#1 |
Member
![]() Join Date: Aug 2002
Heres the basic kit. You will still need to get a driveshaft made. This kit is available for sale and can be purchased through Mazworx.com In order to do this swap you'll have already taken the bellhousing of the Z32 trans off to get it machined to accept the adaptor. But I'm gonna cover putting it back together just in case. Heres what you should have. I stood mine up like this for reassembly but it could lay flat too. The first thing you'll need to do is locate this thrust bearing with matching plate. The bearing goes here on the countershaft, rollers facing up. And the plate goes here, concave side up. Make sure your mating surfaces are clean and then silicone up both sides. Next go ahead and install bolts and zip em tight. Now turn your attention to the shifter and shifter plate that came in the kit. 4 bolts/nuts and mount it in the same location as the stock shifter. The plate is installed over the shifter linkage. This spacer setup also needs to be installed with the shifter as pictured. Now that the shifter is installed, make sure that the tranny is in NEUTRAL. Now turn your attention to this sleeve/ball/spring setup. Guide the sleeve in first, then the ball, then the spring, then the tightening bolt. Tighten all the way down. Installed The last thing to do is to clean up the mounting surfaces on the front plate, inside the bell. There is a large C-clip snap ring that goes on the main bearing, and a smaller C-clip that goes on the striking rod that comes through the bell. Sorry didnt get a pic of that. Once those are installed, silicone the surfaces and bolt it up. Now you'll want to setup the fork/throwout setup. You will reuse the L28 throwout bearing and use the Z32 fork. Once that stuff is on you're ready to bolt it up. Now grab the adaptor and bolt it up to the engine using the tapered bolts (for the countersunk holes). Now before you bolt up the trans, there are two areas that need a little attention with a cut off wheel. the first is the shifter opening. I took off a tad more than needed but the shifter will sit further back than the stock shifter does. Now the second area that needs attention (I took pics, but now cant find them At this point I tilted the engine back a bit and bolted the tranny up to the adaptor. Then using a jack to support the underside of the tranny. With that said, this is how I chose to do the tranny Xmember. No its not the most glamorous approach but it uses the stock tranny crossmember and I can GUARANTEE that it AINT GOING NOWHERE. If you wanna cut off the ears and relocate them or weld up your own crossmember, be my guest. Hehe The Z32 mount location is further back. Bolt your stock crossmember pieces to the trans and jack up the tranny into the tunnel. I slotted the bolt holes on the mount so that the crossmember comes up exactly rearward of the ears. With the trans all the way up in the tunnel, I then ran two 1/2"x7" Stainless Steel Carriage Bolts through the ears and into the stock crossmember, using lock washers and nuts on either side of both ears. With all the nuts tightened its SOLID. This philosophy is identical to how an engine stand works. I went ahead and took some pics of shifter location now that the tranny is installed. Driveshaft specs: Length I gave them was 29 1/16" from flange to output shaft Flange yoke I used (same as zx turbo i believe) Powertrain Industries(spicer) part #3102-20 Slip yoke I used (30 spline z32) Powertrain Industries (spicer) part #3103-30 Spicer U-joints 1310 series #5-785X Spicer Tube Yokes #2-28-437 They had to order a few of these parts in which tagged a few bucks onto the bill but my total was $304.39 This Driveshaft is good for 800+ft lbs torque
__________________
'76 280z - L28et (3.0 liter w/ forged pistons) - "Blowzilla" T3/T4 Turbo - 3" Exhaust - 70mm TB - SDS - 450cc Injectors - Custom Intake Manifold - Spearco IC - Meth Injection - STOCK HEAD/CAM 460whp 430ft lbs 11.248@124.17 Last edited by Garrett76Zt; August 2nd, 2006 at 05:51 PM. |
#2 |
Member
![]() Join Date: Sep 2005
so are you going to get a real tranny mount made up? that looks just not look right for a high horsepower car...
#3 |
Member
![]() Join Date: Mar 2001
Thats a great write-up. I like the format that you used with the text and the pics. So many only have text and it's tough to figure out what people are talking about.
I want to add something about the tranny mount. Looks like your solution might be a great temp solution but, I think with the kind of real fun, power, and punishment your going to be putting to thru there I would suggest at the least some grade 8 bolts. But, really a better mount needs to be made. Maybe putting some tubing or pipe of the right size in the ears of the orginal mount would help it to not move around and last longer. If you came up with a good mount you could sell it as an add on to the kit. I only add this because I'm sure you drive your car like I do mine and that thing is going to have some real stress on it. Please, update us as soon as you get the driveshaft in and can give us a driving impression of it all. |
#4 |
Member
I have done this once before, on the pinks car. Tranny mount was fine after multiple 6k launches. The shifter takes a bit of getting used to. it comes straight up as opposed to a tilted back feel. But overall its very smooth.
__________________
'76 280z - L28et (3.0 liter w/ forged pistons) - "Blowzilla" T3/T4 Turbo - 3" Exhaust - 70mm TB - SDS - 450cc Injectors - Custom Intake Manifold - Spearco IC - Meth Injection - STOCK HEAD/CAM 460whp 430ft lbs 11.248@124.17 |
#5 |
I need a hug...
![]() Join Date: Mar 2003
why dont you just cut off the tranny mount and slide it over and weld it?
still uses the same stock mount.. just welds a few inches over.. while your at it.. weld in some thick sheet metal to re-inforce it
__________________
Currently on a rotisserie for a full restoration - L28 with 9mm rods, 88mm Ross pistons (3.0L), 8.5:1 CR, Schneider Stage II cam, Holset HY35W, Megasquirt, Suzuki GSXR ITB's and home made intake plenum, Z32 transmission, Fidanza aluminum flywheel, ACT stage II clutch and pressure plate, coil-overs, vented 4x4 front brakes, 240sx rear brakes, Corbeau FX1 Pro seat, (soon to be half cage) and still debating the paint.. hurm |
#6 |
Member
As far as the transmission mount is concerned, it will work fine. Sure, it may not be pretty, but he doesn't have a welder to fabricate stuff.
__________________
'87 Buick Grand National 3.8 V-6 Turbo swap ![]() "I'm tired of chasing my dreams man. I'm just going to ask where they are going and hook up with them later." - Mitch Hedberg |
#7 | |
Member
Quote:
I thought it was mandatory to have a a full fabrication shop when you became a member of Hybrid Z. J/K |
#8 |
Ludicrous speed, GO!
![]() ![]() Join Date: Feb 2001
Nice write-up Garrett
__________________
71 240z 2JZGTE TH400, 76mm turbo, 3.36 R200 rearend - 8.915 @ 153.60 TechnoToyTuning 2.94 geared R230 rearend - 9.038 @ 152.14 (so far) http://album.hybridz.org/showgallery...00&ppuser=7981 http://videos.streetfire.net/video/a...e90005d70d.htm 02 IS300 Sportcross (daily) 07 Solar Orange 350Z Roadster (wife's car) 03 Ford Excursio-saurus 4x4 Diesel A really bad want is a justifiable need ... |
#9 |
Member
I updated original post with driveshaft info
__________________
#10 |
HybridZ Supporter
![]() ![]() Join Date: May 2001
Garrett,
Hey! Great info! How much did they take off the bell housing? Is it the exact amount of the thickness of the adapter? If so, I guess the real question is, how thick is the adapter? Ken
__________________
Ken Jones 240Z LS2 collecting parts for conversion |
#11 |
Member
![]() Join Date: Jul 2006
Garret, it would be pretty easy to shorten the shifter to get it near stock or the same as the stock position but nice install.
~Alex |
#12 |
Member
I believe its 1/2" Ken. And yes they machined out exactly the thickness of the adaptor.
__________________
#13 |
HybridZ Supporter
Rick and I were looking at a 1988 Z31 turbo shifter the other day... The Z31 turbo uses the same tranny as the Z32. The only difference is that the shifter is not remotely mounted. I think that solution would make it fit pefrectly with no need for cutting. If we can get some pics of a 88 Z31 turbo shifter it would be useful. If no one has them, we'll try to post one next time the owner is around.
__________________
#14 | |
Member
Quote:
I'll drop a hint though . . . Im not 100% positive but I think that the Later VG30e 2wd pathfinders may have used this "shorter" transmission. Someone needs to check it out. In a similar way, the nissan trucks, hardbody's,etc. used a shorter version of the "C box" tranny aka 240sx tranny. The "stubby C box" if you will . . . Isnt Ricks Pathy a 2wd? roll up under there and check it out. . .
__________________
#15 | |
HybridZ Supporter
Quote:
I think what we were focused on was that the tranny is identical but there is a different shifter which mounts kinda like a T5 shifter mounts. This would eliminate the need for that remotely mounted shifter (even on your car). It fits right into the top of the tranny when you remove the shifter cover. Using this shifter would greatly minimize the installation difficulties and probably make the kit cheaper too since you wouldn't need the shifter or remote mounting flange that comes as part of it... Basically any aftermarket shifter for a Z31 turbo (88-89) should work in the stock shifter hole with no cutting (hopefully)... I will take a look and try to confirm these findings a little further
__________________
Ken Jones 240Z LS2 collecting parts for conversion Last edited by kjones; October 11th, 2006 at 02:48 PM. Reason: more info |
#16 |
Member
![]() Join Date: Dec 2004
Garrett,
Thanks for putting this together. Great thread. I vote to make it a sticky. |
#17 |
Member
![]() Join Date: May 2005
they do in fact use a shorter tranny but its just about as rare to find as the 87-89 300zx turbo 5 speeds. Also, when the frontiers came out they used the z32 style shifter linkage and also I think the length is the same. I am curious if the fs5w71c's shifter would work also? Anyone got any input on this? peace.
#18 |
HybridZ Supporter
![]() ![]() Join Date: Sep 2002
can someone sticky this!!
__________________
78 ZX l28 HC (FIA) Track toy in progres'til rust do us part......or the Armco on the Nurburgring' 79 ZXR, SBC, T5, 5 lug, coil overs HLSD, full cage 01 M540I touring MSPORT "trailer hauler at 150MPH" 08 Z4 Coupe "I was just driving down the road and the oil pressure went away...and I lost a rod bearing! I'm finished with the L's for now, I'm putting in an F-ing M5 Engine!" TonyD |
#19 |
Member
![]() Join Date: Jan 2001
I have a '92 Pathy 2WD 4dr if you need some info from it.
On a side note: It's great being able to slide up under a vehicle to work on it without having to jack it up. Changing a 31" tire sucks though. Heres a good site for Pathy info aswell: http://npora.ipbhost.com// |
#20 |
Member
![]() Join Date: Apr 2004
__________________
________________________ 74 260Zt - In progress... huh when arn't they |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| OK GUYS Z32 tranny on an L28 . . . | Garrett76Zt | Nissan L6 Forum | 153 | July 26th, 2006 12:42 AM |
| Anyone here actually seen a Z32 with an LS1 engine/T56 install? | Chris | Z32 Series - 300ZX | 10 | February 3rd, 2006 02:59 AM |
| Z32 tranny mated to L28. Just checking. | pallnet | Drivetrain | 7 | November 25th, 2005 09:16 PM |
| modifying tranny mounts to allow install of ls1 | 1 tuff z | Gen III & IV Chevy V8Z Tech Board | 11 | October 17th, 2005 11:26 AM |
| How Much Touble Is It To Install A SBC And Tranny In A 77 28 | Anonymous | Gen I & II Chevy V8 Tech Board | 2 | December 8th, 2002 09:12 PM |
