Go Back   HybridZ > Technical > Other Engines > Nissan 4 Cyl Forum
Nissan 4 Cyl Forum Discussions of technical related subjects pertaining to Nissan 4 Cyl HybridZ's such as the SR20, CA18 and KA24 engines.
Reply
Thread Tools Display Modes
Old December 31st, 2006, 04:29 PM   #1
trwebb26
Member
trwebb26 is on a distinguished road
Default Where to buy a built SR20DET (S14) motor?
I'm doing some research and have figured out that IF I go with an SR20 motor for my 280 - I'll likely choose an S14 and get it built. I know there HAS to be a ton of shops that sell built motors - but I can't seem to find one online. Can anybody help me?
If you don't know of a shop... what would it cost me to get an SR20 "bulletproofed" (+400 HP).
Thanks!
trwebb26 is offline   Reply With Quote
Old December 31st, 2006, 04:55 PM   #2
oinojo
Member
oinojo's Avatar
oinojo is on a distinguished road
Default
i personally think your better off reliably to buy a crate sr20 and replace the necessities (headgasket, waterpump, etc)... Stock an sr20 is pretty stout.
oinojo is offline   Reply With Quote
Old December 31st, 2006, 08:20 PM   #3
trwebb26
Member
Default
Where can you source a new "crate" DET motor in the states? Where is a good website to read about the power potential of the stock SR motor?
Anybody else got a line on a place where I could buy a built one?
Old January 1st, 2007, 08:06 AM   #4
Z-Gad
Ludicrous speed, GO!
Z-Gad's Avatar
Z-Gad is on a distinguished road
Default
http://www.mazworx.com/engine_lab.html
__________________
71 240z 2JZGTE TH400, 76mm turbo, 3.36 R200 rearend - 8.915 @ 153.60
TechnoToyTuning 2.94 geared R230 rearend - 9.038 @ 152.14 (so far)
http://album.hybridz.org/showgallery...00&ppuser=7981
http://videos.streetfire.net/video/a...e90005d70d.htm
02 IS300 Sportcross (daily)
07 Solar Orange 350Z Roadster (wife's car)
03 Ford Excursio-saurus 4x4 Diesel
A really bad want is a justifiable need ...
Z-Gad is offline   Reply With Quote
Old January 1st, 2007, 05:36 PM   #5
hotimport
Member
hotimport is on a distinguished road
Default
Isnt Decatur in Michigan? Anyhow if you are close by toward the Chicago IL area, there is a place called "Soko International". They have alot of red tops S13 SR20's and some black top S14. Cheap, last time when i was there sourcing some parts for my car, you can pick one up for about $1500 with a tranny, ecu full loop and etc. S14 usually run a bit higher well over $2k. On the other hand if you want a clean SR20 motor then contact Karim screen name here on forum "Racer98" he can get you a cherry motor just like he got me my RB26 and you wont be dissapointed at all.
As far as buying a build up motor right from scratch could be a risky. There is a shop close by my area that has a bunch of SR20's in stock that they could use for a build up, cost wise is around 7-8K depending on what u want out of it, that was atleast their quote for me on fully build motor with a T-78 turbo.
My sugestion to you is probably geting a clean SR20 motor w/e it is S13, S14 or S15 and moding it as you go along.
__________________
1975 280z "Needs new heart of skyline" in progress.
hotimport is offline   Reply With Quote
Old January 1st, 2007, 06:19 PM   #6
Bluto
Member
Bluto's Avatar
Bluto is an unknown quantity at this point
Default
Soko has shut down in chicago
Sam
__________________
The road of excess leads to the palace of wisdom. -Blake
Bluto is offline   Reply With Quote
Old January 14th, 2007, 03:56 AM   #7
rztmartini
Member
rztmartini's Avatar
rztmartini is on a distinguished road
Default
that really depends on your price range. look at Tomei. they have a very good reputation and sell built and "virtually" bulletproof (never heard of anyone testing the limits). they are pretty pricey...but they look niiiiice!
__________________
1972 240Z: all stock...i swear
Horsepower is sooo overrated...
rztmartini is offline   Reply With Quote
Old January 14th, 2007, 02:20 PM   #8
DspecDJ
Junior Member
DspecDJ is on a distinguished road
Default
It's been a while since I've looked around the SR market but from what i remember there are shops like http://www.g-dimension.com and http://www.signalauto.com that are known for building 400+hp SR's for drift cars, you can check them out or like what was said before Tomei builds nice (very pricey) engines if it fits your budget. There are alot of places that build KA-T Crate engines too that I've seen on 240SX forums. You could always just buy a stock SR, do the research and piece one together to your liking.
DspecDJ is offline   Reply With Quote
Old January 18th, 2007, 01:48 PM   #9
Z U L8R
Member
Z U L8R's Avatar
Z U L8R is on a distinguished road
Default
s14 sr20, a gt 28/71 with the big exhaust housing, metal head gasket, arp studs, NAME BRAND ( i wanted to stress that) rocker arm stoppers, decent sized fmic, 550's should do it but you may wanna go just a hair bigger, walbro 255, z32 maf, and 3" exhaust should put you right at 400hp at about 19-20 psi.
with the 550's you'll be able to run an apexi safc2 which isn't that expensive but if you go a little bigger you're gonna have to run different engine management and or just get your ecu tuned. talk with your tuner about whether or not you should disable the variable valve timing or not. for 400hp i'd probably just go with an s13 sr20 so the vvt wouldn't even be an issue and the motor's a little cheaper....plus you could probably even wire it yourself. the s14's wiring are a pain in the ass to find diagrams for fyi
Z U L8R is offline   Reply With Quote
Old February 2nd, 2007, 11:30 PM   #10
C2AUTOSPL
Junior Member
C2AUTOSPL is on a distinguished road
Default
If you like TOMEI or serious about getting a TOMEI engine crate let me know.
C2AUTOSPL is offline   Reply With Quote
Old July 29th, 2009, 11:33 PM   #11
luckygerman
Member
luckygerman is on a distinguished road
Default
Why would you want to go with a Crate SR, youre better of rebuilding it and install some JE, Mahle forged pistons. so that way you can crank up that boost without having to worry to break your motor. My engine builder charges on avarege $800 in labor plus parts to rebuild. He primarily builds race engines, they have all the Mashing equipment in-house, Honing, bohring, Milling, Air Flow Bench ect . Tony Raimondo Racing LLC. in Fayetteville NC
luckygerman is offline   Reply With Quote
Old July 29th, 2009, 11:42 PM   #12
slown280z
Member
slown280z is on a distinguished road
Default
Quote:
I don't know if it's any different for the RWD guys, but rocker arm stoppers are generally considered bad in the FWD SR20DET crowd. You're better off replacing a broken/popped off rocker arm then valves, pistons, rods, and heads that could end up damaged by using a rocker arm stopper.
Also, again, in the FWD crowd, it is not uncommon to see +400hp with just things like injectors, turbo, and EMS upgrades. No need to even open it up.
slown280z is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
SR20DET!!!! fl327 Turbo / Supercharger 57 November 29th, 2008 07:09 PM
WHEN SBC KIT IS BUILT FOR Z32 WHO WOULD WANT TO BUY UPFRONT? NXRPERFORMANCE Gen I & II Chevy V8 Tech Board 18 September 28th, 2003 11:34 AM
Thinking about a new motor... the wife is going to kill me!! dsommer Gen I & II Chevy V8 Tech Board 18 October 26th, 2001 09:10 PM
what motor is this Anonymous Miscellaneous Tech 10 June 14th, 2001 01:48 AM
building or buying a motor? Speaker Gen I & II Chevy V8 Tech Board 15 December 10th, 2000 09:59 PM
Powered by vBulletin® Version 3.8.1
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
