| 6 Cylinder Z Forums Discussions of technical related subjects pertaining to all types of 6 cylinder Z's. Forums are broken down into categories according to specific types of engines. |
Thread Tools | Display Modes |
#1 |
Member
![]() Join Date: Jul 2002
I purchased a wrecked 1994 tt six speed supra. I pulled the engine trans dash wiring tank lines rear supension wheels I have now bought: a tanabe downpipe massive extra thick griffin radiator, a set of supra non turbo rims and tires apexi avc-r boost controller a greddy bcc boost cut controller hks sequential blow off valve I might make a custom cross member like on my blue ls1 240z (Amir...,Darius..., where are you? Send pics!) or I may try to custom make forward mounts off of the 2jz-gte, this may be hard because I want to retain AC. I am going to mount the supra rear IRS (I have a 1994 viper rear suspension, too, but i think it is too heavy duty) in the Z too. Anyways I am in Hayward, CA and cannot locate a straight non rusty 240Z. Any help is appreciated... |
#2 |
Ludicrous speed, GO!
![]() ![]() Join Date: Feb 2001
Hey Cyrus, I too have aquired a 2JZ-GTE drivetrain. It finally arrived this week from Minnesota after waiting 3.5 months...Grrr...
Anyway, all is now good in who-ville. Here are the specifics on what I have and am doing... The bottom end was refreshed and has only 200 miles on it since rebuild. It was used in a Toyota pick-up drag truck. With a T-72 turbo at 28 psi, the truck dyno-ed 679 RWHP. I figure if I am going through the trouble of installing the drivetrain, I will not want to pull it apart right away. The head was not refreshed at the same time as the engine (found out afterdoing a leak down check ... Grrr again...), so I am refreshing the head, doing a little light porting, polishing, and adding a set of aftermarket cams (either 264's or 272's). I will be running the n/a 5-speed (until it breaks) and a 700 ft-lb sintered iron clutch (came with my drivetrain). The previous owner was running SDS, as will I (already installed in my car for the L28, so should just be plug-n-play for me). The drivetrain also included an unorthodox underdrive pulley (SDS magnets already installed), ported intake, dual feed -8 a/n fittings feeding 87 lb injectors and all accessories (alternator, starter, etc). It did not include turbo(s), but I wanted to go a little bigger anyway, probably a T-78. I am putting an L28 back into the car for the next SEZS event (because it took so long for the engine to arrive), but plan on beginning the swap after returning from Reynolds in March. If you get to the engine mounts before I do, lemme know how you decide to do them. If I get to them first, I will let you know. I hope to start a web page documenting the process in a couple of months.
__________________
71 240z 2JZGTE TH400, 76mm turbo, 3.36 R200 rearend - 8.915 @ 153.60 TechnoToyTuning 2.94 geared R230 rearend - 9.038 @ 152.14 (so far) http://album.hybridz.org/showgallery...00&ppuser=7981 http://videos.streetfire.net/video/a...e90005d70d.htm 02 IS300 Sportcross (daily) 07 Solar Orange 350Z Roadster (wife's car) 03 Ford Excursio-saurus 4x4 Diesel A really bad want is a justifiable need ... |
#3 |
Member
Very nice. Is that the 2jz i saw on ebay with the crazy header? I would strongly recommend a small turbo because the lag makes the car so spongey around town. I am used to NA power so I have no patience for a lagging ride.
I would like to know what you have in mind for the engine mounts. Lets keep in touch. |
#4 |
Super Moderator
![]() ![]() Join Date: Feb 2000
679 RWHP!!
#5 |
Member
![]() Join Date: Feb 2002
I put my drivetrain up for sale already and my buddy is helping me source a 2JZ drivetrain. I'll post up info as I go along but you guys are ahead of me at this point.
Marcos
__________________
Marcos 1971 240z Working on getting the 240z running. |
#6 |
Member
My goal is for this post to turn into the 2JZ-GTE installation post. Here is my contribution:
http://www.blkmgk.com/Development/TestWEB.nsf The 1jz install is similar. Thanks blkmgk |
#7 |
Thanks for posting the link. It made for good reading. The 2JZ I sourced was the one on Ebay, but after it did not sell, I contacted the seller and arranged a deal with him. It was exactly what I was looking for and set up for SDS as well. I am not too concerned about a laggy turbo. That can be overcome by running a smaller turbine housing, but really, how can a mid to high 10 second 3500 lb Supra be considered laggy
I ain't skeered!! I will not be doing any of the install process until after the SEZS event regardless. I also need to source a mid sump pan as mine is front sump... but I understand these to be plentiful... Anyway, I'll be in touch as well... mike P.S. Don't worry Mike, I can't compete with Scottie. His 1/4 mile knowledge is beyond sheer horsepower....but hey, James beat him, so who knows??
__________________
#8 |
Posts: n/a
Hey Cyrus, good to see your still going at it, cant wait to see that thing start to come together. as soon as you get a hold of that car or have anything you want me to publish, remember i dedicated as much of my server space as you need to put up stuff on your swap. write me an email if youve got anything you want me to do on there, or have any new pics to post. for anyone who hasn't seen pics of what he's got, heres a link to the pics im hosting for him so far:
http://www.240zconversions.com/supraswap.htm Enjoy, hope to hear from you soon. thanks for keeping this public, it will help many in the future guys! -Zach |
#9 |
Posts: n/a
Im also doing this swap...dropped my LT1 plans to go with a 2JZ (large single Turbo).
Ive been trying to locate a busted block (yea..they are rare) to do some mock up measurements for the motor mounts. Or has someone already done this? I heard that the stock mounts are way too far forward to be used...perhaps the JTR Setback plates could be redrilled? I did locate a block at Titan Motorsports..but they wanted 200 bucks for it...that seemed a bit ridiculous for a busted block IMO. Hope this thread stays alive! |
#10 |
From looking at my engine, the mounts seem to be set bak a little farther than the L28, but I haven't made any measurements yet...
Anyway, with a few of us working on the swap at the same time, we should get some good information exchanged
__________________
#11 | |
HybridZ Supporter
![]() ![]() Join Date: Apr 2000
Quote:
__________________
Scottie ![]() '87 RX7 / 2JZ Power - 9.51 @ 146.16 71 240Z / GN-powered '84 911 Carrera Cabriolet '97 E36 M3 Coupe/5-spd '98 Sonoma Stepside - LM4 powered |
#12 | |
Posts: n/a
Quote:
#13 |
Posts: n/a
Sucks that Titan didnt want to be all that much help....seems quite a few guys are interested in this swap...even from orlando too!
#14 |
Posts: n/a
i dont see why this swap hasnt been done yet... call me ignorant but every time i think about it i cant see too many problems, money being the greatest for someone like me. There are lots people on this site who had plenty of time and money for an RB swap, we just need someone to go for it in the 2JZ spectrum, who has plenty of money to be able to deal with all the little things
-Zach |
#15 |
Member
Well since I have already bought a totaled supra I have all the parts remove and I am just waiting for a clean 240Z. I have seen a lot of HORRIBLE 240Z's. To bad these cars seem to end up so trashed.
#16 |
Posts: n/a
I have a cherry one waiting to find a motor/6spd...ying and yang
I wont settle for an auto...that thing is worthless. |
#17 | |
Posts: n/a
Quote:
#18 |
Posts: n/a
Eh...thats a matter of opinion....any v8 is better than the motor that came in the Z stock
But the A4 from a supra is a hunkojunk! |
#19 |
Posts: n/a
than THE Z ? way to show some detail. The Z was from 1970-1996.
#20 |
Posts: n/a
As mentioned before...mine(and the one cyrus is looking for) is a 240Z.
FYI..its also in the subject title of the thread...in case more clarification is necessary |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 240Z Hemi Swap ? | Dave Moritz | Other Engines | 12 | July 16th, 2009 08:27 PM |
| 240sx S14 subframe vs. Z32 TT for 240Z swap. | badhobt | Brakes, Wheels, Suspension and Chassis | 11 | June 12th, 2006 09:41 AM |
| Project Silver Bullet - 240Z LS1 Swap Update | qwik240z | Gen III & IV Chevy V8Z Tech Board | 5 | June 2nd, 2005 03:59 PM |
| I'm doing a typical 350 swap into a 73 240z and wondering | milo240z | Gen I & II Chevy V8 Tech Board | 3 | April 20th, 2005 01:55 PM |
| Please take a look at this need help with 240z swap | mr.makaveli | 6 Cylinder Z Forums | 1 | May 29th, 2004 07:32 AM |
