Go Back   HybridZ > Technical > Engine Components > Turbo / Supercharger
Turbo / Supercharger Discussions of technical related subjects pertaining to Turbo and Supercharging in Hybrid Z's
Reply
Thread Tools Display Modes
Old May 11th, 2007, 11:31 AM   #1
TimZ
Member
TimZ's Avatar
TimZ is an unknown quantity at this point
Default Went to the dyno with the GT42r today...
I'm pretty pleased with the results...
this was done at
~85degF ambient,
25psi boost
94 octane sunoco gas
no nitrous
no water or meth injection
it's a stroked L28 with an N42 head
I'll fill in a few more details later, but wanted to get the results out (okay, I'm a little pumped)
EDIT:
100mph corresponds roughly to 5000rpm
The rev limiter was set at 7600rpm and this run ended on the rev limiter.
__________________
Information is not knowledge
Knowledge is not wisdom
Wisdom is not truth
-FZ, Joe's Garage
TimZ is offline   Reply With Quote
Old May 11th, 2007, 11:36 AM   #2
J. Soileau RB26zcar
RB on da brain
J. Soileau RB26zcar's Avatar
J. Soileau RB26zcar is on a distinguished road
Default
Way to go Tim!!
__________________
~joel
True OEM HID Retrofit
Click for^^ rb26dettZ pics
J. Soileau RB26zcar is offline   Reply With Quote
Old May 11th, 2007, 12:06 PM   #3
DemonZ
Member
DemonZ is an unknown quantity at this point
Default
Holy smokes! That must be a world record for L28 power, or darn close. Congrats on the personal best.
DemonZ is offline   Reply With Quote
Old May 11th, 2007, 12:25 PM   #4
Pete S
Member
Pete S's Avatar
Pete S is an unknown quantity at this point
Default
Great pull! You've got good reason to be excited.
Pete S is offline   Reply With Quote
Old May 11th, 2007, 12:42 PM   #5
JustinOlson
Slithering snake
JustinOlson is on a distinguished road
Default
Wow, thats a ton of boost on pump gas. Killer numbers!!! What RPM does 100mph relate to?
JustinOlson is offline   Reply With Quote
Old May 11th, 2007, 12:46 PM   #6
280ZForce
Posts: n/a
Default
wow!
huge congrats... I've got my work cut out for me now once I get mine up and running soon.
What was the rpms your max #s were at? How high were you spinning up to? Maybe you can convert your graph for us to represent rpms.
Can't wait to see the details on your build exactly.
Old May 11th, 2007, 01:06 PM   #7
jgkurz
Slowest Indian
jgkurz's Avatar
jgkurz is on a distinguished road
Default
Wow, the tool kit wasn't far off from the HP prediction. Impressive is an understatement but to do it on pump gas is even more remarkable. With a 15% drivetrain loss that puts you at 700HP crank HP. I think that's got to be a new record for street driven L28.
BTW, did you get the DynoJet DRF output file from the shop. If you did you can download the Run Viewer and view additional data. You could also change the MPH to RPM if the pickup was connected. Here's the link:
http://www.dynojet.com/downloads/software.aspx
__________________
-John
My Z
jgkurz is offline   Reply With Quote
Old May 11th, 2007, 01:09 PM   #8
BillZ260
Member
BillZ260's Avatar
Location: Tulsa, OKLAHOMA you know where that is right?
BillZ260 is an unknown quantity at this point
Default
WOW!
My next Z is definitly a Turbo 6
__________________
Bill
Early 260/355/T-5
I can now drive it around the block anytime I want!!!
BillZ260 is offline   Reply With Quote
Old May 11th, 2007, 01:12 PM   #9
Mikelly
HybridZ Supporter
Mikelly will become famous soon enough
Default
DAYUM!!!!!!
Smokin'!
Mike
Mikelly is offline   Reply With Quote
Old May 11th, 2007, 01:17 PM   #10
CantZme
Member
CantZme's Avatar
CantZme is on a distinguished road
Default
CantZme is offline   Reply With Quote
Old May 11th, 2007, 01:37 PM   #11
PrOxLaMuS©
I need a hug...
PrOxLaMuS©'s Avatar
PrOxLaMuS© is an unknown quantity at this point
Default
600 hp!
holy freakn crap!
__________________
Currently on a rotisserie for a full restoration - L28 with 9mm rods, 88mm Ross pistons (3.0L), 8.5:1 CR, Schneider Stage II cam, Holset HY35W, Megasquirt, Suzuki GSXR ITB's and home made intake plenum, Z32 transmission, Fidanza aluminum flywheel, ACT stage II clutch and pressure plate, coil-overs, vented 4x4 front brakes, 240sx rear brakes, Corbeau FX1 Pro seat, (soon to be half cage) and still debating the paint.. hurm
PrOxLaMuS© is offline   Reply With Quote
Old May 11th, 2007, 02:19 PM   #12
jnjdragracing
Member
jnjdragracing's Avatar
jnjdragracing is on a distinguished road
Default
Congrats on them mighty fine numbers. Way to go....
John
__________________
No Need To Go Through Life Scared......
jnjdragracing is offline   Reply With Quote
Old May 11th, 2007, 02:34 PM   #13
lostfairlady
Member
lostfairlady's Avatar
lostfairlady is on a distinguished road
Default
wow wow wow wow!!!! I just dont know what to say. That is sweet. I envy you.
lostfairlady is offline   Reply With Quote
Old May 11th, 2007, 07:37 PM   #14
Racinjitter
The Jitter Bug...
Racinjitter's Avatar
Racinjitter is on a distinguished road
Default
HOLY CRAP!!! Very nice numbers! When I get my car back from the exhaust shop we should terrorize some mullets!
__________________
RB25DET, RB30DET build in progress. 400whp Shiro Special # 981 build in tuning.
Racinjitter is offline   Reply With Quote
Old May 11th, 2007, 07:39 PM   #15
Scottie-GNZ
HybridZ Supporter
Scottie-GNZ is on a distinguished road
Default
That should make the tires holler for mercy!
__________________
Scottie
'87 RX7 / 2JZ Power - 9.51 @ 146.16
71 240Z / GN-powered
'84 911 Carrera Cabriolet
'97 E36 M3 Coupe/5-spd
'98 Sonoma Stepside - LM4 powered
Scottie-GNZ is offline   Reply With Quote
Old May 11th, 2007, 08:10 PM   #16
Challenger
ReMembered
Challenger's Avatar
Challenger is on a distinguished road
Default
Wow thats amazing!!!!! It looks like your running lean so you could expect even more power?
__________________
Derek
78 280z 2+2- RBR's, tokicos, poly bushings, 240 bumper, black on grey... no chrome here. Slowly emerging from restoration.
81 280zxt Silver Coupe- Stock... keeping me occupied till schools done.
Need help with your turbo swap, click me.
Challenger is offline   Reply With Quote
Old May 11th, 2007, 09:03 PM   #17
TimZ
Member
TimZ's Avatar
Default
Quote:
No, 11.5:1 seemed to be pretty much the sweet spot. I would have liked to have had the ambient temps a bit cooler, though...
__________________
Wisdom is not truth
-FZ, Joe's Garage
Old May 11th, 2007, 09:37 PM   #18
speeder
HybridZ Supporter
speeder's Avatar
speeder is on a distinguished road
Default
You should be! That's just incredible, Tim.
__________________
Rick Bowers
'77 280ZT (Not as fat as I thought) - Awaiting 260ci Twin Turbo Buick Stage II - Finally out of machine shop jail after 2+ years!
'78 280Z (Soon to be for sale)
2002 Lexus IS300 - Turbo 2JZ, 6-speed - daily driven monster.
"Speed costs - How fast do you want to spend?"
My build thread: http://forums.hybridz.org/showthread.php?t=136300
Old body shown in obsolete website:
Rick's 280ZT AKA: "Porkchop"
speeder is offline   Reply With Quote
Old May 12th, 2007, 12:04 AM   #19
evildky
Member
evildky's Avatar
evildky is on a distinguished road
Default
wow!? and not enough traction to kep it pointes strait!
__________________
"if I had all the money I ever spent on cars...I'd spend it all on cars"
12.610 @113.52 mph, 299.3whp 305 lbft TQ
Warning! if you take this or any post too seriously, your head will explode, your dog will run away and your car will break!
evildky is offline   Reply With Quote
Old May 12th, 2007, 07:52 AM   #20
Z-Gad
Ludicrous speed, GO!
Z-Gad's Avatar
Z-Gad is on a distinguished road
Default
WOW Tim!!!
That is simply amazing!!
Big turbo = GOOD!!
__________________
71 240z 2JZGTE TH400, 76mm turbo, 3.36 R200 rearend - 8.915 @ 153.60
TechnoToyTuning 2.94 geared R230 rearend - 9.038 @ 152.14 (so far)
http://album.hybridz.org/showgallery...00&ppuser=7981
http://videos.streetfire.net/video/a...e90005d70d.htm
02 IS300 Sportcross (daily)
07 Solar Orange 350Z Roadster (wife's car)
03 Ford Excursio-saurus 4x4 Diesel
A really bad want is a justifiable need ...
Z-Gad is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Got The Rb280z On The Dyno Today ZDrifter Nissan RB Forum 9 May 10th, 2007 08:57 AM
Dyno Runs today - All is Good jnjdragracing Gen I & II Chevy V8 Tech Board 15 September 9th, 2006 05:03 AM
Ran my car on the dyno today... Chris240zTurbo Nissan L6 Forum 36 September 6th, 2006 06:38 PM
Can it be? Yes it is! Even more dyno results!!! bastaad525 Turbo / Supercharger 21 September 11th, 2004 09:19 PM
toy'ed with a turbo Z at school today, dyno too. ON3GO Miscellaneous Tech 15 January 28th, 2004 02:18 PM
Powered by vBulletin® Version 3.8.1
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
