Go Back   HybridZ > Technical > 6 Cylinder Z Forums > Toyota L6 Forum
Reply
Thread Tools Display Modes
Old October 25th, 2007, 08:24 PM   #1
JustinOlson
Slithering snake
JustinOlson is on a distinguished road
Default TH400 with GM or Toyota Bellhousing?
I'm looking to do a TH400 setup in my car real soon. I'm wondering if there is a preference/advantage to running a Toyota bellhousing on a TH400 vs the standard GM be bellhousing?
I realize that you have to run a smaller hybrid converter when using the toyota bellhousing. Is this a disadvantage? Do the smaller torque converters have more trouble with heat?
My main worry is the size of the GM bellhousing fitting the transmission tunnel with the 2JZ mounted back to the firewall.
I have the option of going with a Boostwerks adapter:
http://www.clubna-t.com/forums/showthread.php?t=1467
Or a Virtual Works toyota bellhousing adapter for the Th400.
I already have a GM TH400 and a toyota auto, so its no real difference to me parts wise.
Regards,
Justin
JustinOlson is offline   Reply With Quote
Old October 26th, 2007, 06:09 AM   #2
Scottie-GNZ
HybridZ Supporter
Scottie-GNZ is on a distinguished road
Default
I am using the Boostwerx kit.
Not a fan of the cut-the-bellhousing method but I understand the potential fitment issue. Obviously it works since that is what Z-Gad has.
__________________
Scottie
'87 RX7 / 2JZ Power - 9.51 @ 146.16
71 240Z / GN-powered
'84 911 Carrera Cabriolet
'97 E36 M3 Coupe/5-spd
'98 Sonoma Stepside - LM4 powered
Scottie-GNZ is offline   Reply With Quote
Old October 26th, 2007, 11:07 AM   #3
JustinOlson
Slithering snake
Default
Is there a major difference in cost/availability between the hybrid converters and the standard converters?
Old October 26th, 2007, 07:19 PM   #4
JustinOlson
Slithering snake
Default
Well, I missed out on a local deal for a adapter plate for the toyota bell housing. Looks like I'm going to order DaveH's kit shortly.
Justin
Old October 26th, 2007, 07:44 PM   #5
JustinOlson
Slithering snake
Default
I'm beginning to think that Dave's kit uses the Ross Machine Racing adapter with his own torque converter adapter:
http://www.rossmachineracing.com/supratransadapt.html
Justin
Old October 28th, 2007, 08:54 AM   #6
orklc
Member
orklc is an unknown quantity at this point
Default ATI Racing solution
I was just looking over the ATI Racing catalogue and they list an adapter for 2JZ to GM transmision.
I have been meaning to call and find more information here is a link.
http://www.atiperformanceproducts.co...pterk/akit.htm
__________________
72 Datsun 1200 - 1.8L Toyota engine, 11.4 in the 1/4 mile and 1.50 sec in 60' (Stock short block)
orklc is offline   Reply With Quote
Old October 28th, 2007, 04:25 PM   #7
Scottie-GNZ
HybridZ Supporter
Default
While the ATI kit is about $35 cheaper than the Boostwerx, it states you have to use their 9" converter which lists for almost $1000. I am using a Precision Vigilante that cost $640. Not pushing anyone towards the Boostwerx but I did all the reasearch and decided on the Boostwerx.
__________________
Scottie
Old October 28th, 2007, 05:45 PM   #8
JustinOlson
Slithering snake
Default
So how do I choose a proper stall speed for the converter? I'm planning on using nitrous to flash the converter at the track.
The general setup I'm going for:
Stock 2JZGE
272 cams
Custom Intake manifold like Virtual Works
Divided t4 turbine manifold like full-race's
GT4202 1.15 a/r
4" downpipe w/ 4" muffler out the passenger fender
24*12*3 intercooler
Regards,
Justin
Old November 10th, 2007, 08:56 PM   #9
240Z_478
Member
240Z_478 is on a distinguished road
Default
Hey Justin I am in the same boat as you I have a TH400 that is being rebuilt for my 2JZ right now. I also have the stock 2JZ auto tranny. What exactly is needed to get the TH400 to bolt up? I know there are two options but neither really make sense on how to get it to bolt up. Do I need the ross machining adapter plate and then the custom converter or will a normal TH400 converter work? What about the flex plate which one is used?
240Z_478 is offline   Reply With Quote
Old November 10th, 2007, 09:12 PM   #10
Z-Gad
Ludicrous speed, GO!
Z-Gad's Avatar
Z-Gad is on a distinguished road
Default
I use the Toyota bellhousing. I too would wonder about clearance issues with the TH400 bell in the Z tunnel with the engine back on the firewall. I know it would not fit in mine. I barely have room for the Toyota housing.
Regarding the stall. With the GT42, you'll need a little spray to spool the turbo, unless you go with an unstreetable stall converter. Scottie and I both run 4200 stalls. I am satisfied with mine, and I run a Precision 76-GTS (same size wheels as a GT4202, but a different turbine housing). I do spray to spool the turbo, as does Scottie...
Regards, Mike
__________________
71 240z 2JZGTE TH400, 76mm turbo, 3.36 R200 rearend - 8.915 @ 153.60
TechnoToyTuning 2.94 geared R230 rearend - 9.038 @ 152.14 (so far)
http://album.hybridz.org/showgallery...00&ppuser=7981
http://videos.streetfire.net/video/a...e90005d70d.htm
02 IS300 Sportcross (daily)
07 Solar Orange 350Z Roadster (wife's car)
03 Ford Excursio-saurus 4x4 Diesel
A really bad want is a justifiable need ...
Z-Gad is offline   Reply With Quote
Old November 11th, 2007, 02:49 PM   #11
240Z_478
Member
Default
so which toyota bellhousing do you use? Is it a custom one that must be ordered or just the stock one off the 2JZ? Where can you get the custom torque converters made?
Old November 11th, 2007, 03:31 PM   #12
JustinOlson
Slithering snake
Default
Its the factory toyota auto bellhousing. I believe you can use the A340 or A341 bell housing (2JZGE or 2JZGTE). You need a adapter plate that allows you to bolt it to the TH400 once you've cut off the factory TH400 bellhousing. You then use a hybrid converter.
Regards,
Justin
Old November 11th, 2007, 06:24 PM   #13
240Z_478
Member
Default
ok it is making a little more sense now. So then after you cut it and use the adapter plate the stock toyota bell housing will bolt on? after it gets cut do you just use all the toyta parts and get a custom converter? where can you get this hybrid converter?
Old November 11th, 2007, 06:37 PM   #14
240Z_478
Member
Default
Does someone have pictures of the process of adapting the two?
Maybe just pictures of the cutting?
Why is the boostwerx kit so much if all that you need is the adapter plate?
Can you just use the Ross machining one?
Old November 11th, 2007, 08:30 PM   #15
Scottie-GNZ
HybridZ Supporter
Default
The boostwerx kit allows you to use an unmodified TH400 and standard GM converter. That means you do not have to cut the tranny bellhousing or use any hybrid stuff. There's more to these things than just the adaptor and in the end, the hybrid method could end up being more expensive. Of course, if there is a clearance problem then I guess there is little choice.
__________________
Scottie
Old November 12th, 2007, 01:53 PM   #16
Ivan280zt
Member
Ivan280zt's Avatar
Ivan280zt is on a distinguished road
Default
I got mine for DaveH at boostwerx. Great guy to deal with he will answer any questions that you have. His whole kit for 2jz was $750 and as Scotty mentioned you can use any gm torque convertor none of that $900 hybrid bs! Not that there is something wrong but I just like to keep my options open with torque convertors.
__________________
My 2JZGE-T project: http://forums.hybridz.org/showthread.php?t=143165
Ivan280zt is offline   Reply With Quote
Old November 23rd, 2007, 09:09 AM   #17
GODCHSR
Junior Member
GODCHSR is on a distinguished road
Default
I went to Boostwerx to check the 'kit' out and it wasn't listed, that I could see at least. What exactly is included in the kit?
Assuming I have the 2JZ, TH400 and convertor of choice.... where does the boostwerx kit come in? adapter....? $750 seems high, so I have to assume there's more to this kit.
GODCHSR is offline   Reply With Quote
Old November 23rd, 2007, 12:50 PM   #18
Ivan280zt
Member
Ivan280zt's Avatar
Default
Here is the link with pics from DaveH:
That is where I got mine from.
__________________
Old December 2nd, 2007, 02:43 PM   #19
GODCHSR
Junior Member
Default
I'm trying to figure out how a TH400 with boostwerx adapter would fit into a Z32 but does anyone know if someone is even running this setup?
__________________
2000 VW Jetta 2.0 (fully built NA)
1993 Jeep Cherokee (3" RC Lift and 32x11.5 BFG ATs)
1992 Nissan 300zx TT (removed VG30DETT, looking for a replacement)
Old December 31st, 2007, 10:00 AM   #20
240Z_478
Member
Default
Justin what adapter did you end up going with?
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
FAQ Acronym Page JSM FAQs 31 March 2nd, 2009 09:08 PM
GM bellhousing bolt pattern dimensions staledale Gen I & II Chevy V8 Tech Board 19 December 29th, 2007 01:34 PM
6.0L Gen III Escalade Crate Engine ZTR Gen III & IV Chevy V8Z Tech Board 11 November 21st, 2004 11:32 AM
Non-Hydraulic T5 BillZ260 Drivetrain 9 January 14th, 2004 11:16 AM
T56 with GM transverse bellhousing pattern Will Drivetrain 1 June 17th, 2002 08:57 PM
Powered by vBulletin® Version 3.8.1
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
