Go Back   HybridZ > Technical > 6 Cylinder Z Forums > Nissan RB Forum
Reply
Thread Tools Display Modes
Old June 18th, 2007, 09:12 AM   #1
Booztd 3
Member
Booztd 3 is on a distinguished road
Default My Rb26 Z32 Project is finished for the year....
My 1990 RB26 powered Nissan 300ZX
Modification List
Drivetrain
RB26DETT
RB25 Modified Oil Pan
Z32 Transmission Mated w/RB Trans
Modified Cross Member
Custom Motor Mounts
Full-Race Twin-Scroll Manifold
(2) Tial 44mm Wastegates
Tial 50mm BOV
Greddy Cam Gears
ARP Head Studs
Tomei Type-A Poncams
Greddy T-Belt
Tomei 5 Layer Gasket Kit
Garret GT4202-74mm
JGY Fuel Rail (Dual -8 Feed Setup, Single -6 Return)
TMS 1000CC Injectors
AeroMotive FPR
(2) Walbro 255 GSS-342 Fuel Pumps
Earls Fittings/Braided Lines For Fuel
Earls Fittings/Braided Lines For Oil
OS Giken Triple Plate Clutch
RB25 Slave Cylinder
Clutch Pivot Ball & Clutch Line
Z1 1piece Steel Driveshaft
Richmond 4.10 Ring & Pinion Set
XS Engineering 4" FMIC
Custom Aluminum IC Piping
4" Downpipe & Test Pipe Fab
Greddy SP Dual Exhaust for 300ZX
(2) 10" Permacool HD Electric Fans
Custom Double-Pass Radiator
245/45/17 Khumos in front
275/40/17 MT ET Street Radials in rear
Not Installed
N1 Water Pump
N1 Oil Pump
Crank Collar
Pauter Rods
CP Pistons
ACL Race Bearings
Suspension
Powertrix HICAS Eliminator Bar
Powertrix Adj. Tension Rods
Electronics
AEM 1621 RB26DETT EMS
AEM 3.5 Bar Map Sensor, Coolant Sensor, IAT Sensor
AEM UEGO
Defi Link 2
Defi BF Boost Guage
Relocated Battery to Rear - Optima Red Top
Alpine CDA-9857
Alpine Speakers
Safety
Full 8pt Roll Cage - Certified to 8.50's
Swing-Out Bars
RCI Platinum 5pt Harnesses
RJS Window Net
Flaming River Battery Kill Switch
Interior
Complete Maroon Red to Charcoal Black interior swap
Removed Tweed Inserts, Custom Vinyl application
Sparco Speed Seats w/custom sliders
Sparco Extreme2 Steering Wheel
Nismo Shift Knob (the rare one!)
Cosmetic
1999 Fairlady Z JDM Bumper w/smoked turn signals
1999 Fairlady Z JDM Tail Lights
Stillen Type 3 Sideskirts & Door Fillers
5-Zigen FN01R-C
Paint matched Brake Caliper to wheel colors
Powertrix Carbon Fiber Air Guides (under hood)
The car is currently making 485rwhp@14psi and I plan on going back to the dyno to give it a little more boost before rebuilding the motor. I would like ot achieve 600rwhp this season and get a few 10 second passes in. Once I regain my social life this summer/fall and get to enjoy my car for several months, it wil be going back under the knife this winter so I can add all the forged goodies and paint the engine bay. I will probably sell the N1 oil pump in favor of a better oil pump (JUN, Tomei, etc) and I'll also need to pick up an ATI Pulley.
Laterz
Booztd 3 is offline   Reply With Quote
Old June 18th, 2007, 09:48 AM   #2
ZDrifter
Member
ZDrifter's Avatar
ZDrifter is on a distinguished road
Default
Very clean install I love it!! But one thing.... Having the AEM in the engine bay makes me cover my eyes!! In my opinion I would rather have it inside the car. Is there any reason preventing you from doing that?? Electronics and heat dont mix. Just my opinion tho, great job and I cant wait to see more videos!!!!!!
__________________
1978 RB280Z
ZDrifter is offline   Reply With Quote
Old June 18th, 2007, 09:56 AM   #3
Booztd 3
Member
Default
I mainly wanted it there for a showoff factor
Plus I shortened the RB wiring harness considerably, in order to do this, so i'd have to re-lenthen the harness to do it all over again!
I do not drive the car in extreme heat, nor in rain, so I havent had any issues yet, plus AEM is really good about warranting their stuff
Old June 18th, 2007, 01:34 PM   #4
ZDrifter
Member
ZDrifter's Avatar
Default
I would still build a box for it atleast.... My ignitor failed because of heat and ended up frying my ECU. If you want to show it off you can just pull the cover off of it. But if you take it out and drive it for a good amount of time and pull it in the garage back home put your hand on the ECU if its cool then your fine. But if you have to take your hand off of it I would suggest building a box for it. Just my opinon and I hope to see your car sometime!!!
__________________
1978 RB280Z
Old June 18th, 2007, 02:41 PM   #5
mannyvig
Member
mannyvig's Avatar
mannyvig is on a distinguished road
Default
Man I have loved watching everything going on with your car. It has given me plenty ideas and hope for the 26 build im knee deep in. Thanks a lot. Keep posting videos and other good stuff. Good luck
__________________
mannyvig is offline   Reply With Quote
Old June 18th, 2007, 09:44 PM   #6
J Taylor
Member
J Taylor is an unknown quantity at this point
Default
Looking good, man.
__________________
F&D Autocare 251-653-8141
78 280z rb25det / th350.......9.69 @ 144mph
73 240z
69 Datsun 1600 Roadster
J Taylor is offline   Reply With Quote
Old June 20th, 2007, 07:46 AM   #7
RB26DETT
Member
RB26DETT is an unknown quantity at this point
Default
looking good!
... not running an air filter?
__________________
Imola yellow RB26DETT 240Z
Perth, Western Australia
RB26DETT is offline   Reply With Quote
Old June 20th, 2007, 09:02 AM   #8
Z-Gad
Ludicrous speed, GO!
Z-Gad's Avatar
Z-Gad is on a distinguished road
Default
Very Nice!!
Have you had a chance to weigh the car in it's current form?
__________________
71 240z 2JZGTE TH400, 76mm turbo, 3.36 R200 rearend - 8.915 @ 153.60
TechnoToyTuning 2.94 geared R230 rearend - 9.038 @ 152.14 (so far)
http://album.hybridz.org/showgallery...00&ppuser=7981
http://videos.streetfire.net/video/a...e90005d70d.htm
02 IS300 Sportcross (daily)
07 Solar Orange 350Z Roadster (wife's car)
03 Ford Excursio-saurus 4x4 Diesel
A really bad want is a justifiable need ...
Z-Gad is offline   Reply With Quote
Old June 20th, 2007, 01:27 PM   #9
Booztd 3
Member
Default
No weight figures yet, still working on that
Old June 27th, 2007, 09:07 PM   #10
Z U L8R
Member
Z U L8R's Avatar
Z U L8R is on a distinguished road
Default
lookin good lookin good.
but for GOD SAKES lower the frickin car!!
__________________
WWW.LETHALMOTORSPORTS.COM
1978 280z + RB25DET = 441rwhp381rwtq@22psi GT30/76R 11.92@125mph 2.1 60' street tires/no lsd
1972 Datsun 510 4 door IRS KA24DE (ka-t soon)
www.myspace.com/z_u_l8r
Z U L8R is offline   Reply With Quote
Old June 28th, 2007, 08:00 AM   #11
slownrusty
HybridZ Supporter
slownrusty's Avatar
slownrusty is on a distinguished road
Default
Simply awesome...inspiring indeed!
Three thumbs up!
Yasin
__________________
Ole skool "wouldn't have it any other way"
slownrusty is offline   Reply With Quote
Old June 28th, 2007, 10:08 AM   #12
Booztd 3
Member
Default
I drag race this car frequently, lowering it would be like suicide.....stock suspension is great for the drag strip
Old June 28th, 2007, 10:14 AM   #13
Z U L8R
Member
Z U L8R's Avatar
Default
gotcha
__________________
Old June 29th, 2007, 10:03 AM   #14
triple B
Member
triple B's Avatar
triple B is on a distinguished road
Default
thats dead sexy man
nice
__________________
The best in the Tri-cities area
http://www.myspace.com/empireracingmi
WWW.EMPIRERACING.ORG/F
triple B is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
I finished my RB26 240Z markrolston@mac.com Nissan RB Forum 90 March 8th, 2007 09:43 AM
WTB... any year Z w/ rb26 topsecretz Other Engines 27 April 19th, 2006 03:46 PM
GTO Project Finished 250z Body Kits & Paint 30 December 14th, 2003 05:50 PM
Did anyone actually ever complete a Z32 > Z8 project? Your Car is Slow Gen I & II Chevy V8 Tech Board 4 April 7th, 2003 11:29 PM
The LS1 Z32 project is officially underway. KraZeeZX Gen III & IV Chevy V8Z Tech Board 4 July 25th, 2002 06:53 PM
Powered by vBulletin® Version 3.8.1
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
