Go Back   HybridZ > General > Vendor's Forum
Vendor's Forum This board is for vendors to use for new product announcements, specials, group buys, specials of the month, etc. Members and vendors can use this board for technical support, request special products or toss out ideas for product development.
Reply
Thread Tools Display Modes
Old March 14th, 2009, 01:41 AM   #21
Gabriel Tyler
Junior Member
Gabriel Tyler's Avatar
Gabriel Tyler is on a distinguished road
Default
JustinOlson: We used the gussets to add in the triangulation and strengthen the lower control arms. We've got a ton of guys running cars in rally, so we try to build all our parts strong enough to handle the abuse. Anyone with our TC Rods can attest to this.
You guys asking about the LT-1 swap, if you need something custom, just let us know. It's very possible we can do a bit of re-design work to get the job done.
__________________
Gabriel Tyler is offline   Reply With Quote
Old April 9th, 2009, 09:26 PM   #22
240Z2NV
Member
240Z2NV is an unknown quantity at this point
Default
Going to chime in...
First, "Timing Is EVERYTHING". I would have jumped on these in a heartbeat, had I not already sourced mine.
Second, I have purchased many items from TTT, as well as had them section my struts. FIRST CLASS, Grade AAA, Top Of The Heap.
I wouldn't blink an eye at purchasing ANYTHING from Gabriel. His products are thoroughly engineered, and well-made, and VERY fairly priced.
Above all else, the Customer Service is beyond excellent...which is, sadly, very RARE these days.
__________________
Finally, a launch date. Project begins first week of Jan. '04!
MUCH slower and more expensive than planned!
'73 240Z LS1/T56/R230 street/road racer underway!
240Z2NV is offline   Reply With Quote
Old April 10th, 2009, 09:13 AM   #23
Armand
HybridZ Supporter
Armand is on a distinguished road
Default
Any lighter than stock LCA's?
__________________
-1971 Datsun 240z-SR20DET
Enjoy the most out of life, ride a bicycle!
www.green-cycles.com
Armand is offline   Reply With Quote
Old April 10th, 2009, 03:02 PM   #24
fentin_fury
Member
fentin_fury is on a distinguished road
Default
my $0.02 on TTT.....
Bought the Tension compression rods - one bound up and was unadjustable. TTT replaced it no questions asked - i shipped them the broken piece back.
Once i have more budget i will be buying these LCL.
Q
__________________
RB26dett, hks -GTRS(s), tomei rods, pistons, cams, ported head and power steering!
fentin_fury is offline   Reply With Quote
Old April 16th, 2009, 04:04 PM   #25
Gabriel Tyler
Junior Member
Default
Armand: These are just about the same weight as the factory units, if not half a pound heavier. We build for strength not for lightness. You guys are pushing envelope on horsepower, so we have to build with that in mind.
Thank you for the support, guys! It is good to hear our customer service is appreciated!
__________________
Old April 26th, 2009, 09:28 PM   #26
Z-Gad
Ludicrous speed, GO!
Z-Gad's Avatar
Z-Gad is on a distinguished road
Default
Just saw this thread..
I have the TTT rear end setup in the car and the only thing I feel I am missing is rear ALCA's...
Once I get a couple of other things set aside, I will be ordering a pair Gabriel.
Thanks for supporting this nitch market of ours!!
Mike
__________________
71 240z 2JZGTE TH400, 76mm turbo, 3.36 R200 rearend - 8.915 @ 153.60
TechnoToyTuning 2.94 geared R230 rearend - 9.038 @ 152.14 (so far)
http://album.hybridz.org/showgallery...00&ppuser=7981
http://videos.streetfire.net/video/a...e90005d70d.htm
02 IS300 Sportcross (daily)
07 Solar Orange 350Z Roadster (wife's car)
03 Ford Excursio-saurus 4x4 Diesel
A really bad want is a justifiable need ...
Z-Gad is offline   Reply With Quote
Old April 26th, 2009, 10:14 PM   #27
rsicard
Member
rsicard is on a distinguished road
Default
This gets back to the "A" design LCA versus the "H" design. The "A" design takes all the compression (bumps in the road) onto ONE heim joint. The "H" design distributes the compressive load by TWO heim joints aka twice as strong.
rsicard is offline   Reply With Quote
Old May 1st, 2009, 01:22 PM   #28
rsicard
Member
Default
Oh. Additionally the "A" design has a torsional load on the front heim joint as it must take up all the compressive load exerted by the strut.
Old May 1st, 2009, 02:29 PM   #29
JMortensen
HybridZ Supporter
JMortensen's Avatar
JMortensen has a spectacular aura aboutJMortensen has a spectacular aura aboutJMortensen has a spectacular aura about
Default
Quote:
The only way to put a torsional load on a heims joint is to exceed it's angular capacity, to bottom the spindle pin out on the race of the rod end. You're right that there is a torsional load on the STRUT, but it is the STRUT that takes that load. A single rod end cannot put torsion on the arm so long as it is not bound. More here: http://forums.hybridz.org/showthread.php?t=129154
__________________
Jon Mortensen www.m2differentials.com
No, we don't have any Z differential parts (yet). We have gears, lockers, limited slips, axles, etc for most American vehicles.
JMortensen is offline   Reply With Quote
Old May 1st, 2009, 03:12 PM   #30
rsicard
Member
Default
The force from going over a bump is transmitted to the strut and from the strut to the Forward heim joint which has the mass of the LCA to contend with. This puts a shear load on the strut pin, heim joint and strut that contains the pin/bolt. Yes the strut takes up the MAJORITY of the compressive load when going over a bump in the road. Yet there still is the shear load taken up by ONLY ONE heim joint with the "A" type design Rear LCA. That is what I was concerned with in the design of the "A" type design LCA i.e. it is not a FAIL SAFE design.
Old May 1st, 2009, 03:20 PM   #31
JMortensen
HybridZ Supporter
JMortensen's Avatar
Default
Define "fail safe". I'm not following you there.
__________________
Old May 1st, 2009, 03:56 PM   #32
rsicard
Member
Default
If one fails there is another to take up the load ala FAA Part 25 aircraft requirements. With the "H" design Rear LCA if one breaks there is another to assume the load.
Old May 1st, 2009, 05:43 PM   #33
JMortensen
HybridZ Supporter
JMortensen's Avatar
Default
Not really. If one of your H arm rod ends fails, the wheel goes any which direction. It's bad news. If the rod end on the A arm fails, same thing. Presumably the toe link would try to hang on, but the wheel would go any which direction also. I think what you are looking for is something where the rod end can fail and the suspension is relatively contained. Neither option does that. There were better pics on this thread that aren't available anymore http://forums.hybridz.org/showthread.php?t=123263, but suffice it to say that if a rod end fails in either instance there's going to be some staining of underwear.
__________________
Old May 4th, 2009, 11:10 PM   #34
Gabriel Tyler
Junior Member
Default
That's why we use rod ends with a 3/4" shank and a 5/8" bore with a 44,000lb tensile strength We use these same rod ends on all our suspension parts and they don't fail us even when we put a car into a concrete barrier!
__________________
Old May 9th, 2009, 09:35 PM   #35
Z-Gad
Z-Gad's Avatar
Default
Email sent, I need a pair
Mike
__________________
Old May 10th, 2009, 06:09 AM   #36
fentin_fury
Member
Default
Quote:
I try to avoid the walls.
Q
__________________
Old May 10th, 2009, 10:24 PM   #37
Z-Gad
Z-Gad's Avatar
Default
Payment sent... Let's see how these do in a straight line
__________________
Old June 3rd, 2009, 11:00 AM   #38
zilvia_gt
Member
zilvia_gt's Avatar
zilvia_gt is on a distinguished road
Default
When will these be available on the website as I plan on ordering some of your other products as well?
zilvia_gt is offline   Reply With Quote
Old June 4th, 2009, 02:14 PM   #39
junglist
HybridZ Supporter
junglist's Avatar
junglist is on a distinguished road
Default
Quote:
He has them listed on ebay for sale.
__________________
'72 240Z - under construction
'03 350Z - RIP
'95 Volvo 850 T5-R - the daily beater
junglist is offline   Reply With Quote
Old July 10th, 2009, 08:47 AM   #40
nazgule6
Member
nazgule6 is on a distinguished road
Default
hey guys these LCA's look very nice and im very intrested...i dont do much racing just daily driving and car shows but i would love to put these on my z it would look alsome...so my question is after i bolt these on do i have to adjust them to my likeing/setup or do them come already adjusted for stock lca's....also the guys that already purchased these...how are they?...they do they ride compare to stock LCA'S...are they easy to install/adjust....remeber i dont race so i won't be trying to kill them..but i would prefer and like them to ride like stock lCA'S...let me know
thanks..
nazgule6 is offline   Reply With Quote
Reply
Bookmarks
Tags
lower control arms, techno toy tuning
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
FAQ Acronym Page JSM FAQs 31 March 2nd, 2009 09:08 PM
72 240 rear control arms? sjhafa Brakes, Wheels, Suspension and Chassis 8 February 8th, 2005 03:17 PM
New rear lower control arm option and rear brace. mac Brakes, Wheels, Suspension and Chassis 7 December 19th, 2003 04:58 PM
Pics of rear adjustable lower control arm Anonymous Brakes, Wheels, Suspension and Chassis 7 November 22nd, 2000 10:12 AM
Seperating Rear Lower control Arms and stub axle alsil Brakes, Wheels, Suspension and Chassis 4 August 29th, 2000 01:47 AM
Powered by vBulletin® Version 3.8.1
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
