Go Back   HybridZ > Technical > 6 Cylinder Z Forums > Toyota L6 Forum
Reply
Thread Tools Display Modes
Old December 17th, 2007, 02:03 PM   #1
theianmonster
Member
theianmonster's Avatar
theianmonster is on a distinguished road
Default My '71 240Z 1JZ Swap...
I thought I might as well join in and let everybody know about my project that I have going on. By the way, this is my drift car...
A little background on the car. I bought the car for $900 last January, and spent a good amount of time getting it running, doing some mild suspension, fixing the brakes, and putting the air dam off of my old car on it.
Specs:
- Tokico Illumina Shocks
- Eibach Pro-Spring Kit
- Nismo T/C Kit
- Nismo Steering Couplers
- Long-nose R200 Rear Differential
- Rear Sway Bar
- BRE Hangers
- Poly Bushings
Here are some pictures before I tore the car apart:
Then one day, after a few beers, my buddy convinced me to go for the 1JZ-GTE swap:
Then I gave in again and did the S13 dash swap, not complete, obviously:
And test fitted some 15x10 -38 Diamond Racing Wheels. I will be running the exact width and offset, but in a 16" rim:
Here are the specs on my motor so far:
- 1JZ-GTE from Toyota Chaser
- W58 5-Speed (Came out of my friend's 1JZ powered MX83 Cressida, 400rwhp)
- XTD Stage-3 Clutch
- 2JZ-GE OEM Flywheel
- OEM Flywheel Bolts
- 2JZ-GE Bellhousing
- MKIV Clutch Fork
- 5M Starter
- Megasquirt w/ 2-Step and Boost Cut
I have the whole front of the motor to finish.
I'll keep you guys updated.
- Ian.
__________________
theianmonster is offline   Reply With Quote
Old December 17th, 2007, 02:26 PM   #2
Gareth
Member
Gareth's Avatar
Gareth is on a distinguished road
Default
Looks good, but don't you think that the car could use some bigger brakes? Stock brakes just won't cut it with a high-powered turbo engine...
__________________
'71 240Z, chassis no. HLS30 52689.
Gareth is offline   Reply With Quote
Old December 17th, 2007, 02:46 PM   #3
Pete84
Member
Pete84 is on a distinguished road
Default
Nothing more terrifying than being on a winding mountian road with fading brakes . . .
When you REALLY need to break for the next corner, and it is all downhill for several more miles.
You going to use the swap directions from this sub-forum? Would be interesting to get some feedback, it looks very straight forward. Might get the earlier 1JZ with the TT's and call it a 2JZ Supra swap . . . . and get it smoged
Pete84 is offline   Reply With Quote
Old December 17th, 2007, 05:24 PM   #4
JustinOlson
Slithering snake
JustinOlson is on a distinguished road
Default
I love it. Your car is very badass looking!
Justin
JustinOlson is offline   Reply With Quote
Old December 19th, 2007, 11:41 AM   #5
theianmonster
Member
Default
I have brake plans, don't worry.
Thanks for the feedback.
__________________
Old December 26th, 2007, 07:56 PM   #6
timbo1jz
HybridZ Supporter
timbo1jz's Avatar
timbo1jz is on a distinguished road
Default
very cool man, I am in the same boat as you. Get some good pics during your build up!
timbo1jz is offline   Reply With Quote
Old April 16th, 2008, 11:09 AM   #7
theianmonster
Member
Default
Finally got some time to work and order some parts for this damn car, motor should be in next week on my custom crossmember.
- Ian.
__________________
Old April 25th, 2008, 01:09 AM   #8
ghost1530
Junior Member
ghost1530 is on a distinguished road
Default
sweet...dude. i'm planning on doing a 2jz into my 240z. i want to know if a 1jz tranny bolts onto a 2jz motor?
ghost1530 is offline   Reply With Quote
Old April 25th, 2008, 09:11 AM   #9
ShaggyZ
Terminator
ShaggyZ's Avatar
ShaggyZ is on a distinguished road
Default
Quote:
Yes, but look around and you'll find some info on this. The short: R154 requires hard-to-find bellhousing; W58 is easy.
__________________
'77 280Z 2JZ-GTE in Progresso
'03 SV650S
ShaggyZ is offline   Reply With Quote
Old April 26th, 2008, 11:06 AM   #10
timbo1jz
HybridZ Supporter
timbo1jz's Avatar
Default
the bellhousing is not hard at all to find. My friend sells them from his shop as do a lot of other shops. They are pricey though.
Driftmotion.com
Old April 26th, 2008, 11:51 AM   #11
ShaggyZ
Terminator
ShaggyZ's Avatar
Default
Quote:
Driftmotion.com
Right. I meant hard to find used. You can buy them new for under $400.
__________________
'03 SV650S
Old April 26th, 2008, 09:47 PM   #12
Z-Gad
Ludicrous speed, GO!
Z-Gad's Avatar
Z-Gad is on a distinguished road
Default
Quote:
... and that's cheaper than having to replace your first broken W58
__________________
71 240z 2JZGTE TH400, 76mm turbo, 3.36 R200 rearend - 8.915 @ 153.60
TechnoToyTuning 2.94 geared R230 rearend - 9.038 @ 152.14 (so far)
http://album.hybridz.org/showgallery...00&ppuser=7981
http://videos.streetfire.net/video/a...e90005d70d.htm
02 IS300 Sportcross (daily)
07 Solar Orange 350Z Roadster (wife's car)
03 Ford Excursio-saurus 4x4 Diesel
A really bad want is a justifiable need ...
Z-Gad is offline   Reply With Quote
Old April 26th, 2008, 10:16 PM   #13
ShaggyZ
Terminator
ShaggyZ's Avatar
Default
Quote:
Very true. Actually, the R154 I have now I basically got for free plus $150; plus, it came with a new stock clutch, shifter and driveshaft. Previously, I was looking at spending ~$700 for an ebay R154 with the way they sell there. I'd say I'm off to a good start on my budget build
__________________
'03 SV650S
Old April 19th, 2009, 11:09 AM   #14
shinji Hirako
Junior Member
shinji Hirako is on a distinguished road
Default
Is it ok for me to steal you color scheme idea for my 240Z Project!
shinji Hirako is offline   Reply With Quote
Old April 21st, 2009, 09:11 PM   #15
shinji Hirako
Junior Member
Default
Update!!! Please Update!
Old April 23rd, 2009, 06:19 PM   #16
WizardBlack
HybridZ Supporter
WizardBlack is on a distinguished road
Default
Great looking setup. Update with PICS!
__________________
'77 280Zt - RB25DET swap and Q45 rear end swap in progress
WizardBlack is offline   Reply With Quote
Old April 23rd, 2009, 09:56 PM   #17
piston
Member
piston is on a distinguished road
Default
pics didnt work or me? dont see the rest of the pics?
piston is offline   Reply With Quote
Old June 17th, 2009, 12:54 AM   #18
orange76
Junior Member
orange76 is on a distinguished road
Default
will that suspension setup work fine with the 1jz cause im looking to do a swap and i have the illumina shocks and the eibach springs?
thanx
orange76 is offline   Reply With Quote
Old June 17th, 2009, 01:55 AM   #19
aziza z
DEFCON 4
aziza z's Avatar
aziza z is on a distinguished road
Default
Last Activity: January 24th, 2009 02:52 PM
Ill try to get his attention on FB.
__________________
- Matt
- Challenge authority -
http://www.myspace.com/azizaz
75 280z (LS1) - 73 240z (widebody)
aziza z is offline   Reply With Quote
Old June 18th, 2009, 12:03 PM   #20
theianmonster
Member
Default
Yes,this suspension will work fine. I was going to upgrade to custom Stance coilover set up.
THIS CAR HAS BEEN SOLD. I never completed the project due to money issues.
I'm sorry there haven't been updates. I WILL build a 1JZ 240Z in the future.
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
240Z Hemi Swap ? Dave Moritz Other Engines 12 July 16th, 2009 08:27 PM
240z 1jz 0n the way!! timbo1jz New Members Forum 1 December 3rd, 2007 09:47 PM
Q: RB25DET swap in '73 late model 240Z 240_Skyline Nissan RB Forum 17 August 25th, 2007 04:48 PM
I'm doing a typical 350 swap into a 73 240z and wondering milo240z Gen I & II Chevy V8 Tech Board 3 April 20th, 2005 01:55 PM
finished BW t-5 into 240z turbo swap, now some clutch noise mobythevan Drivetrain 2 August 19th, 2003 10:17 PM
Powered by vBulletin® Version 3.8.1
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
