Go Back   HybridZ > Technical > V8 Z Forums > Gen I & II Chevy V8 Tech Board
Gen I & II Chevy V8 Tech Board Discussions of technical related subjects pertaining to Chevy V8Z's
Reply
Thread Tools Display Modes
Old April 15th, 2008, 11:32 AM   #1
dts300z
Member
dts300z's Avatar
dts300z is on a distinguished road
Default turbo lt1 300z (pictures)
Just finished up the turbo kit this past weekend!
dts300z is offline   Reply With Quote
Old April 15th, 2008, 01:30 PM   #2
deja
Member
deja's Avatar
deja will become famous soon enoughdeja will become famous soon enough
Default
Co-o-o-o-ol!!! It fits pretty nicely in there. But I see no alternator????
__________________
'77 280Z - Newly built LT1 4 bolt main, LT4 hot cam kit. 4L60E/Transgo shift kit. 300ZX LSD, 280ZX CV axles. Silvermine Stage 4 front brakes - MM rear disc brakes. 2905 lbs with a full tank.
deja is online now   Reply With Quote
Old April 15th, 2008, 01:46 PM   #3
dts300z
Member
dts300z's Avatar
Default
you can't see it from any of those angles... lol what are the chances
Old April 15th, 2008, 05:49 PM   #4
rustorbust
Member
rustorbust will become famous soon enoughrustorbust will become famous soon enough
Default
Is that a t70, have you done anything else to the motor. Let us know how it runs?
rustorbust is offline   Reply With Quote
Old April 15th, 2008, 05:51 PM   #5
DavyZ
Super Moderator
DavyZ's Avatar
DavyZ is just really niceDavyZ is just really niceDavyZ is just really niceDavyZ is just really niceDavyZ is just really nice
Thumbs up
VIDEOS! WE NEED VIDEOS! Nice work in making all of that fit. It should run like a raped ape when complete
Davy
DavyZ is offline   Reply With Quote
Old April 16th, 2008, 05:26 AM   #6
dts300z
Member
dts300z's Avatar
Default
Quote:
yup its a Master Power T70... .96 A/R exhaust, It is a stock engine for now hehee... I am actually driving it today and it is pretty violent around 3200 rpm. Its only around 4psi till I can get it up on the dyno. I have an FMU on it until I can put some injectors in it. I really need some tires on this thing now... I'll be at the shop this Sunday to dyno it and I'll video it and post it up for you guys.
Old April 16th, 2008, 07:53 AM   #7
deja
Member
deja's Avatar
Default
Ok there it is, thought maybe you were build and drag car running on battery only. Or some weird driveshaft driven alternator like that crazy NASCAR fuel pump, LOL.
Quote:
__________________
Old April 21st, 2008, 08:28 AM   #8
dts300z
Member
dts300z's Avatar
Default
here is a video... 130k and too much timing showed its ass hahaaa... enjoy http://videos.streetfire.net/video/T...0ZX_158121.htm
Old April 21st, 2008, 11:47 AM   #9
rustorbust
Member
Default
Man thats awesome for only 5.5 lbs. Get a good head gasket in there and that thing should be an monster. Is it a t56 or a tko transmission?
James
Old April 21st, 2008, 01:21 PM   #10
PrOxLaMuS©
I need a hug...
PrOxLaMuS©'s Avatar
PrOxLaMuS© is an unknown quantity at this point
Default
wow awesome work!!
that looks great! a few hours with a wire brush and some paint on the exhaust could do wonders!!
sorry to hear about the HG! =(
__________________
Currently on a rotisserie for a full restoration - L28 with 9mm rods, 88mm Ross pistons (3.0L), 8.5:1 CR, Schneider Stage II cam, Holset HY35W, Megasquirt, Suzuki GSXR ITB's and home made intake plenum, Z32 transmission, Fidanza aluminum flywheel, ACT stage II clutch and pressure plate, coil-overs, vented 4x4 front brakes, 240sx rear brakes, Corbeau FX1 Pro seat, (soon to be half cage) and still debating the paint.. hurm
PrOxLaMuS© is offline   Reply With Quote
Old April 21st, 2008, 01:22 PM   #11
Slow_Old_Car
Member
Slow_Old_Car is on a distinguished road
Default
going to make any kind of a screamer pipe so that it's not going to atmosphere right around all those lines?
what was up w/ trimming a vacuum hose and then seeing a boost increase?
Slow_Old_Car is offline   Reply With Quote
Old April 21st, 2008, 02:24 PM   #12
dts300z
Member
dts300z's Avatar
Default
James
Thanks, I have a T56 behind it... can't wait to get some gaskets back in her
Old April 21st, 2008, 02:29 PM   #13
dts300z
Member
dts300z's Avatar
Default
Quote:
Originally Posted by PrOxLaMuS© View Post
wow awesome work!!
Thanks again! yea it needs a little touch up.. I might do some ceramic coating on all the hot stuff...
Old April 21st, 2008, 02:44 PM   #14
dts300z
Member
dts300z's Avatar
Default
yea I forgot to order the piping for the dump tube... lol yea thats kinda a cheapy boost controler. If you put a tee with a long vac hose on it (about 2' to start to be safe) between the wastegate and the manifold it acts like a bleeder valve. The longer the hose the less increase in boost or none depending on the length.. the shorter the more it bleeds off and the boost goes up and too short and it goes BOOM!!! lol
Old April 21st, 2008, 03:35 PM   #15
Slow_Old_Car
Member
Default
makes sense, never seen it done before this though.
Old April 21st, 2008, 03:37 PM   #16
deja
Member
deja's Avatar
Default
That sound down right evil! Glad someone else asked about the hose cutting thing, LOL. Bummer about the head gasket, but I guess stock just can't cut it even at 5.5 boost.
__________________
Old April 21st, 2008, 03:44 PM   #17
N20Jeep
Member
N20Jeep is on a distinguished road
Default
badass....cant wait to see this car out on the streets...i remember seeing this thing parked out infront of stage6 for the longest time..
N20Jeep is offline   Reply With Quote
Old April 21st, 2008, 04:11 PM   #18
dts300z
Member
dts300z's Avatar
Default
Quote:
yea, I kinda failed to mention that it did overheat slightly before this and that may have contributed to the outcome.... They should hold somewhere around 8-10psi but this again is an ASSumption.. lol
Old April 21st, 2008, 04:31 PM   #19
dts300z
Member
dts300z's Avatar
Default
Quote:
yea I worked there for a while in the Argyle location... I have seen your screen name on a few of the local boards aswell..
Old April 23rd, 2008, 07:27 PM   #20
dts300z
Member
dts300z's Avatar
Default
Well it looks like 5.5psi is not the limit of the stock head gaskets.... It just split at the coolant passage.... Time for some cometics, stud kit and possibly more goodies.... hehe
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
The Ultimate Turbo FAQ/Beginners Guide Drax240z Turbo / Supercharger 38 April 21st, 2009 08:48 AM
Problem with Turbo...leaking !!! Turbo Experts Dayz Turbo / Supercharger 8 June 5th, 2006 03:14 PM
RX7_HT18S-2S Turbo Question?????Please Help dilop Turbo / Supercharger 0 July 26th, 2004 10:45 AM
Need advise on a 300Z twin turbo rear end swap from stock. LS1240Z Drivetrain 7 December 15th, 2003 05:16 PM
Twin Turbo LT1 discussion on Camaroz28.com JAMIE T Gen I & II Chevy V8 Tech Board 4 January 14th, 2002 09:47 AM
Powered by vBulletin® Version 3.8.1
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
