zcarnut
A One Inch Diameter Brake Master Cylinder for the S30 Z Cars
It's mentioned just a page back, but there are 3/8x24 male to 10mm female adapters available. http://www.brakequip.com/products/automotive-fittings/male-to-female-thread-adapters or http://www.ebay.com/itm/Brake-Line-Thread-Adapter-Male-3-8-x-24NF-Female-M10-x-1-Inverted-Seat-/390439357312?pt=Vintage_Car_Truck_Parts_Accessories&hash=item5ae7ffcb80 these would be the only things I'd add to the first post. Just so people know. Otherwise I didn't know about these and just made new lines with a 3/8x24 fitting on one end and a 10mmx1.0 fitting on the other end.
Thanks for the info.  I purchased the fittings and I hope this will solve the problem.  For those wanting to purchase these fittings, I went to this website http://dmpfasteners.com/shop/search/results?search_in_description=1&keyword=BQ50 as brakequip online shop requires minimum of $10 purchase and the shipping is expensive.
Share this post
Link to post
I'm probably gonna try using that Wilwood MC setup, but I'm unsure about which Booster to use. (I'm guessing that's what's not really talked about in the 1st post :P )
Can anyone tell me which one can I use if I don't want to drill new holes to install a new booster?  (so basically with the same bolt pattern)
btw, I have a '72 240Z, so one of the smallest boosters. I'm afraid it's gonna be a problem with such a large MC.
Edited by Interceptor
Share this post
Link to post
I purchased the larger 2+2 booster and it worked fine. I only had to flip it upside down. Meaning I rotated it 180 degrees. The vacuum hose was more than long enough still. I believe I even shortened the vacuum hose.
Edited by smoorenc
Share this post
Link to post
No autoparts store can get the boosters for the 240z to 280z. The 280zx 10in booster is to big. And the z32 booster and MC is to touchy for our cars. I was ablw to snag the last booster amazon had, as far as i know but it did only say one left in stock. There was a booster that was slightly smaller than the 10in for later z cars that fit but ive had a hard time finding that in stock too. I just did the MC upgrade.
Share this post
Link to post
After having my 1" Wilwood master on the shelf for about 2 years I finally did this swap about a week ago. I have the modern motorsports rear disc package with the Toyota fronts and had the 7/8 OEM master.  It seemed like it worked pretty good that way so wasn't in rush.
Followed the procedure here and it worked with no surprises. Just had to adjust my brake rod out a bit. My Wilwood 1" master had check valves in both ports so removed them. My OEM master did have the check valve in the rear port (never seemed to drag at all though).
I don't think its a major difference but is definitely noticeable. Pedal effort is about the same but it wants to grab harder. Seems to make the rear discs work better at first impression. Certainly looks better with the rest of the new parts under the hood.
I now have a Nabco 7/8 master in the parts pile.
Edited by Aero Z
Share this post
Link to post
My 1" Wilwood seems to have low pedal.  I think I need to revisit my booster pushrod.
Running race pads and fresh fluid but with the booster the pedal is just lower than I want it.
Guess I would need to max out all the adjustments to get the most upright pedal I can?
Share this post
Link to post
I have the 1 inch Wilwood MC with Toyota solid calipers on the front and 240sx calipers on the the rear with all adjustments, including the push rod,  verified and no air in the lines. I have a long slightly squishy  pedal  which becomes firm after about one inch of travel.  Many other people have made this same complaint.
The long pedal is a pain, so I researched the 240SX caliper design. The 240SX caliper has a low drag design (look it up) which means that the seals are designed to pull the piston away from the rotor which means that moving the piston takes a bit more fluid volume to bring the pads  in contact with the rotor. I verified this by looking at 240SX master cylinders and sure enough they are of the  "fast fill" step bore design as indicated by the bulge on the side.  The"fast fill" MC provides an initial additional volume of fluid to push the piston out of the caliper to reduce time for the pads make contact with the rotor.
I now believe that this may explain why there are many complaints about a long pedal or squishy pedal by people who have done the 240SX rear caliper swap.
I have been researching  the pros and cons of installing a 2psi residual pressure valve on the rear brake line coming out of the MC to offset the lag time (volume) required to bring the piston out of the bore.  Some hot rod blogs make this recommendation to fix the long pedal issue common to drum to caliper swaps: http://www.hotrodders.com/forum/low-drag-caliper-replacement-110823.html
I am still researching the viability of installing the 2psi residual pressure valves.
Note: The first two Wilwood MCs I bought both leaked internally out of the box. So far the third MC has held up for three years.
Edited by Miles
Share this post
Link to post
Hmmm...interesting. I have the vented S12-W on the front and the 240SX solid on the rear. After fighting an issue with the reaction disc in the booster - I have it sorted. Reaction disc now glued into place....I can't tell the difference in pedal between my stock 78 setup and the Yota setup. You may have a little more adjustment to do with the booster rod AND/OR your pedal travel/adjustment at the pedal itself. It's in there....mine works perfectly....you just gotta futz with it a little bit. Solid pedal from initial push.
Share this post
Link to post
Yes ^ the spring and the valve gets removed. Mine only had the check valve and spring in the rear cylinder. Doesn't speak too well about Wilwood quality control if some boxes ship without the valves, some are installed in both cylinders and some in only the rear.
DUMB QUESTION: how the heck do you guys bench bleed the master cylinder and then install it in the car without getting fluid all over the place? Drip drip drip drip drip
Edited by thedarkie
Share this post
Link to post
You can use small black rubber stoppers available at the hardware store or you can buy brake line plugs with the correct threads and inverted flare shape.
Share this post
Link to post
Fair suggestion, I'll try to find some before I install it.
Another question: has anyone tried installing it and bleeding according to Wilwood instructions? Their documents specifically say to install the cylinder and hook up the lines prior to bleeding, and then to run a hose from the bleeder screws into the reservoirs and bleed the cylinder in that manner. Not sure why the discrepancy between that and a more standard bench bleed procedure..
Share this post
Link to post
thanks smoorenc and Miles for the replies
I've got the master in, the front side works fine, bled fine, and seals fine. The back brake line leaked. I bought a new line with flared ends and bent it to shape, installed...... and it still fuggin leaks at the flare.
Has anyone used conical copper washers for the flare seal? I really don't wanna keep buying new brake lines if they're all gonna leak. I used the Brakequip BQ50 fittings on the master to accept 10x1 metric threads... it worked fine for the front brake portion so I know the adapter is good.
Share this post
Link to post
Update, and confirming a few tips for future reference.
You don't have to bench bleed this master cylinder. Wilwood's instructions state that it should be installed and hooked up, and then the bleeders on the cylinder used to do the initial bleeding. I did it this way and it worked just fine. I went on to bleed the brakes and very very little air came out of only one of the 4 calipers.
Also, if you're flaring your own lines, or buying a pre-flared one and bending it to suit... make damn sure that the bends are accurate and there's no sideways tension on the brake line, otherwise it won't seal. If you can't get the nut to thread without much effort, there's something wrong and it will leak. 3 lines later and a bunch of brake fluid (and cursing) my setup is finally up and running.
Lastly, the BQ50 fitting from brakequip is what you'll want if you don't have an old master cylinder with adapters that fit the wilwood.
Cheers
Edited by thedarkie
Share this post
Link to post
I wasn't happy with the 1" Wilwood Master.  Pedal still had too much travel.
I installed the Strange B3359TA 1.125" master and now the pedal is perfect.
S12W with DTC60 pads front / early style 280zx rear caliper with DTC70 pads.
Good ducting and good fluid and I can push pavement for days without fade.
Love this new setup.
Share this post
Link to post
What booster are you using?
I thought of doing the same thing, but was concerned that it would increase pedal effort or the brakes would have a wooden feel.
Share this post
Link to post
Also curious about the booster.
Now I've gone for a very similar setup: s12w, early 280zx rears, but am running a late 280zx booster and 1" nissan pickup master. Luckily I'm now the horizontal master style, so I could got to the 1-1/16" z32 one if need be.
I'd prefer a softer than firm pedal (closer to a modern car), so we'll see how it goes.
Share this post
Link to post
Finally getting to finish my brake rebuild but after chasing leaks (all new Stainless steel lines) I bled the MC and all four corners (wilwood 6/4 setup) the pedal is still soft and goes to the floor. I would expect it be firm and not allow for full travel. Is this a booster rod adjustment? Also using the 280Z booster
Share this post
Link to post
I picked up Wilwood 260-8794 from amazon and there are no residual pressure valves in either front or rear. I've looked through documentation on wilwood's site and they talk about installing inline pressure check valve adapters that are external to the unit. Can someone confirm if the new design eliminates pressure check valves from the MC itself, or am I just missing something really simple?
Share this post
Link to post
Could be poor quality control. I had two of the Wilwood 260-8794 MCs leak internally right out of the box. I now bench test Wilwood  MCs before installing them. Another member complained that the bleeder fittings appeared to be damaged.
We remove those anyway for disk brake applications.
Share this post
Link to post
I have talked with Wilwood engineers in the past.  They were very responsive helpful.  Give Wilwood a call. It would be interesting to see if they stopped including the residual pressure valves for some reason.
When I did the Wilwood 1 inch install a few years ago I ran the the car with the valves in place for a month and then without the valves for a month and there was no difference. At the same time I looked at some old 280ZX MCs and there were residual pressure valves in the front and rear outlets.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
