Go Back   HybridZ > Technical > 6 Cylinder Z Forums > Nissan L6 Forum
Reply
Thread Tools Display Modes
Old August 10th, 2009, 06:57 PM   #1
Butters
Member
Butters's Avatar
Butters is on a distinguished road
Smile need year models plz!?!?
I need some help getting year models of these 300zx, 300zxt, & 240sx. I need to know the year so i can get the diff for my car. Thanks for you time
__________________
76' 280zt "Porcha" fixen to be superchaged hopefully
http://www.cardomain.com/ride/3122027
Butters is offline   Reply With Quote
Old August 10th, 2009, 07:30 PM   #2
Xnke
Member
Xnke is on a distinguished road
Default
Go look under the hood. It's printed on the nameplate what diff and what year.
Xnke is offline   Reply With Quote
Old August 10th, 2009, 07:58 PM   #3
neotech84
Member
neotech84 is on a distinguished road
Default
+1
Ditto
check the door tag on them. the glove box might even have a book for you.
__________________
“Sometimes life seems like a dream, especially when I look down and see that I forgot to put on my pants”
Jack Handy
With 3 options, Fast, Cheep and Reliable...... You can have your choice of 2 but never 3!
Cheap+Reliable = Not Fast
Fast+Cheap = Not Reliable
Fast+Reliable = Not Cheap
98% of the time
neotech84 is offline   Reply With Quote
Old August 10th, 2009, 07:59 PM   #4
flatblack280
I have a thing for women who've been to prison...
flatblack280's Avatar
flatblack280 is on a distinguished road
Default
If you are looking for the LSD,
The Z31s need to be Kouki [87-89] turbo cars and those are all N/A Zenkis. Koukis have the single light bar on the back, they don't come down near the outside like the zenkis.
The blue car in this pic is a kouki, look for those lights and it'll say 'turbo' somewhere on the rear.
Not sure about the 240sxs. There are several diff lists with spine counts and gear listings, you just need to search.
If you do find one it'll have a finned diff cover.
__________________
Mat
'78 280Z Terbeaux - Flat top F54/P79 - RBs, MSnSE MSI V3.57, Volvo 740 FMIC, DXD Z33 Clutch
'86 300ZX Turbo - BW T5, Maxima Alternator, "L28ET Hauler"
Quote:
Originally Posted by D@H
Eh, if it isn't rear wheel drive or Nissan, Mat tends to be an ass about things if he doesn't agree with something.
flatblack280 is offline   Reply With Quote
Old August 11th, 2009, 11:06 AM   #5
Butters
Member
Butters's Avatar
Default
i would have not asked this if there were tags on the engine bay they were removed for some odd reason. maybe i should of mention this in the begging. sorry about that. but so that blue on is the one. cool that helps alot. but i'[m going to get that one and the one from the 40sx. but yes i do know i still need to research the years for the ratio. thank you guys again. atleast i do not have to drop every diff to find the one i won't but i might have to jsut to find the ratio...........
__________________
Old August 11th, 2009, 01:38 PM   #6
smokeybear
Member
smokeybear is on a distinguished road
Default
http://zilvia.net/f/archive-faqs/537...f-options.html
s13 diff options, read that it is good for years and what not for the 240sx option.
Also, I think the nissan VLSD has a blue sticker on the diff, I have been out the 240sx scene for a minute so bare with me.
smokeybear is offline   Reply With Quote
Old August 11th, 2009, 04:46 PM   #7
Xnke
Member
Default
The VIN tags likely got pulled, but the actual dataplates usually are not. Usually they are stickers on the hood or firewall.
Again, keep in mind that not every car has an LSD in it, they are pretty rare.
Old August 11th, 2009, 05:31 PM   #8
Butters
Member
Butters's Avatar
Default
glad my phone is bad ass enough to get the updates from here lol. cuz i was looking out there and started to look on the hoods that were there and around the firewall. thank you i did not know those tags were there! i have only delt with s30 so ya.....
ok the blue one had a open rear(86) as per the end cuz if i'm corret(& most the time i'm not on this kinda stuff) if you turn one wheel clock wise, the other wheel should turn counter clock wise. then still turning one wheel clock wise, then hold the other will still. only 1 wheel should spin.
but there is one car that showed up today lucky and it was the kouki but its a 10-86 so that makes it a 87 right. cuz don't the year split for cars. aren't they 6or7?? or is it earier then that??
so i tested the diff by spinning one wheel clock wise. low and behold the other wheel spun counter. but i did set on wheel on the gound and tried to turn the one that was up in the air. IT DID NOT SPIN. sooo dose that mean its a lsd ?????
I could not get to the 240 to check them so i have no clue on them
__________________
Old August 11th, 2009, 06:47 PM   #9
Xnke
Member
Default
Ok, when looking for a Junkyard LSD, turning the wheels on the car in the air is one way to figure it out.
NON LSD will spin in opposite directions.
LSD will spin in the same direction.
If you hold one wheel of a NON LSD differential still, WITH THE DRIVESHAFT DISCONNECTED, the other wheel will still turn.
If the driveshaft is connected still, it's gonna be pretty hard to turn just one wheel, since you are also turning the driveshaft and anything connected to it.
IF you hold one wheel of an LSD still, with the driveshaft unhooked, the other wheel will be really hard to turn. It MAY still turn, depending on the type of LSD.
Old August 11th, 2009, 08:30 PM   #10
Butters
Member
Butters's Avatar
Default
ok this one i think dose not have the drive line hooked up. but i was laying upside down so i might be backwards lol. i'll check sat after i get it out.
__________________
Old August 11th, 2009, 08:41 PM   #11
flatblack280
Default
I didn't post this earlier because I didn't know the exact facts, but the 87 cars only had it for certain months, look for the finned cover on the Z31s.
An '87' car made in 86 *shouldn't* have it. The information is out there you just need to search some Z31 sites or google. I'm pretty sure it's mentioned here as well.
Save yourself some effort jacking up cars and search
__________________
Mat
Old August 11th, 2009, 09:49 PM   #12
Butters
Member
Butters's Avatar
Default
i did use much effort at all jacking up the car i had a forklift
__________________
Old August 11th, 2009, 09:57 PM   #13
Butters
Member
Butters's Avatar
Default
ok that one had a smooth cover. but i thought i read some where in the sticky some where deep into the conversation. i found there was a guy that had a lsd that had a smooth cover ?? or did i jsut read it wrong. i'll go hunting again & again & again....oh and again did i mention again??
__________________
Old August 15th, 2009, 08:09 PM   #14
Butters
Member
Butters's Avatar
Default
well went to the junk yard today and told the guy witch diff i wanted. he told me that i could not have that one. so i told him i wanted to look at the diff from the blue 300 ( in the pics above) & asked to pull the cover off. i know it was a open anyways but. found it was a 3.90 ratio and its a 12 mm bolt carrier. so i'll jsut do my lsd swap later.
but i do have one thing to ask now... on this k r180 pic (thanks to jmortensen sticky) what is the purpose of the center peice between the gears????
i did not see a K on my diff housing so i jsut thinks its a r-200.
__________________
Old August 16th, 2009, 01:59 PM   #15
260Zz
Junior Member
260Zz is on a distinguished road
Default
240z 70-73 260z late 73-74 280z 75-80/1 280zx 81-83 300zx 84-87 or sumthin im not good with the 300s 240sx were 89-93 the one in the pics and the newer 300zx's were late 89 to like 96
__________________
1973 - 260z l28 245hp
260Zz is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
91 300z want to go sbc--help plz Powerskay Gen I & II Chevy V8 Tech Board 2 February 16th, 2009 09:16 PM
2008 South Florida Year End Picnic westpak Motorsports / Events 3 December 2nd, 2008 09:24 AM
280z Fuel Tank year difference? Jersey Fuel Delivery 8 March 13th, 2008 03:35 PM
CAD/CAM models of 280ZX available anywhere? avriette Miscellaneous Tech 9 November 2nd, 2006 02:08 AM
What year 5.0 engine is the best to get? Nemesis280ZX Ford V8Z Tech Board 16 March 23rd, 2005 10:00 AM
Powered by vBulletin® Version 3.8.1
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
