#21 |
Bawb Dawg
![]() ![]() Join Date: May 2006
The RB: Better Heads IMO Small Displacement Revvy Motor Similar Mounts/Easier Fab work. The 2J: More Displacement More Tractable power band (more torque provided you're not building a motor that is useless below 5k, but if you were I think you'd already know what route you'd be taking) Came Factory in the USofA... I think this is the most important, since the JZ came in a couple of USDM Toyota's, it's way easier to get parts in this country, and not have to wait for something rare... But it is kind of a heavy monster... 1J: Kind of a hybrid of both, revvy, less torque, but some 2J parts will swap over... It has a stronger bottom end IMO than the RB with a full counter crankshaft. Throw it all together and I'd say if weight isn't much of an Issue go 2JZ, there's already tons of aftermarket parts out there by US mfg's so you'll get direct support and even though I don't think it's head is quite as good, it's already been proven by many performance groups that it still has Zero problem making horsepower. |
#22 |
Member
![]() Join Date: Sep 2006
If you have the money for a 2jz swap... there is really no debate...easy choice...
__________________
88' Starion (18g,FMIC,3in exhaust at 15psi) 74' 260z (1jz On the way) 88' Mightymax (4g63T powered) ![]() 00' lexus ES300 (Daily Driver) |
#23 |
Member
![]() Join Date: Oct 2006
__________________
http://www.cardomain.com/ride/2559525www.bertollis.com www.myspace.com/mikegtech |
#24 |
Member
![]() Join Date: Dec 2005
Would you not be able to use the 200ZR parts to swap in a RB25/26?
| Bookmarks |
| Thread Tools | |
| Display Modes | |
