Go Back   HybridZ > Technical > V8 Z Forums > Gen III & IV Chevy V8Z Tech Board
Gen III & IV Chevy V8Z Tech Board Discussions of technical related subjects pertaining to Chevy V8Z's
Reply
Thread Tools Display Modes
Old May 27th, 2009, 04:50 AM   #1
Bigdeezs
Member
Bigdeezs's Avatar
Bigdeezs is on a distinguished road
Default Some pics n vids of Cali LSx Zs at the 1/4 track
Went to California Speedway's 1/4 track for Memorial day for some chillen, BBQ'n and racin. Three LSx Zs showed up along with a 469 rwhp RB26 Datsun.
Mine is the primer gray Z and USA3776 is the blue one(didnt run). ColtGT4g63, with the orange Z came all the way up from San Diego with some buddies to run his!
The air temp got up into the low 80s and density altitude was about 3600ft at midday but I still was able to run my new best of 11.470@122 with a 1.843 60ft (on 235/45/17 Continentals): http://www.youtube.com/watch?v=PfkXmskhvfY. I also got about 25mpg on the 140 mile roundtrip (not including racing).
ColtGT4g53 ran a best of 10.9@124 with a 1.563 60ft! (hope you dont mind me posting this Dave ) http://www.youtube.com/watch?v=CsEhUqub2Yc
oops howd that get in there
This was the RB26 Datsun...one of coltgt45's buddies from San Diego also. He had some issues but got a few runs. Not sure what his best was.
__________________
1975 LS6 Datsun complete(420rwhp NA)...1995 LS1 Blazer complete(360rwhp NA)
Datsun going 11.4@122: http://www.youtube.com/watch?v=PfkXmskhvfY
Bigdeezs is offline   Reply With Quote
Old May 27th, 2009, 06:58 AM   #2
janaka
Member
janaka is on a distinguished road
Default
Dear lord those thigs squat!
Very nice photo's!
Looks like a blast!
__________________
'76 Datsun 280z-------- '74 Datsun 260z 2+2
LS1/T56 swap ----------L26, cam, exhaust
11.77@119.98 ------------Full skirt kit
363hp/353tq -----------Headlight covers
janaka is offline   Reply With Quote
Old May 27th, 2009, 07:14 AM   #3
blueshark123
Member
blueshark123 is on a distinguished road
Default
Very nice pics and nice times! Ill have to take a look at the vids when I get home. So you managed to cut a 1.843 60ft on a 235/45/17 street tire?? What tires and setup is ColtGT4g53 running if you dont mind me asking?
blueshark123 is offline   Reply With Quote
Old May 27th, 2009, 07:49 AM   #4
Magnum380Z
Member
Magnum380Z's Avatar
Magnum380Z is an unknown quantity at this point
Default
good videos it looks like you guys had some good times !
Magnum380Z is offline   Reply With Quote
Old May 27th, 2009, 11:49 PM   #5
ColtGT4g63
Member
ColtGT4g63 is on a distinguished road
Default
Those are some awesome pics! Of course I don't mind you posting my times / video's. That's what they're there for.
Quote:
I've got some 26 x 8.5 x 15 Mickey Thompson ET drags mounted on some stock wheels. I'm using the MT tubes as well, along with some summit racing wheel Bolts to keep the rim from spinning inside the tire. Rear suspension is Tokico blue struts with QA1 175lb spring rates. The springs are sitting on some Cosmo coil over adjustable sleeves. And diff set up is the Q45 with custom axles.
Chris had a SERIOUS launch before his car broke. I swear, one more mm and the front tires would be off the ground.
__________________
71' 240Z
LS1 / T56 / Q45
10.9 @ 124 N/A
ColtGT4g63 is offline   Reply With Quote
Old May 28th, 2009, 06:04 AM   #6
Gr8White
Member
Gr8White is on a distinguished road
Default
Nice times, gives me some hope that I'll be able to hook mine up too!
Gr8White is offline   Reply With Quote
Old May 28th, 2009, 07:34 AM   #7
jgkurz
Slowest Indian
jgkurz's Avatar
jgkurz is on a distinguished road
Default
Having a street driven Z that run's 10's is impressive. Your car gives me hope I can get into the 10's if I go to the ET drag tires. Is your car certified for the 10's (roll bar, driveline lop, etc...) If not, did the track officials hassle you?
__________________
-John
My Z
jgkurz is offline   Reply With Quote
Old May 28th, 2009, 08:22 AM   #8
blueshark123
Member
Default
Very nice! What mods do you have done and how much power are you making? What are your front spring rates?
Old May 28th, 2009, 09:08 AM   #9
ColtGT4g63
Member
Default
Quote:
Thanks dude, I have an 8 point cage, harnesses, drive shaft loop, open lug nuts, metal valve stems/caps, fire resistant jacket, battery under the hood. Seems like I've got all that you would need, but the tech guy told me that I could not run under an 11.5 or else I would be kicked out. After running sun 11.5, 6 times in a row the lady who gives you the time slips told me that she was asked to check my car and make sure I've got a cage, and a fire jacket. Once she saw it she told me to go have some fun. Some people had big problems with the tech there, and some people passes with flying colors.
Front springs are a 125lb spring rate. I've got just about every bolt on I can get. I've got PRC stage 2.5 truck heads on there. CNC ported with biggie valves. Fast 92mm intake and PTM 92mm throttle body, Magic Stick 3 cam with a 113LSA, Dual 3" exhaust with an X pipe. 36lb / hr. injectors. I would guess I'm making somewhere in the 450 hp range. I'll be getting it dynoed sooner then later. I'm at the point where the next mod is going to get expensive, stroker motor... Super charger... Nitrous? Turbo again? Hahaha
__________________
71' 240Z
LS1 / T56 / Q45
10.9 @ 124 N/A
Old May 28th, 2009, 09:14 AM   #10
blueshark123
Member
Default
Ok so this was done NA. I love it. Go nitrous man the stock bottom end can take a 100-150 shot no problem and it's cheap. I'm hoping to run 10s NA as well and 9s with juice.
Old May 28th, 2009, 05:22 PM   #11
Bigdeezs
Member
Bigdeezs's Avatar
Default This Just In!!!
ColtGT4g63's run from the stands...
http://www.motorgen.com/vid/showphot...to/935/cat/535
(Dave if you want this vid (and maybe others) of your car in hi res I think they will email it to you if you sign up for their site)
same pics REAL BIG..lol: http://www.motorgen.com/pic/data/834/IMG_0045.JPG
http://www.motorgen.com/pic/data/834/IMG_0141.JPG
http://www.motorgen.com/pic/data/834/IMG_0044.JPG
http://www.motorgen.com/pic/data/834/IMG_0152.JPG
Me vs My girlfriends 2002 WS6: longtubes, lid, tune...makes 340rwhp (She's not allowed to be faster than me )
__________________
Old May 28th, 2009, 07:45 PM   #12
ColtGT4g63
Member
Default
I think nitrous will be my last resort. I like the whole idea of being able to start the car, put in pump gas and go. I don't want to have to worry about "re-filling" my horse power.
That video is sweet man!! I would love to get a Hi res copy of it. Just sign up and request it?
__________________
71' 240Z
LS1 / T56 / Q45
10.9 @ 124 N/A
Old May 28th, 2009, 08:53 PM   #13
Z-Gad
Ludicrous speed, GO!
Z-Gad's Avatar
Z-Gad is on a distinguished road
Default
Looks like a fun day
Congrats on the runs
__________________
71 240z 2JZGTE TH400, 76mm turbo, 3.36 R200 rearend - 8.915 @ 153.60
TechnoToyTuning 2.94 geared R230 rearend - 9.038 @ 152.14 (so far)
http://album.hybridz.org/showgallery...00&ppuser=7981
http://videos.streetfire.net/video/a...e90005d70d.htm
02 IS300 Sportcross (daily)
07 Solar Orange 350Z Roadster (wife's car)
03 Ford Excursio-saurus 4x4 Diesel
A really bad want is a justifiable need ...
Z-Gad is offline   Reply With Quote
Old May 28th, 2009, 10:34 PM   #14
Bigdeezs
Member
Bigdeezs's Avatar
Default
From what I've found they go out and film to get people to sign up for their website...I assume cuz they get more $$ from sponsors with more members (asside from the enjoyment and praise)...
Heres a quote from LS1tech:
A4Blk98SS
Teching In
My Garage
Trader Rating: 0
It was fun watching you guys race today. For everyone that came and got a sticker we got all of you at least once and in most cases multiple times. I took 62 videos total today including a couple with the 2010 Camaro. With any luck we should have them up at our site by the end of the week, so keep your eyes open. If anyone wants high resolution copies just send me a PM and I'll get it to you. In addition my wife too hundreds of pictures from the start area. Those should be up in about a week as well. Thanks!
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Track Car Progress, PICS mark Body Kits & Paint 156 December 17th, 2009 06:56 PM
On Track Pics of the new car... Mikelly Non Tech Board 7 April 16th, 2007 04:10 AM
More 1/4 Pics EvilRufusKay Body Kits & Paint 10 February 1st, 2005 06:35 PM
Going to 1/4 mile track thursday night Ivan280zt Turbo / Supercharger 23 October 12th, 2004 12:29 PM
LS1 Track day 11.4 1/4 mas28O Gen III & IV Chevy V8Z Tech Board 14 March 8th, 2004 01:25 PM
Powered by vBulletin® Version 3.8.1
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
