Z31 Axle Swap R200 CLSD - M2 Differentials
  • Please log in to reply
36 replies to this topic
#21 EF Ian
EF Ian
    Junior Member
  • Members
  • PipPipPipPip
  • 475 posts
  • LocationPortrush - Northern Ireland
Posted 05 November 2012 - 04:56 PM
Thanks, won't be looking for a set untill I confirm I'll be running this setup and get the other parts but I'll definitly keep that in mind when the time comes.
#22 EF Ian
EF Ian
    Junior Member
  • Members
  • PipPipPipPip
  • 475 posts
Posted 27 January 2013 - 01:51 PM
Can anyone give me the lengths of the shorter M2 shafts please?
I'm going to get a set made but I need to know what length to get them made.
#23 Akira
Akira
    Regular
  • Members
  • PipPipPip
  • 61 posts
  • LocationLos Angeles, CA
Posted 27 January 2013 - 02:20 PM
I measured the m2 shaft for the driver's side at 14 13/16". As for the passenger side, I don't have the m2 shaft. I'm using the stock 300zxt driver's side shaft on the passenger side now, which measure's 15 3/8".
Edited by Akira, 27 January 2013 - 02:30 PM.
#24 EF Ian
EF Ian
    Junior Member
  • Members
  • PipPipPipPip
  • 475 posts
Posted 27 January 2013 - 04:18 PM
Thanks. I didn't atually realise they were different lengths, I thought it was only the input shafts that were different lengths.
I guess they are both shorter than the originals by the same length, so if I measure that against my original I should be able to work it out. But hopefully someone can confirm the length for me before then.
It may be that it works ok on mine with just the cages reversed, but do they work aswell reversed?
#25 Akira
Akira
    Regular
  • Members
  • PipPipPip
  • 61 posts
Posted 27 January 2013 - 05:12 PM
This is how it is stock:
I just took apart my stock 300zxt axles yesterday. Driver side 15 3/8". Passenger side 15 13/16". Longer input shaft goes to longer passenger axle. Shorter input shaft goes to shorter driver side axle.
Per M2 instructions:
I'm to use M2 axle measured at 14 13/16" with short input shaft on the driver side. Then use 15 3/8" axle with longer input shaft on the passenger side.
As for reversing the cage, I don't have much to say about that. I've seen people do it and grind down the end of the axle. But that's as far as I've read about it.
Edited by Akira, 27 January 2013 - 05:14 PM.
#26 JMortensen
JMortensen
    Retired Admin.
  • Donating Members
  • PipPipPipPipPipPipPipPipPipPip
  • 12386 posts
  • LocationSeattle area, WA
Posted 28 January 2013 - 09:26 AM
If you have the right length axles, reversing the cage doesn't do anything for you. Lengths are correct as I recall. Don't have a set of shafts to measure. Should be in one of the group buy threads.
Jon Mortensen, owner/operator www.petdoorstore.com
#27 EF Ian
EF Ian
    Junior Member
  • Members
  • PipPipPipPip
  • 475 posts
Posted 28 January 2013 - 12:59 PM
Thanks, no binding with this setup then?
I'm confused, my stock 300ZXT axles are probably not the correct size, thats why people suggest reversing the cages?  If I had the M2 axles for example then I definitly wouldn't reverse the cages.
I'll have a look in the group buy thread.
#28 JMortensen
JMortensen
    Retired Admin.
  • Donating Members
  • 12386 posts
Posted 28 January 2013 - 01:01 PM
Stock 300ZX axles are too long. Flipping cages gains you next to nothing. You need shorter axles. I think the Driveshaft Shop is the go to place at this point.
#29 EF Ian
EF Ian
    Junior Member
  • Members
  • PipPipPipPip
  • 475 posts
Posted 28 January 2013 - 01:17 PM
Thanks for confirming that. I'll definitly not flip the cages and will go with shorter axles, I think theres a place in the uk that can make me custom ones as long as I can give them the correct length,
#30 zgeezer
zgeezer
    HybridZ Supporter
  • Donating Members
  • PipPipPipPipPip
  • 662 posts
  • LocationIndio-Southern California
Posted 21 April 2013 - 11:35 AM
Getting the inner CV off; this can be accomplish in a few manors. Using a pipe, and placing the axle in the pipe, and slamming the CV assembly down into the pipe OR using a dead blow hammer. Using the dead blow hammer, took 4-8 hits to get the inner snap right to give. Mind you I am 145 lbs, so with me holding shaft and hammering, I think this method works great. When taking off the inner CV, be sure to hit the inner portion. Otherwise, the outer cage will shift, and you will never get the snap ring to give.
I beat up and destroyed a Pathfinder CV and axle using both of these methods.  Sometimes the inner CV simply will not come off.
Rebuilders use a special tool for this chore.  It is a heavy punch that is angled away from the shaft and has a foot designed to fit around both the inner and out race.  The design guarantees that the force of each hammer blow is delivered precisely to the inner race.   They work well, store easily in the tool box, and are, relatively speaking,  affordable,    I purchased mine from Rockford Driveline in Rockford, Illinois for a little over $50.00 shipped to me. Here's their website: http://rockforddriveline.com
This is called a cv inner race driver.  They have a number of heavy duty components.  Well worth looking at their catalogue.
Obligatory disclamer:  I have no relationship with this folks, other than dropping $ on them for their driver.
G
Life is a matter of simple logic:
If "some" is good; then it follows that "more" is better; and "too much" is just about right.
#31 mutantZ
mutantZ
    Member
  • Members
  • PipPipPipPip
  • 171 posts
Posted 04 August 2013 - 08:12 PM
I just took off the outer CV assembly but the cage retaining clip got bent in the process. Its the clip thats just inside the lip of the outer housing. Does anyone know where I can find a possible replacement. I looked on courtesy nissan, but it's hard to tell in the parts image if they are talking about the clip I need or the spring clip that is on the axle shaft itself. If anyone has any information it would be really appreciated.
#32 CHEQUERED FLAG JOE
CHEQUERED FLAG JOE
    Moving Up
  • Members
  • PipPip
  • 39 posts
  • LocationChatsworth Ca 91311
Posted 25 September 2013 - 04:56 AM
Hi I have axles being made right now.  They are a copy of Jon Mortensen axles.  They should be finished in 3-4 weeks price for the pair should be around $330-350 for the pair.  Thanks to Jon M. idea.  I'm slowly working on a complete axle kit from the diff to the wheel featuring all new parts ready to bolt in.   Thanks  Joe
Joseph P Saim      818 350 6222
9833 Deering Ave unit I Chatsworth Ca 91311
WWW.chequeredflagracing.net
WWW.modern-motorsports.com
#33 EF Ian
EF Ian
    Junior Member
  • Members
  • PipPipPipPip
  • 475 posts
Posted 25 September 2013 - 02:53 PM
Sounds good, too late for me, but if I ever need a replacement setup I know where to go.
#34 CHEQUERED FLAG JOE
CHEQUERED FLAG JOE
    Moving Up
  • Members
  • PipPip
  • 39 posts
Posted 29 November 2013 - 07:47 AM
Hi I have made a run of 5 sets of the shortened axles.  The first set has been dropped shipped and he should see it Monday 2 December.  The rest will be in my hands on Wednesday. They are black zinc coated to prevent rusting and are made by the same shop that makes the stub axles and companion flanges.  The are $ 350.00 shipped in the US.
Thanks  Joe
#35 RebekahsZ
RebekahsZ
    Life Member
  • Donating Members
  • 5348 posts
  • LocationFlorence, Alabama
Posted 29 November 2013 - 08:31 AM
That is for a pair?
1972 240z, purchased in 1991 for $900. Bone stock LS2/T56/DBW from 2006 GTO, swap completed in 2011. 400rwhp/435 rwtq. 2400# minus driver. JCI swap, Mantic ER2 clutch kit, JTR headers, single exhaust, Borla muffler, MGW shifter, M2 Differentials shortened Z31 CV axles, Z31 CLSD R200, Chequered Flag Racing billet stubs and companion flanges. MSD 2-step, Hurst roll control, both operated from switches on clutch pedal. 9" Hoosier drag slicks on Weld Draglites, 245/45/16 Hoosier A6/R6 on 16X8+10 Rota RBR. 225/250 sectioned coilovers, Koni 8610-1437RACE shocks, DP and EMI camber plates, MM shortened rear control arms, TTT front control arms, poly and aluminum bushings. Top speeds: Ohio Mile 174mph, C/GMS class record holder, best 1/8 mile 6.96 at 100mph, best 1/4-mile 11.0 at 126mph, best 60' 1.43, best 1/2-mile 148mph at GA 1/2-mile. Home Track-Jake's Dragway, Moulton, AL. SCCA autocross club - TVR, Huntsville, AL. Lets race!
#36 RB26powered74zcar
RB26powered74zcar
    XXXXXX
  • Super Moderators
  • 4461 posts
  • LocationLouisiana, 70601
Posted 29 November 2013 - 09:20 AM
That is for a pair?
Sounds like it to me.   :2thumbs:
RB26dettZ pics
th_April_2012006.jpg ®
#37 CHEQUERED FLAG JOE
CHEQUERED FLAG JOE
    Moving Up
  • Members
  • PipPip
  • 39 posts
Posted 14 December 2013 - 06:52 AM
Hi yes the price is for a pair. $350.00 delivered in the us via USPS flat rate box.  I have sold 3 sets with 2 still in stock and more on order.
  Z31 HALF SHAFTS Z 31 half shafts are designed to allow you to install the Z31 CV into your 1970-1978 Z car. They are made out of 4340, heat treated and black zinc coated.  They are the correct size so no need to flip your CV cages. Sold in pairs
1 set axles $ 350.00 shipped in the US.   $390 out of country
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
