Quick Haltech E6K Checkout??
JSM
I'm looking at a used Haltech E6K for $275 locally. Can I simply apply +12 volts to what I'm assuming is a Main power source and the switched power source and see if I can connect and read the haltech without any sensors hooked up?
Is there any other way or is it simply a $275 gamble?
I don't remember exactly, but if you hook up power and ground plus the accessory power it will turn on and you can query it. You need a dos based laptop to communicate or run dos box, its a little tricky to set up so its hard to tell if you just got the programming of dos box wrong or if its dead. I have a e6k that seemed to be a little finikie to me and reset when I turned the engine over. selling it for 100 is someone wants to try it, it communicates fine I just couldnt get the engine to start.
