related subjects pertaining to Chevy V8Z's |
Thread Tools | Display Modes |
#41 |
Ludicrous speed, GO!
![]() ![]() Join Date: Feb 2001
Rick Bowers (speeder) and I are having 2.93 R230 gear sets installed in our Z32tt pumpkins to get a taller gear... Kudos on your project. I am partial to yellow as well
__________________
71 240z 2JZGTE TH400, 76mm turbo, 3.36 R200 rearend - 8.915 @ 153.60 TechnoToyTuning 2.94 geared R230 rearend - 9.038 @ 152.14 (so far) http://album.hybridz.org/showgallery...00&ppuser=7981 http://videos.streetfire.net/video/a...e90005d70d.htm 02 IS300 Sportcross (daily) 07 Solar Orange 350Z Roadster (wife's car) 03 Ford Excursio-saurus 4x4 Diesel A really bad want is a justifiable need ... |
#42 |
Super Moderator
![]() ![]() Join Date: Feb 2000
Where do the 2.93 gears come from? Any chance of taller gears, say around 2.5?
#43 | |
Quote:
I remember someone posting a link to a Japanese website offering L28 racing parts and they had a 2.76 R200 ring and pinion. I think it was around $1000 for just the R&P!!
__________________
#44 | |
Member
![]() Join Date: May 2006
Quote:
Cheers, |
#45 |
Member
Welp, I figured out why the car hasn't been working that well...
![]() and ![]() As you can see, the second cam lobe is almost completely wore off and the lifter is concave, rather than flat.. This resulted in the exhaust valve not opening and causing my piston to ♥♥♥♥ the bed also.. Explains the lack of power.. Not sure what happened to the cam, but whatever... Just glad to finally figure out why it's been working so bad.. Got it all back together on the weekend.. ![]() Only about 30 kilometers on it and it's seen 10psi blasts quite frequently.. Should maybe let the piston rings seat before I beat on it too much more.. Still have much tuning to do, especially now that I have a different cam in there.. The other problem is that the car leaves two black marks behind it and smokes.. Will investigate this further... Also been working on the hood... ![]() It's not quite finished, but good enough for some primer anyways... ![]() And I guess this is the current state of things.. I had the intercooler replaced with a straight peice of pipe to make sure that the intercooler wasn't causing a pressure drop, but has since been put back in and is working well.. ![]() Anyhow, till next explosion.. Good video footage to come.. Cheers, |
#46 |
Member
![]() Join Date: Jun 2005
BEAST
the only word that i can t hink of for it is BEAST. |
#47 |
Thanks for the update.
Looks like you'll be ready just in time for the cooler weather to really take advantage of the turbos!!
__________________
#48 |
Member
![]() Join Date: Jun 2002
I think if you leave now,you can make it down to Reynolds Ga by Sept.10!
__________________
71 240z 408sbc,edelbrock proflo fi,w/p,alum heads,eagle crank,eagle rods,1.6s,6al,fuel cell,arizona z 5 lug w/wilwoods and coilovers. 10.94@122.08mph 1.61 60' 3.70LSD |
#49 | |
Super Moderator
![]() ![]() ![]() Join Date: Dec 2000
Quote:
Davy |
#50 |
Member
Welp, she's back together agian..
![]() Had it out for a couple hours yesterday just poking around.. Running at around 6lbs of boost and it is working well.. Hasn't see full throttle yet as I'm still breaking the bottom end in, but at half pedal and 6lbs it spins a lot.. Hard to gauge as the road is cold and salt covered so traction is just a pipe dream.. Everyone will be happy to know that this version has a set of forged pistons in it so hopefully I can last the summer without tearing the engine down.. Here is a pic of the new turbo vs old turbo.. ![]() Cheers, |
#51 |
170 oz, Malt liquor
![]() ![]() Join Date: Jan 2006
Nice! It looks like it got a little toasty arround the turbos, though!
__________________
1979 280ZX with '86 305 and 700R4 |
#52 |
Posts: n/a
#53 |
Member
![]() Join Date: Oct 2004
Are you able to find and install a corvette style throttle body intake?
Figured that would get your hood clearence problems down a smidge and make for an over all cleaner looking install. The cap over the carb style throttle bodies always bother me. |
#54 |
Member
Yea, at one point the timing was running really retarded, and I was unaware.. Caused the engine and exhaust to run extremely hot..
As for the intake, I have an LT1 intake setup, but don't feel like converting it over to use a distributor.. I keep a constant eye out for the Holley Stealth ram setup on ebay and other sites.. That's the end goal.. Cheers, |
#55 |
Junior Member
![]() Join Date: Jan 2007
That is one very very sick setup. I like it alot! Nice Job!
-Mike |
#56 |
A couple of turbo blankets would help the underhood temps...
Anyway, looking awesome!!
__________________
#57 |
Super Moderator
The new turbos look significantly bigger--are they hybrids too or what? I think your car will be too fast for sure
Davy |
#58 |
Member
holy cowwwwwwwww
#59 |
Compensator
![]() ![]() Join Date: Nov 2003
The entire installation looks great and I'm sure the larger turbos will temporarily satisfy. What are the specs on the new turbos?
Hanns |
#60 |
HybridZ Supporter
![]() ![]() Join Date: Apr 2000
Kudos. You have my admiration!
__________________
Scottie ![]() '87 RX7 / 2JZ Power - 9.51 @ 146.16 71 240Z / GN-powered '84 911 Carrera Cabriolet '97 E36 M3 Coupe/5-spd '98 Sonoma Stepside - LM4 powered |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Twin Turbo Setup On 240Z | dj paul | Turbo / Supercharger | 23 | May 12th, 2008 12:13 AM |
| 300zx twin turbo, turbo interchange with 81-83 turbo? | Wheeler | Turbo / Supercharger | 1 | April 28th, 2006 02:58 PM |
| Twin Turbo Kit on eBay | wheelman | Gen I & II Chevy V8 Tech Board | 9 | April 3rd, 2005 11:55 PM |
| For those of you that have seen the SBC Z32 and SBC 280ZX swaps... | Ripoff | Gen I & II Chevy V8 Tech Board | 5 | December 17th, 2004 02:30 PM |
| Anyone running a single turbo SBC or know anything about it? | Magnum Rockwilder | Gen I & II Chevy V8 Tech Board | 3 | November 9th, 2004 08:00 PM |
