Go Back   HybridZ > Technical > 6 Cylinder Z Forums > Toyota L6 Forum
Reply
Thread Tools Display Modes
Old September 8th, 2009, 09:16 PM   #241
Garrett76Zt
Member
Garrett76Zt's Avatar
Garrett76Zt is an unknown quantity at this point
Default
yea i remember watching that a few years ago.
__________________
'76 280z - L28et (3.0 liter w/ forged pistons) - "Blowzilla" T3/T4 Turbo - 3" Exhaust - 70mm TB - SDS - 450cc Injectors - Custom Intake Manifold - Spearco IC - Meth Injection - STOCK HEAD/CAM
460whp 430ft lbs
11.248@124.17
Garrett76Zt is offline   Reply With Quote
Old September 10th, 2009, 09:37 AM   #242
mike321go
Member
mike321go's Avatar
mike321go is on a distinguished road
Default
and its still going strong!
mike321go is offline   Reply With Quote
Old September 22nd, 2009, 05:27 PM   #243
mike321go
Member
mike321go's Avatar
Default
As of Yesterday my car is TUNED..untill 2500rpms. for some reason it acts like it is hitting a rev limiter at 2500 rpms.... now I have talk to MANY professionals and everyone is scratching their heads.
Things i have Checked to see what could be cause it.
2step rev limit in AEM---OFF
Main rev limit in aem---8000rpms
sync status ---0 even if ignoring sync it still does it.
timing---set
fuel---set
can anyone add to the list of things i could check????? remember this is a series 2 EMS
Old September 22nd, 2009, 06:00 PM   #244
stony
RB Moderator
stony's Avatar
stony is an unknown quantity at this point
Default
You say you looked at timing and fuel but have you looked at those values in the boost pressure area. you could be starting to boost and if the boost cut is set at o or +1 wamo.... just something i learned a long time ago ;>
__________________
Unnatural Aspiration....turbo lag was invented to give V-8s a chance
RB26DETT, T88-34D, 30 PSI, full tune JUN head, 280 Cams W/ 10.30 lift, 1.2mm cometic Metal head gasket, custom intercooler, HKS Fcon V Pro engine management, 2 speed powerglide, Fully built Dana rearend, Ladder bar suspension,
Best 1/4 to date 9.10 @ 147mph
4 link car in the chassis shop now more updates soon
http://smg.photobucket.com/albums/v2...ompilation.flv
stony is offline   Reply With Quote
Old September 22nd, 2009, 09:02 PM   #245
mike321go
Member
mike321go's Avatar
Default
but this is happening at idol? no load? i guess technically i could be hitting boost???
Old September 22nd, 2009, 09:42 PM   #246
ShaggyZ
Terminator
ShaggyZ's Avatar
ShaggyZ is on a distinguished road
Default
You said it was fine until 2500 RPM, which isn't idle.
__________________
'77 280Z 2JZ-GTE in Progresso
'03 SV650S
ShaggyZ is offline   Reply With Quote
Old September 22nd, 2009, 09:54 PM   #247
mike321go
Member
mike321go's Avatar
Default
it runs GREAT!!!!! revs great..doesnt over heat or anything!!!
but when i hit 2500rpms it back fires and pops like crazy.
i meant In neutral i haven't driven the car yet.
Old September 23rd, 2009, 03:27 AM   #248
Gritz
Member
Gritz's Avatar
Gritz is on a distinguished road
Default
Check your coil packs, crank and cam angle sensors. Also a bad tps can cause issues like this.... One more thing what are your spark plugs gapped to? most 1j and 2j guys gap the plugs at .26-.28 only use NGK also.
Make sure the car has all the proper ground.. for example from the engine block to the chassy.
Ps if your car has been running like this for awhile, i would go with a fresh set of plugs, cause NGKs foul out like crazy..
__________________
88' Starion (18g,FMIC,3in exhaust at 15psi)
74' 260z (1jz On the way)
88' Mightymax (4g63T powered)
00' lexus ES300 (Daily Driver)
Gritz is offline   Reply With Quote
Old September 23rd, 2009, 07:47 AM   #249
stony
RB Moderator
stony's Avatar
Default
Can you take a video of it running and doing what you are describing.
__________________
Old September 23rd, 2009, 09:24 AM   #250
mike321go
Member
mike321go's Avatar
Default
i will get a vid today!
Old September 24th, 2009, 11:09 AM   #251
mike321go
Member
mike321go's Avatar
Default
HERE IS THE VIDEO OF MY REVVING PROBLEM!!!!
LET ME KNOW WHAT YOU GUYS THINK!!
http://videos.streetfire.net/video/O...ems_708824.htm
Old September 24th, 2009, 11:17 AM   #252
stony
RB Moderator
stony's Avatar
Default
definitely sounds like a rev limiter of some sort. if you have checked everything i would suggest contacting AEM and ask some questions
__________________
Old September 24th, 2009, 11:25 AM   #253
ShaggyZ
Terminator
ShaggyZ's Avatar
Default
Did I really just watch a 15 second ad before watching your video!?
__________________
'03 SV650S
Old September 24th, 2009, 11:26 AM   #254
stony
RB Moderator
stony's Avatar
Default
mine was for a Klondike bar :>
__________________
Old September 24th, 2009, 01:34 PM   #255
mike321go
Member
mike321go's Avatar
Default
lol ya streetfire does that now!! its lame...you can fast forward through them tho.... I have talked to AEm multiple times and they are kinda scratching their heads and want me to try someone elses ems at this point in time....but its kidna hard to find someone willing to unplug their box.
Old September 24th, 2009, 06:29 PM   #256
stony
RB Moderator
stony's Avatar
Default
Can you send it to AEM and have them set everything to zero??? tell them what it is doing and have them look thru everything. other then that not sure what to tell you. But it for sure sounds like a rev limiter. your boost gauge was acting kinda funny to. looks like it started to build boost then lost it. if the pedal wasn't lifted that might be an issue to. you shouldn't be bouncing around like that.
__________________
Old September 24th, 2009, 06:35 PM   #257
mike321go
Member
mike321go's Avatar
Default
i was lifting the pedal case the car was cold
Old September 24th, 2009, 06:40 PM   #258
ARZ_
Member
ARZ_'s Avatar
ARZ_ is on a distinguished road
Default
It sounds like you have the firing order wrong. 1,5,3,6,4,2 will idle fine and do EXACTLY what yours does in the video.
You state that it runs fine until 2500 but if you have it floored until it gets to 2500 I think that sounds like CRAP. Also watching your boost gauge, supports my theory. WOT at that kind of acceleration rate wont build boost unless you have unburnt fuel getting into the exhaust and igniting there. Thats why the longer you stay on the throttle the more it appears to build boost.
Hope this helps, please keep us posted. Obviously its supposed to be 1,5,3,6,2,4
Also are you going WOT when it accelerates? Or are you easing into it? Please let us know.
__________________
1971 240Z 7MGTE 60-1 powered, 2505 lbs, 487 rwhp 473 torque @ 23 psi, 11.7 @ 125, it was my first and only time, they kicked me out. Build thread
1970 240Z 2JZGTE T76 powered sub 2100 lbs (Street legal track car in work=collecting parts)
ARZ_ is offline   Reply With Quote
Old September 24th, 2009, 07:47 PM   #259
ShaggyZ
Terminator
ShaggyZ's Avatar
Default
I think that's a great guess. That idea was on the tip of my brain but couldn't get it out.
__________________
'03 SV650S
Old September 24th, 2009, 08:57 PM   #260
mike321go
Member
mike321go's Avatar
Default
i dont think so...when its warm it idols extremely smooth with no hicups or anything.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Won't Start RockyB12 Nissan V6 Forum 9 December 19th, 2006 05:24 PM
Car wont start! Ran fine, now not so fine...HELP PLEASE! george.bryant Nissan L6 Forum 6 November 15th, 2006 10:16 AM
Sell and start over, keep and start over, keep and start another project. ON3GO Non Tech Board 12 February 28th, 2006 07:56 AM
STILL hard to start - getting interesting E.Murray Gen I & II Chevy V8 Tech Board 14 May 14th, 2005 03:49 AM
can't get the motor to start (the fun begins, stock 73' Z) 73Turbo240z 6 Cylinder Z Forums 0 January 13th, 2005 12:43 AM
Powered by vBulletin® Version 3.8.1
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
