Go Back   HybridZ > General > Members Projects > S30 Series - 240z, 260z, 280z
S30 Series - 240z, 260z, 280z A forum where members can post pictures and descriptions of progress on their project cars.
Reply
Thread Tools Display Modes
Old July 11th, 2008, 12:22 AM   #1
speeder
HybridZ Supporter
speeder's Avatar
speeder is on a distinguished road
Default Rick's Widebody Tilt Front Buick Hybrid
New changes are about to get going for real, so I figured I'd start to document my project.
The flared/tilt front body I as shown in my old, soon to be up dated website (sig url) was my starting point. Late last year I completed tilt/widebody II as in my sig using the Reaction Research 280YZ kit as a base. I'll add body construction pictures to this thread later. I built the body to accommodate up to 335 width tires at all 4 corners.
I have a crappy Safety Devices 6- point bolt - in roll cage installed that will be professionally redone. Cobra Daytona seats will replace the bulky Cerullo couches currently installed.
The car is currently powered by a Turbo 3.0l stroker L with ~ 420 rwhp , with a G- force T5 transmission and 3.69:1 R230 rear. All this is being removed and will be for sale (Shameless plug).
I have sectioned struts with Tokico Illumina shocks/coilovers installed, and Ground Control camber plates at all 4 corners.
The motor will be replaced with a 260 ci (about 4.3 l) twin - turbo Buick Stage II that has been under construction for over 2 years. I made the V6 choice because I liked the idea of a short motor that can be set far back in the chassis, giving good weight distribution and lots of room for the top/front mount turbos. The Stage II was chosen because of its power production capability - My realistic goal is horsepower in the 4 -figure range, at torque numbers that blow away any wimpy 2J or RB. Please, don't even start on me about "needing" that much. Of course I don't, and that's not even relevent.
My engine is a real mutt - The 4.005" bore block was originally from a Mclaren Indy racer, The billet odd-fire 3.450" stroke crank (by Hank the Crank) is from an unknown Trans Am racer, and the rods are old 6.5" Busch Grand National I- beam Oliver pieces. Turbo pistons are custom JE. The heads are BMS Stage II aluminum pieces, with 2.005" intake and 1.65" exhust valves. The intakes flow 310 cfm at the .615" lift that my custom Comp Cam provides. The valve train is composed of Comp roller lifters and T&D 1.65:1 roller rockers. A four stage Weaver dry sump pump provides lubrication. An ARE road race aluminum dry sump pan allows the engine to sit low in the car. There are some really beautiful surplus race parts in this motor. The almost 1.9:1 rod-stroke ratio will make this a rev monster - but it will probably be red-lined at 8500 or below.
Engine management will be Electromotive TEC3r. I have modified a Busch Victor 4- barrel intake manifold to have a holley pattern, progressively linked secondary 1600 CFM throttle body and 2- sets of 85 -pound Delphi Injectors, each set with its own twin Walbro fuel pumps/Aeromotive regulator. Injector staging will run the engine on the primary injectors until a set boost/rpm is reached, then bring the secondaries into operation. Eventually I will have a fuel cell for each bank of injectors, with the secondary tank loaded with C16. Ignition will be with 6 coils.
Turbos are T4 60-1s, .7 a/r turbines. I plan on running 3" exhausts into the rear fender wells and under the side skirts of the car, exiting in front of the rear wheels. I will replace the brake booster with a balance bar non -boosted setup (my Wilwoods are overboosted as it is) and relocate the battery to the rear to make room for the exhausts to exit into the rear fenderwells.
For the drive train I have a really cool NASCAR magnesium reverse - mount starter bellhousing and a hopped up Borg Warner T10. This synchro 4-speed tranny was built for a Nascar road racer - and has a claimed horsepower rating of 800 in a fat stock car. I have a Jerico Dog box standing by if this breaks. The clutch is a twin 7.25" carbon disc unit from Quartermaster with a hydraulic throwout bearing. I have a Technotoy tuning rear setup with shortened Z32TT CVs and wheel hubs ready to install with Dan's sweet tubular rear control arms. A 2.93:1 R230 is built and ready to install. Custom 13/12" CCW wheels will be ordered as soon as the rear suspension is done.
I'll add more BS and pictures as I get time and as the build progresses.
__________________
Rick Bowers
'77 280ZT (Not as fat as I thought) - Awaiting 260ci Twin Turbo Buick Stage II - Finally out of machine shop jail after 2+ years!
'78 280Z (Soon to be for sale)
2002 Lexus IS300 - Turbo 2JZ, 6-speed - daily driven monster.
"Speed costs - How fast do you want to spend?"
My build thread: http://forums.hybridz.org/showthread.php?t=136300
Old body shown in obsolete website:
Rick's 280ZT AKA: "Porkchop"
speeder is offline   Reply With Quote
Old July 13th, 2008, 10:30 AM   #2
speeder
HybridZ Supporter
speeder's Avatar
Default Buick Stage II Adventure
Most of this thread will probably be about the motor for a while. I just went to the machine shop to visit my baby and the rotating assembly was being balanced. From here all there is to do is to assemble the engine and set up the valvetrain. There is no excuse for him taking so long on this, but great status!
There have been major problems with the engine build - Scottie-GNZ and I picked up the Stage II in Atlanta shortly after Christmas, 2006. The original configuration was a carbureted 14:1 cr 274 ci dirt track motor.
I knew I would have to replace the pistons and cam for turbo duty but was really negligent in checking other things, such as head volume necessary to get the compression down to some kind of turbo - friendly number.
Turns out there was no way I could use the heads supplied with the engine - chambers too small. I located a pair of heads with suitable chamber volume - pristine new with big chambers and all the roller valvegear included. Of course, the titanium valves were not suitable for turbo use, so they were replaced with high -end Ferrea units. ($).
I found some "bargain" Ross forged pistons on ebay - they needed to be fly-cut to have the right valve reliefs for my build, but looked like they would do. Looked like I caught a small break on build cost. More on this later.
Next was cam selection. On the advice of a knowledgable Buick racer that Scotty recommended, I called Comp Cams, where an extremely helpful Tim Cole helped me design my cam. Of couse, there are no more odd-fire blanks available, so a billet build is necessary. (=$. This is the start of a troublesome trend.) On his recommendation, I went with a larger base circle since the Buick V6 cams have really small lobes and are known to have cam/lifter durability problems. I knew this would necessitate a line-bore, but didn't consider another consequence:
Now the rods hit the cam when the engine was mocked up. Too much interference to eliminate by trimming rods. One rod was trimmed in the attempt, and the machinist was uncomfortable with using it, so I had to find another Oliver rod.
Since trimming the rods was not working for us, the next step was to destroke. I hit the Buick internet community and found a guy who would trade my 3.650 stroke crank for a 3.590 one. Our calculations showed this would clear, but we were worried about how much. OK, now there is no interference but not enough clearance. Back to the Buick boards and the perfect crank was found - 3.450", Biilet, standard/standard. This one cost me, however. I did recover some of my purchase price by selleng the old one.
Now the bottom end clears, but the pistons are too far down the hole. New piston time. After looking at the Ross ones we didn't like the top thickness or the ring land configuration for turbo use, so even if I was spending more $ we got to specify some massively strong JE units, with the correct dish to get compression down to 8.2 or so.
I don't know if I would have selected this power plant had I known what all was involved - WAY too late to turn back now - but it will certainly be something that you don't see in everyone's Z car.
__________________
Rick Bowers
Old August 2nd, 2008, 12:17 AM   #3
speeder
HybridZ Supporter
speeder's Avatar
Default Pictures of the Intake
http://forums.hybridz.org/showthread.php?t=118128
I really have to stop making cute titles to threads....
__________________
Rick Bowers
Old August 2nd, 2008, 09:30 AM   #4
johnc
Administrator
johnc's Avatar
johnc is a splendid one to beholdjohnc is a splendid one to beholdjohnc is a splendid one to beholdjohnc is a splendid one to beholdjohnc is a splendid one to beholdjohnc is a splendid one to behold
Default
I edited the title for ya...
__________________
John Coffey
johnc@betamotorsports.com
BetaMotorsports, LLC
Once more unto the breach, dear friends, once more,
Or close the wall up with our HybridZ dead!
In deciding for those who cannot decide,
Or educating those who will not listen,
There's nothing so becomes a man
As modest stillness and humility;
But when the blast of indecision and ignorance blows in our ears,
Then imitate the action of the tiger:
Stiffen the sinews, summon up the blood...
...Follow your spirit, and upon this charge, Cry "God for HybridZ, Datsun, and Horsepower!"
johnc is offline   Reply With Quote
Old August 3rd, 2008, 07:48 PM   #5
speeder
HybridZ Supporter
speeder's Avatar
Default
Umm, Thanks John, I think.
Highbroad?
__________________
Rick Bowers
Old August 4th, 2008, 08:50 AM   #6
johnc
Administrator
johnc's Avatar
Default
Sorry, dumb joke.
__________________
John Coffey
Old December 24th, 2008, 08:21 AM   #7
speeder
HybridZ Supporter
speeder's Avatar
Default Update
Checked out the engine a couple days ago and it's all together! They are working a few more external details like oil pan scraper clearance but promise to have it ready before the new year.
I took that opportunity hang my twin turbo headers on to take some measurements and do some preliminary planning for the swap - looks as if it will fit with minimum cutting on the car. My main concern is the width of the headers between the strut towers and where the turbos will be positioned. Exhaust plumbing will be a challenge.
I will likely have to build custom accessory drives for alternator and AC compressor - hoping the existing dry sump drive will fit.
Swap Meister Scottie-GNZ has offered to help with engine conversion mounts - That expertise will be very much appreciated.
I'm in the process of stripping the car's engine bay - Have a front crossmember that has the control arm pivots relocated and the Datsun mount towers cut off.
Everywhere I look there's something to be fabricated/ trimmed to fit.
I still need to build a front mount for my R230 - Would have liked to buy the Technotoy one but it doesn't fit my Armada cased R230.
All the Technotoy rear with custom tubular control arms is installed, with Arizona Z-car Z32 rear Wilwoods.
The car is now sitting on new CCWs - 12X18 rear, 11X18 front w/Shot peened black anodized centers/polished rims. Tires are 335/30-18 and w/275/35-18 Toyo RA1s
Pictures soon.
__________________
Rick Bowers
Old December 28th, 2008, 08:15 PM   #8
DavyZ
Super Moderator
DavyZ's Avatar
DavyZ is just really niceDavyZ is just really niceDavyZ is just really niceDavyZ is just really niceDavyZ is just really nice
Default
This one is going to be AWESOME! Those wheels & tires are huge---it'll look so mean I can't wait
Davy
DavyZ is offline   Reply With Quote
Old January 20th, 2009, 10:16 PM   #9
speeder
HybridZ Supporter
speeder's Avatar
Default Almost out of jail
My engine is almost ready to come home! Can't wait to start hanging turbos, dry sump pump, etc on this baby, then attacking the fabrication to get it into the Z.
There is still a formidable amount of work to do getting the car ready - but I feel like progress is picking up.
N
__________________
Rick Bowers
Old February 9th, 2009, 08:36 AM   #10
speeder
HybridZ Supporter
speeder's Avatar
Default
Back from Jail. No time right now to work on the conversion , but I just had to hang those turbos on to see how it looks.
Looks as if there will be some mods to the headers required, but the turbos should fit just ahead of the strut towers. Exhausts will be a challenge.
__________________
Rick Bowers
Old March 22nd, 2009, 07:10 PM   #11
speeder
HybridZ Supporter
speeder's Avatar
Default CCWs on, slowly getting ready to swap.
I'm making slow progress with the swap - The dual brake master install is in work - That and the rear mount battery will make room for the twin exhausts to dump into the fenderwells.
Next is installation of the front crossmember with shaved motor mount towers and relocated control arm pivots.
After the above is done, all that remains before building motor mounts is front diff mount fabrication.
Pics of the CCW wheels - Shot -peened anodized centers, 12X18 rear, 11X18 front. Tires are Toyo RA-1s, 335/30-18 rear, 275-35-18 front.
I threw the R230 in the back just to make the rear sit lower, but it needs that lump in the front to get the stance right!
__________________
Rick Bowers
Old July 20th, 2009, 08:21 AM   #12
speeder
HybridZ Supporter
speeder's Avatar
Default Rear Suspension, other preps for swap done
Back to work. To make room for the fenderwell exhaust exits, and to reduce sensitivity of the brake pedal for my Wilwoods, twin Tilton masters with balance bar are installed.
Front crossmember's motor mounts shaved and control arm pivots relocated
Right side tool box area cut, welded and seam-sealed for Armada-cased R230 mounting ear clearance.
Front diff mount built
What a pain to build that, had to lift the 125 pound diff in and out about 10 times. The Armada case has wider spaced mounting ears than the Z32TT case, necessitating more cutting and a more complicated diff mount.
Here's the mount installed.
And finally , the end result - The R230 mounted with full TTT setup and Dan's sweet rlcas:
I'm working on getting the motor outfitted with all the major protruberences (drysump pump, etc.) so we can begin engine bay placement and motor mount build.
I had made some rough measurments that told me that the turbo placement would put them into the sides of the inner fenderwell, so I have modified the headers rather than cut on the car. Headers are now at the tig welder's to receive V-bands and right angle adaptors - Will give great flexibility in making the turbos fit and getting good angles for the twin 3" downpipes. I'll post pictures when done.
Next step is to take the car to Scottie's tomorrow for engine mount installation. I'm excited to be this far - Will be too cool to see the engine in its new home!
__________________
Rick Bowers
Old July 21st, 2009, 07:45 PM   #13
speeder
HybridZ Supporter
speeder's Avatar
Default
Car, engine, and transmission are at Scottie's - We begin measurements for motor mount construction tomorrow.
__________________
Rick Bowers
Old July 25th, 2009, 03:48 PM   #14
speeder
HybridZ Supporter
speeder's Avatar
Default Fit Test and mount mockup
Spent some quality time with Swapmeister Scottie today - We got the trans mount mocked up with "just" a minimum of cutting on the car.
That V6 sure looks tiny in there. I do have some plans for all that space up front, however....
__________________
Rick Bowers
Old July 29th, 2009, 05:42 PM   #15
speeder
HybridZ Supporter
speeder's Avatar
Default
Tranny Mount is built, Motor mounts are mocked up. Pics soon.
Saw Z-Gad on the road yesterday and he remarked "Well, now that it's at Scottie's we'll see some progress."
There are still lots of things to fabricate, hammer, and ortherwise make fit, but it's getting far enough along to start looking doable. Talk about underestimating the scope of a project...
__________________
Rick Bowers
Old August 4th, 2009, 06:19 AM   #16
speeder
HybridZ Supporter
speeder's Avatar
Default
Yesterday the motor was fully supported by some really elegant Scottie-GNZ -designed cradle/mounts - Final welding being done as we speak.
A little hammering on the inner fenders and the headers/turbos fit! I was worried about wastegate room but it looks to be easy to fit. Note the V-banded angle adaptors for the header-to turbine inlet connections. The GN headers had to have this mod to mount the turbos inward in the Z's long - but - narrow engine bay..
I will have to angle the radiator to make room for air filters-
I have discovered that I will have to hammer/ mod the passenger footwell to clear my rear-mount starter and clearance the rear of the trans tunnel for my 1350-Ujointed driveshaft, but, with the radiator mod, those "appear" to be the last clearance issues.
__________________
Rick Bowers
Old September 11th, 2009, 08:39 AM   #17
speeder
HybridZ Supporter
speeder's Avatar
Default
The Z is back with me - I'm now working on clearance stuff, modifying the car to fit around the new drivetrain.
With the motor offset 1.5" to the left, the header on that side has clearance issues with the strut tower - I've cut a section out of the strut tower and will weld in a concave piece so that header can be removed/installed without raising the engine. After doing some hammering (but not cutting) on the strut towers, I belatedly thought that maybe I should install my strut brace before proceeding. Good idea, huh?
I have found that my triangulated strut brace will work with this engine, as well as having room for a 2" tall throttle body spacer to increase the plenum volume of the EFI converted Victor Intake.
Next I'll be removing the upper part of the core support and build a frame for the angled radiator.
__________________
Rick Bowers
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
240mph 240z? Jonas240z Miscellaneous Tech 103 January 29th, 2009 02:45 PM
Brake Balance FAQ johnc FAQs 0 August 28th, 2005 09:53 AM
Re:Olds V-8? (and some buick ID tips and facts) twoeightythreez Other Engines 1 September 20th, 2003 12:01 AM
fiberglass tilt front end zphreek Body Kits & Paint 11 May 11th, 2002 03:43 PM
Tilt front end Anonymous Brakes, Wheels, Suspension and Chassis 12 March 26th, 2000 02:01 AM
Powered by vBulletin® Version 3.8.1
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
