| Gen III & IV Chevy V8Z Tech Board Discussions of technical related subjects pertaining to Chevy V8Z's |
Thread Tools | Display Modes |
#1 |
Member
![]() Join Date: May 2003
Thanks
__________________
Best Run with MAS280 Driving, 10.852 @ 131.98 2005 GTO LS2/T56 Engine Swap! 409.56 hp. 391.11 torque. cam 228"/230" .576"/.595" 114LSA,Ported Intake and TB, JTR headers,Aluminum driveshaft,3'' to a 3 1/2'' mandrell bent exhaust,light crank pulley,no A/C, no power steering pump,3 1/2'' k&n filter,Front Willwood Big brake,AZC A-arms,Q45 VLSD Rear end. http://www.cardomain.com/ride/438021 1/4 pass video: http://videos.streetfire.net/video/a...b600dd1102.htm |
#2 |
Member
![]() Join Date: Dec 2003
Cool hanging out with you guys on Sunday. Oh yea and excellent food! The vidio does give the car justice but not what it deserves... Meaning after you guys left, Mike (mas280) and I came to the conclusion the Z wasn't runnining right. Something was off. We spent a couple more hours going through the LS2 wiring, which is nothing close to an LS1! Pretty much in the vid only one bank was firing. All was fixed and thats when we called you! Sounds mean!! Soo close you can feel it!!! Will help Mike with brakes this week!! Looking forward to racing you or your bro!!!!!!
JOEY
__________________
"UNLEASH YOUR BEAST" 77 280z 00 LS1 w/T56 445 RWHP! 416 RW TORQUE! 10.94 @ 127.064! 95 RX-7 LS2 POWERED, STROKED TO A 402!! ON THE ROAD!!!! 536 RWHP! 522 RW TORQUE! |
#3 |
Member
![]() Join Date: Nov 2000
awesome! congrats on the progress!
__________________
TO Z OR NOT TO Z... |
#4 |
Member
Here is the video, I guess its going to show bad quality when it finishes optimazing,I didnt know I already had film on this tape.When the video showed Joey He was pressing the correct gas pedal....
http://videos.streetfire.net/video/6...a41e46a4b0.htm
__________________
Best Run with MAS280 Driving, 10.852 @ 131.98 2005 GTO LS2/T56 Engine Swap! 409.56 hp. 391.11 torque. cam 228"/230" .576"/.595" 114LSA,Ported Intake and TB, JTR headers,Aluminum driveshaft,3'' to a 3 1/2'' mandrell bent exhaust,light crank pulley,no A/C, no power steering pump,3 1/2'' k&n filter,Front Willwood Big brake,AZC A-arms,Q45 VLSD Rear end. http://www.cardomain.com/ride/438021 1/4 pass video: http://videos.streetfire.net/video/a...b600dd1102.htm Last edited by ULISES; July 6th, 2006 at 11:13 PM. |
#5 |
Member
![]() Join Date: Jan 2001
I wwasn't able to get the video to play in either Firefox or IE...
__________________
Toys don't make the Man - Man makes the Toys. |
#6 | |
Member
Quote:
__________________
#7 |
Custom user-title!
![]() ![]() Join Date: Jun 2004
Awesome, the Z sounds great! It's going to be kind of hard to drive with the gas pedal in your hand while trying to steer though. Just kidding.
Good luck on gettin' er' done! |
#8 |
Member
![]() Join Date: Jul 2006
That's bad to the bone man!!
You guys do "know" that LS2 ignition coils can deliver "Lethal" voltage & amps don't you (GM tech info)? Probably would be safer to use your cat as an ignition tester next time!
__________________
![]() 94' Laguna blue Miata-2006 Corvette LS2 V8, Ron Davis, T-56 six speed, Ground Control, Ford 8.8 IRS rear 3:73 posi "Patience is NO longer a virtue, Motivated to finish" |
#9 |
Member
![]() Join Date: Sep 2003
haha drive by wire... it just looks wierd to me
__________________
![]() 233k | Photo Album "I heard and smelled your car before I saw it." -innocent bystander |
#10 |
Member
![]() Join Date: Apr 2003
Looks awesome! Did you use the John's Cars LS1 mounting kit? Was there anything that needed to be changed to make the LS2 work?
#11 |
Member
![]() Join Date: Dec 2004
Looks really good! I can't wait til next spring to get mine done. So when are getting some drivin vids?
__________________
Clive 1970 240z #1905 - L30ET Resto-Mod Project 1971 240z- LS1/T56 New club forming in the Northeast. www.NYZCC.org NY,NJ,CT,PA. PM for info.
#12 |
Member
Johns car kit was used with the LS2, I believe there is no difference on the LS1 and LS2 engines.Mike did modify the kit but it had nothing to do with then engine being a LS2.I think Joey had to modify He's and he has a LS1.
Mike said He is trying to finish it by this sunday but its up to him and He's free time.He needs to install all tha guages,Willwood front brakes and axles.
__________________
#13 |
Member
What did you have to modify?
#14 | |
Member
Quote:
__________________
#15 |
Member
![]() Join Date: Jul 2001
i love it, yet another lsz joining the ranks!
__________________
david " I strip away the old debris that hides a shining car. A brilliant red Barchetta from a better, vanished time. I fire up the willing engine, responding with a roar. Tires spitting gravel, I commit my weekly crime..." Rush, Red Barchetta-Moving Pictures 1981 |
#16 |
Member
My car is @ home now, I will have to do brakes and gauges, Mike is doing the axles.
The dash came out today and I have headlights now, I need to make my turn signals work.Brakes should be on by this thursday.I will take the gas tank out and have it cleaned.
__________________
#17 |
Member
![]() Join Date: Jul 2004
Awesome install! Sounds healthy!
__________________
Altec Products Inc. Z and ZX Headlight Lenses. http://altecproducts.com/products_zzxlenses.htm
#18 |
Member
Brakes are almost done Mike cutted the brake line by mistake so I dont know if im going to replace it or fix it yet.My gauges are half way done too.Most of the work should be done by next thursday.The plan is to drive it on the weekend if everything come out right.
Here are some pictures of the work done today! ![]() ![]() ![]() ![]()
__________________
#19 |
Member
Damn......looks great!
__________________
#20 |
Member
![]() Join Date: Jun 2005
Man! I still can't beleive how clean that engine compartmnet is. Its like a work of art.
__________________
'77 280Z - Newly built LT1 4 bolt main, LT4 hot cam kit. 4L60E/Transgo shift kit. 300ZX LSD, 280ZX CV axles. Silvermine Stage 4 front brakes - MM rear disc brakes. 2905 lbs with a full tank. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| What Sectioned Strut Inserts for Coilovers on 280z? | Pennyman | Brakes, Wheels, Suspension and Chassis | 16 | August 16th, 2006 08:30 PM |
| 280z and 300zxt swap-ability | 280z400 | Miscellaneous Tech | 4 | November 27th, 2004 07:31 PM |
| 78 280Z overcharging problem solved. | DaleMX | Ignition and Electrical | 1 | June 5th, 2004 09:04 PM |
| ITS RUNNING AGAIN !!!!! | Cruez | Fuel Delivery | 0 | April 9th, 2004 05:43 PM |
| Need help with rich running triple Mikunis | Moridin | Fuel Delivery | 0 | November 7th, 2002 01:58 AM |
