Roll Cage
  • Please log in to reply
60 replies to this topic
#41 tube80z
tube80z
    Super Moderator
  • Super Moderators
  • 1140 posts
  • LocationRickreall, Oregon
Posted 06 January 2012 - 12:06 PM
Re Zerorust. I used that and it seems to work great on the floorboards and engine bay BUT it chips really really bad when exposed to flying debris such as in the wheel wells. And yes I used the primer powder stuff they sell for it.
I've had good luck with real hammerite. I put it on with a roller and it holds up pretty well.
Cary
Tube80z
"A little knowledge is a dangerous thing
So is a lot"
#42 heavy85
heavy85
    Member
  • Members
  • PipPipPipPipPipPip
  • 1137 posts
  • LocationIllinois
Posted 06 January 2012 - 09:47 PM
Yeah it seems good for interior and engine bay it just chips easily in the wheel wells. I also found out to make sure you seam seal everything first as rust grows quick between plates if they are painted only.
Cameron
#43 JMortensen
JMortensen
    Retired Admin.
  • Donating Members
  • PipPipPipPipPipPipPipPipPipPip
  • 12383 posts
  • LocationSeattle area, WA
Posted 06 January 2012 - 09:58 PM
What makes you think there isn't rust under the seam sealer? My car had tons of rust in the seams (even the ones with factory seam sealer. That's why I'm going to oil the frame rails when I'm done...
Jon Mortensen, owner/operator www.petdoorstore.com
#44 redneck1545
redneck1545
    Junior Member
  • Members
  • PipPipPipPip
  • 220 posts
  • LocationCartersville ga
Posted 07 January 2012 - 06:41 AM
My plan was to spray as much as i could before applying seam sealer.
I'm I in the wrong to do it that way?
Kinda too late seeing as how I only have an engine bay left to spray but figured i'd ask anyways.
#45 heavy85
heavy85
    Member
  • Members
  • 1137 posts
  • LocationIllinois
Posted 07 January 2012 - 07:18 AM
Yeah Jon there is rust hidden inside but it starts to show visible orange rust at the seams if you dont seam seal it.. I would paint first or primer or somehow coat the bare metal then seam seal then paint the seams again.
Thanks Cary maybe Ill try the Hammerite to recoat the wheel wells
Cameron
#46 surpip
surpip
    Always Here
  • Members
  • PipPipPipPip
  • 204 posts
  • LocationTX
Posted 11 January 2012 - 01:02 PM
IMO POR 15 is qwite a bit more durable i painted some rusty pices with zero rust, POR 15 and the stuff you can get from eastwood. Banged them around other scrap metal pelted them with rocks from my lawnmower left them outside for about a mounth and POR15 coating looked better than evrything elce. So thats what im going to use. BTW thanks for all the R&D for my cadge, im trying hard to resist, but i think im going to end up doing a full teardown and blast like you did.
"The unwilling, led by the incompetent, to do the unnecessary, for the ungrateful" [found inscribed on a vietnam-era coffin]
My 280Z ss build: http://forums.hybrid...04397-383-280z/
2005 350Z
2010 Camaro SS/RS
#47 redneck1545
redneck1545
    Junior Member
  • Members
  • PipPipPipPip
  • 220 posts
Posted 19 January 2012 - 07:49 PM
Dang man...Is this thread that bad??? I mean I know I haven't updated in a while but really...the tool shed??? after all my hard work??? lol
#48 proxlamus©
proxlamus©
    I need a hug...
  • Members
  • 2107 posts
  • LocationAurora, Colorado
Posted 19 January 2012 - 09:12 PM
it's not in the tool shed?
Currently on a rotisserie for a full restoration - L28 with 9mm rods, 88mm Ross pistons (3.0L), 8.5:1 CR, Schneider Stage II cam, Holset HY35W, Megasquirt, Suzuki GSXR ITB's and home made intake plenum, Z32 transmission, Fidanza aluminum flywheel, ACT stage II clutch and pressure plate, coil-overs, vented 4x4 front brakes, 240sx rear brakes, Corbeau FX1 Pro seat, (soon to be half cage) and still debating the paint.. hurm
#49 redneck1545
redneck1545
    Junior Member
  • Members
  • PipPipPipPip
  • 220 posts
Posted 20 January 2012 - 08:21 AM
I was commenting on your post above saying "delete"
it was intended to be a joke...har har har
#50 redneck1545
redneck1545
    Junior Member
  • Members
  • PipPipPipPip
  • 220 posts
Posted 24 February 2012 - 11:00 AM
Update,
Some old floor pans pics...Attached File  420355_3425626038923_1218439599_3508363_206658914_n.jpg   70.66KB   81 downloadsAttached File  405964_3425617918720_1218439599_3508330_1747635380_n.jpg   78.31KB   86 downloadsAttached File  404280_3425622118825_1218439599_3508345_360342461_n.jpg   80.07KB   69 downloadsAttached File  419648_3425624078874_1218439599_3508354_19119263_n.jpg   89.74KB   83 downloads
Repainted and seam sealed...
Attached File  408867_3425920166276_1218439599_3508926_280334878_n.jpg   90.15KB   99 downloadsAttached File  429392_3425904325880_1218439599_3508892_326391686_n.jpg   68.66KB   101 downloadsAttached File  405897_3425904685889_1218439599_3508893_490944559_n.jpg   71.91KB   90 downloadsAttached File  428756_3425906965946_1218439599_3508898_591371077_n.jpg   65.01KB   92 downloadsAttached File  424798_3425909166001_1218439599_3508903_2019865044_n.jpg   74.13KB   87 downloadsAttached File  430985_3425910246028_1218439599_3508904_1730596553_n.jpg   73.68KB   89 downloadsAttached File  428201_3425910966046_1218439599_3508906_372396106_n.jpg   112.16KB   82 downloadsAttached File  399936_3425914446133_1218439599_3508913_899839358_n.jpg   74.34KB   90 downloadsAttached File  396426_3425918126225_1218439599_3508922_681257050_n.jpg   72.4KB   99 downloadsAttached File  430549_3425915246153_1218439599_3508916_568564475_n.jpg   72.2KB   108 downloads
Suspension Stuff, stripped, painted and installed...I did relocate the LCA pivot point up by about 3/4" I think and slotted the engine mount holes in the crossmember.
All suspension components have hyperflex energy bushings installed as well.
Attached File  431063_3425954007122_1218439599_3508932_2067577515_n.jpg   73.68KB   94 downloadsAttached File  430591_3425955567161_1218439599_3508936_381332223_n.jpg   51.78KB   80 downloadsAttached File  424022_3425957367206_1218439599_3508941_517848892_n.jpg   60.94KB   76 downloadsAttached File  432353_3425958327230_1218439599_3508944_1072555666_n.jpg   58.35KB   73 downloadsAttached File  395420_3425959127250_1218439599_3508946_1486965590_n.jpg   74.15KB   74 downloadsAttached File  404172_3425962367331_1218439599_3508953_1661360498_n.jpg   84.43KB   76 downloadsAttached File  419233_3425964287379_1218439599_3508958_236547293_n.jpg   79.15KB   85 downloadsAttached File  408961_3425966247428_1218439599_3508962_754686188_n.jpg   150.62KB   86 downloadsAttached File  422151_3425967447458_1218439599_3508964_525195186_n.jpg   138.13KB   85 downloads
Attached File  404883_3425991368056_1218439599_3509024_1800950970_n.jpg   72.04KB   74 downloadsAttached File  421356_3425971207552_1218439599_3508974_1199034174_n.jpg   89.34KB   75 downloadsAttached File  425927_3425973287604_1218439599_3508980_660275982_n.jpg   69.14KB   78 downloadsAttached File  431691_3425981207802_1218439599_3508995_552095377_n.jpg   76.54KB   77 downloadsAttached File  422537_3425982007822_1218439599_3508996_1774784931_n.jpg   86.07KB   79 downloads
And now the brake stuff...Typical 4x4 S12W vented rotors with z31 hubs up front and Q45 hubs in the back. Honda odysee Studs up front and ARP studs in the rear. (can give part numbers if needed) The front z31 hubs have the same inner and outer bearings as the s30 but they do use the dust seal from the z31 hub. Just slap the hub up there and run it on the spindle with the nut, dont bother trying to "hand" fit the hub to the spindle as it will take more effort.
I will be running a 1" wilwood master cylinder with a rear proportioning valve. I'm changing all my lines over to 3/8-24 threads as its easier to connect to the wilwood stuff instead of having a monstrosity of metric adapters. Also rebuilt the Steering rack with some speedi boots from advanced auto parts. They are universal botos and have to be cut to fit but they work great. I used generalpurpose lithium grease on all the rack componets.
Attached File  425059_3425988567986_1218439599_3509007_574781625_n.jpg   66.76KB   79 downloadsAttached File  417468_3425989208002_1218439599_3509010_1371471965_n.jpg   74.46KB   71 downloadsAttached File  423666_3425989648013_1218439599_3509014_1902733704_n.jpg   80.62KB   79 downloadsAttached File  431978_3425990168026_1349060872_n.jpg   79.79KB   88 downloadsAttached File  399809_3425993888119_1218439599_3509038_1007920534_n.jpg   80.83KB   88 downloadsAttached File  401293_3425995208152_1218439599_3509041_1257921880_n.jpg   76.42KB   79 downloadsAttached File  425141_3425995928170_1218439599_3509044_1384896878_n.jpg   79.57KB   78 downloadsAttached File  430360_3425997568211_1218439599_3509048_1621542550_n.jpg   58.24KB   76 downloadsAttached File  418259_3425998368231_1218439599_3509050_1870504004_n.jpg   83.64KB   75 downloadsAttached File  429108_3425999728265_1218439599_3509053_1607858862_n.jpg   93.33KB   83 downloadsAttached File  402027_3426000048273_1218439599_3509054_816798152_n.jpg   83.69KB   96 downloadsAttached File  429133_3426002168326_1218439599_3509060_1665034992_n.jpg   77.74KB   102 downloadsAttached File  427465_3426003288354_1218439599_3509062_1619080053_n.jpg   73.02KB   96 downloadsAttached File  409109_3426003928370_1218439599_3509064_1295729894_n.jpg   67.3KB   112 downloads
Question about the cage though. My welds dont encompass the entire tube at the mounting plate ebcause of the angle required. It's REALLY hard to get a MIG torch head in there. Im considering getting it TIG'd in that location before I paint it.
Could I leave it alone and spray some paint on it or should I be worried about the weld not going all the way around the tube? The joints on the cage were all Tig welded except for the mounting plates to the car and the bar to the plate joints.
Attached File  429222_3425907645963_343855211_n.jpg   99.27KB   148 downloadsAttached File  396523_3425908125975_1218439599_3508900_2126747424_n.jpg   62.86KB   164 downloads
Any help would be appreciated.
Comments are welcome!
#51 Racer Z
Racer Z
    Junior Member
  • Members
  • PipPipPipPip
  • 127 posts
  • LocationLos Angeles
Posted 24 February 2012 - 12:42 PM
SCCA, VARA and most clubs will require all joints to be fully welded. Some cut the roof off, others cut the floor out, finish all the welds and then put the car back together. I haven't done a full cage yet, so I'm not sure what would be easier or better. I'm leaning towards cutting the roof off at the "A" and "C" pillars. I suppose there are other ways to do this.
Racer Z
Escargot Racing
#52 JMortensen
JMortensen
    Retired Admin.
  • Donating Members
  • 12383 posts
Posted 24 February 2012 - 12:52 PM
There are other ways, like cutting access holes through fenders and door jambs for the torch.
I think in this case he's talking about the main hoop backstays, and I don't think that will work. That is a tight spot. Coffey would be able to tell you if you can tig it where it sits or if one of his adjustable mig tips would work. If none of that works, my solution would be to cut the backstays off, change them so they hit closer to the leading edge of the strut tower, and then you would have plenty of room for the torch on the underside there.
#53 johnc
johnc
    Administrator
  • Administrators
  • 9739 posts
  • LocationLa Habra, CA, USA
Posted 24 February 2012 - 02:16 PM
All joints must be welded 360 degrees. You will fail tech with SCCA and NASA. Beg, borrow, or pay for a MIG welder and use a Tweco #3 gun with a flexible swan neck and .023 wire. You can get to those spots with that gun.
In the future, make sure all of your required tubes are completely welded before adding any optional tubes. The main hoop rear brace that is not completely welded is a required tube and is more important then the horizontal brace that attaches to it. Design your welded joints with complete 360 degree welding in mind.
Go to the FB BetaMotorsports page and look at how I did the recent M3 cage. I had to allow room between the cage elements to get that 360 degree weld and I had to hole saw the floor and drop the cage after tacking to get complete welds over the top.
Again, if you had welded the required tube first then you could have positioned the optional horizontal brace at the mounting plate or far enough above to allow complete welding of its junction with the required tube.
----- John Coffey, Fabricator at Benton Performance, LLC
#54 redneck1545
redneck1545
    Junior Member
  • Members
  • PipPipPipPip
  • 220 posts
Posted 03 June 2012 - 09:45 PM
I haven't done an update in a while so heres my condolences annnnnd pictures :)
I've done a lot more than im posting tonight but heres to getting my updates going again. I welded the whole joint on the cage as per recommendations...looks like snot but its a solid weld, Im adding some pics of the car on the ground finally. Rear is way high and will be lowered but here ya go.
Attached File  249183_4133039323813_1367168058_n.jpg   103.26KB   42 downloadsAttached File  303607_4133037043756_1218439599_3824391_1242534877_n.jpg   117.79KB   40 downloadsAttached File  546165_4133038003780_1218439599_3824392_1936100108_n.jpg   74.62KB   37 downloadsAttached File  556092_4133034043681_1654800395_n.jpg   100.69KB   54 downloadsAttached File  598782_4133034683697_2116978615_n.jpg   127.15KB   62 downloads
And heres some of my exhaust pics. I got bored toying with the idea of having someone build my exhaust and the added cost, and what the heck I built my roll cage so why not try something as trivial as some exhaust tubing :)
So I made another journey to Summing Racing...If your are unfortunate enough as I am to live with in driving distance of one of these stores go ahead and send your apologies to the bank account...
I picked up the universal 2.5" mandrel bent tubing kit, a Narrow X-pipe, some collectors, hangers and clamps. I took my time placing everything up and started from the header flange and worked my way back little by little. I'm usually anal retentive about measuring 10 times and cutting once but I'm ready to drive this things already! I measured one...count it, yes one cut, and eyeballed the rest of em. I deburred all my cuts inside and out and made sure to have no blow through or mig whiskers in the tube after welding. I tacked everything in place before I pulled the whole system out for final welding.
I started off by cutting the flange off of the collector kit and welding it straight onto a peice of mandrel bend, Otherwise with the JTR headers it would have put the pipe too close to the oil pan. After that went into some 90 degree bends pointed toward the rear. A few very small bends were cut to point the straight pipe back. I wanted to keep good access to the oil filter and slave cylinder as well as keep the passengers side away from the starter as far as possible, but in doing so I may have sacrificed about 1/8"-1/4" ish ground clearance. I snaked both sides up above the transmission crossmember. 2.5" is TIGHT in the trans trunnel with a t-56 and straight x-member.
I added some shortened slip joints to the x-pipe and slipped it onto the pipe coming over the trans tunnel. After that I just added bends as needed to keep the pipe as hight and tight as possible all the way to the rear where have them mounted to some 2.25" summit mufflers (dont hate, they were on sale for $10 bucks a pop, too good to pass up simply to get it quiet enought to drive down the road). I added some angled tips made from 2.5" pipe but don't have any pics of those just yet.
Attached File  551101_4133065204460_1272600899_n.jpg   36.23KB   49 downloadsAttached File  527719_4133064724448_1412507265_n.jpg   32.75KB   36 downloadsAttached File  579930_4133064124433_722988103_n.jpg   37.55KB   35 downloadsAttached File  534312_4133063404415_84867471_n.jpg   38.73KB   33 downloadsAttached File  600935_4133060404340_823836459_n.jpg   56.83KB   32 downloadsAttached File  582361_4133056324238_1218439599_3824418_928272287_n.jpg   48.68KB   30 downloadsAttached File  385681_4133054764199_1218439599_3824416_1936407764_n.jpg   50.76KB   29 downloadsAttached File  534456_4133053244161_766843946_n.jpg   34.83KB   30 downloadsAttached File  521315_4133052684147_1874189373_n.jpg   45.65KB   32 downloadsAttached File  385654_4133051804125_1218439599_3824413_1075833947_n.jpg   57.75KB   31 downloadsAttached File  542357_4133075524718_1218439599_3824447_1279601036_n.jpg   60.9KB   28 downloadsAttached File  540507_4133074924703_1218439599_3824446_1666990358_n.jpg   66.39KB   30 downloadsAttached File  166588_4133074204685_1218439599_3824445_1207346658_n.jpg   57.74KB   27 downloadsAttached File  537654_4133073124658_1100000906_n.jpg   53.59KB   33 downloadsAttached File  285739_4133072364639_769100266_n.jpg   59.72KB   31 downloadsAttached File  526902_4133071884627_1218439599_3824441_782840161_n.jpg   54.22KB   26 downloadsAttached File  389583_4133070604595_1218439599_3824439_959657420_n.jpg   62.82KB   26 downloadsAttached File  547137_4133070084582_418252282_n.jpg   68.63KB   24 downloadsAttached File  318237_4133068484542_77305327_n.jpg   57.44KB   24 downloadsAttached File  537689_4133069164559_390810660_n.jpg   59.79KB   23 downloadsAttached File  522464_4133085844976_1218439599_3824459_548176292_n.jpg   128.62KB   32 downloadsAttached File  550834_4133084804950_1427830749_n.jpg   137.5KB   28 downloadsAttached File  551075_4133082604895_1218439599_3824455_539680252_n.jpg   115.26KB   25 downloadsAttached File  545158_4133081884877_1569937217_n.jpg   131.34KB   28 downloadsAttached File  208863_4133081204860_1896016127_n.jpg   133.47KB   25 downloadsAttached File  526271_4133078124783_1968220138_n.jpg   128.97KB   23 downloadsAttached File  600880_4133079604820_367301415_n.jpg   128.47KB   24 downloadsAttached File  526708_4133077084757_1218439599_3824449_881629005_n.jpg   89.87KB   26 downloadsAttached File  544727_4133076204735_416381440_n.jpg   52.6KB   27 downloads
All in all im pretty happy with the way it turned out considering this is my first attempt at any of this stuff. I may need to re-work the front based on how much ground clearance I have when its on the ground but time will tell. It sounds much better than it did in my old truck! My old truck had 2.5" with long tube headers, an h-pipe and glasspacks with LOTS of dreaded drone! This system has a very airy sound to it with lots of tone in the rpm ranges. Not too mbad for some on sale summit mufflers :)
Let me know what you guys think.
Edited by redneck1545, 03 June 2012 - 09:50 PM.
#55 zxcrazyv8
zxcrazyv8
    Newbie
  • Members
  • Pip
  • 4 posts
  • Locationwa
Posted 25 July 2015 - 08:31 PM
Any body have pictures of 280zx 2+2 roll bars or blueprints on making or what kits, where to buy
#56 waddiejohn
waddiejohn
    Member
  • Donating Members
  • PipPipPip
  • 86 posts
  • LocationWhetstone AZ
Posted 02 September 2015 - 09:57 PM
Nice work Redneck. Thanks for all your posts and pictures.
#57 smokehouse_83
smokehouse_83
    Newbie
  • Members
  • Pip
  • 11 posts
  • LocationNew Mexico
Posted 17 May 2016 - 08:44 PM
I am looking into putting a jegs 10point in my 280.  I am in the process of doing floor pans and make custom seat mounts for some Corbeau Forza seats so I can get them low.  My question is how much room is there in these cars with a halo bar?  Will I be able to drive the thing on the street without a helmet?  I am putting a turbo SBF in it and will need a cage to take it to the track.
#58 JMortensen
JMortensen
    Retired Admin.
  • Donating Members
  • 12383 posts
Posted 18 May 2016 - 08:58 AM
There is not a lot of room for sure. My halo is right up next to the frame around the door and I had to move my seat towards the center otherwise my helmet would interfere and I couldn't hold my head up straight. You might be able to get the seat lower or maybe put the tube lower and bend it out a little farther, but there is a serious issue there either way.
#59 smokehouse_83
smokehouse_83
    Newbie
  • Members
  • Pip
  • 11 posts
Posted 18 May 2016 - 11:24 AM
So do a 8 point and keep it under 10.00 is gonna be my best bet?  I don't wanna ruin the drivability of the car by having to wear a helmet to drive the sucker.  Will keep the car cheaper in the long run I guess.
#60 Chris Duncan
Chris Duncan
    Always Here
  • Members
  • PipPipPipPip
  • 159 posts
  • LocationSeattle
Posted 18 May 2016 - 11:58 AM
My Chumpcar came out pretty good with an 8 point. The seats are thin racing buckets and they are touching the floor in the back. That way there is enough room to drive without a helmet.
Don't know how a pre-built cage would work though. My cage is custom and it was designed to hug the pillars and ceiling, like a max of 1/4" clearance and touching in several places.
Edited by Chris Duncan, 18 May 2016 - 12:03 PM.
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
