Base model 280zx project
  • Please log in to reply
96 replies to this topic
#21 shuttlefever
shuttlefever
    Regular
  • Members
  • PipPipPip
  • 82 posts
  • LocationSeattle area
Posted 15 February 2012 - 05:17 PM
Went back and reviewed both your builds, Cool work!! I am liking the new build!! Wish i had the cash flow to get mine up and at em quicker!! Where did you source your fuel rail? and does it come with a different regulator or use the stock one somehow?
D~
#22 BluDestiny
BluDestiny
    Member
  • Members
  • PipPipPipPipPipPipPip
  • 2305 posts
  • LocationCedar Rapids, IA
Posted 15 February 2012 - 06:02 PM
You probably could use the stock one, but might as well go aftermarket. I bought the FPR separately.
I wouldn't have had nearly the amount of money to get it together without selling my 260z. And it's still not painted.
Got the fuel rail from cockerstar, but pallnet also makes them.
Cost of redoing my fuel system:
$150 for rail and rail fittins
$120 for the FPR
$60 in misc AN fittings
$50 for the SS line
$25 for an AN fuel filter
so like $400ish. If you stick with just rubber lines you can save about $100 in fittings and cost of the line.
Posted Image
We race from 120MPH rolls...
Moderatio est figmentum
Le mieux est l'ennemi du bien
#23 shuttlefever
shuttlefever
    Regular
  • Members
  • PipPipPip
  • 82 posts
Posted 15 February 2012 - 08:49 PM
$120 for the FPR
$50 for the SS line
Very cool! I will check into that stuff, I might also look into building my own. I need to research the pressure the system needs to run right, i have a couple regulators but they are for some of my old v8 carburetor fuel systems. They will work at high pressure, just not sure how well. Might need to do some more research!!
I love research... Should have some pics of my ZX up pretty soon.
D~
#24 BluDestiny
BluDestiny
    Member
  • Members
  • 2305 posts
Posted 24 February 2012 - 06:02 AM
Got some Swastikas to throw on for around town commuting. Sucks because I'm just trying them out and I need to take them off again on Saturday for the AutoX this weekend :(
A big con was that when I first put the front on, the tire rubbed on the coilover collars, wtf man. so I had to raid the front by about an inch and a half to make sure they clear. Another con is they look like crap.
A pro is that they are wayyyyy lighter than the DRW so it actually feels quicker. And I get better gas mileage.
Posted Image
Posted Image
Posted Image
I have gold on one side adn black/grey on the other. Total cost of rims with new tires was about $400 so I'm not really complaining.
Might be able to see the horrible gap these rims create
Posted Image
My steamrollers
Posted Image
This is why I needed some stockers, if you look at the inside (right) I have some bad camber wear from it being lowered not even by that much. I've only had these tires on the car for 4000 ish miles. Total miles on these tires is probably under 6000, if not 5000.
Posted Image
Edited by BluDestiny, 24 February 2012 - 06:04 AM.
Posted Image
#25 turboHLS30
turboHLS30
    Member
  • Members
  • PipPipPipPipPip
  • 527 posts
  • LocationDaytona Beach, Florida
Posted 24 February 2012 - 06:35 AM
I'm sooo excited for Sunday :D Are you taking anyone with you? If not can I ride with you?
Kid's in the backseat cause accidents and accidents in the backseat make kids, stick with a 2 seater.
"Those thoughts that were going through your mind as you sat there in your Z breaking through the BOOOST ZONE will become a reality."
By PR280z
Posted Image
#26 BluDestiny
BluDestiny
    Member
  • Members
  • 2305 posts
Posted 24 February 2012 - 06:48 AM
Yeah I'm trying to take another of my friends, one that won't ditch hopefully. I don't know if he wants to take his car or not though. I'm also heading out to the millenium mall meet tomorrow also.
Posted Image
#27 BluDestiny
BluDestiny
    Member
  • Members
  • 2305 posts
Posted 16 March 2012 - 02:41 PM
Update time. Oil cooler time
Got a complete oilcooler setup from autospot. It was in great condition but the main thing I was interested in was the adapter/sandwich plate.
First step was getting fittings and a bigger oil cooler.
Posted Image
Install was easy, take off the oil filter, use vice grips to take the oil nipple out, install sandwich plate, done.
Posted Image
Made a custom bracket for the new oil cooler to position it in front of my radiator. Used some thin aluminum bar and ran it from the top rad support to the bottom with a 90 degree bend. Bolted on so I could remove it.
Posted Image
The lines came out nice, ran them along the frame rail. Had to widen the AC line hole to make it look a bit nicer.
Here's how the lines turned out:
Posted Image
Posted Image
Posted Image
Posted Image
#28 FricFrac
FricFrac
    Member
  • Members
  • PipPipPipPipPip
  • 712 posts
  • LocationVictoria, BC
Posted 22 March 2012 - 06:27 PM
Nice setup. You should really be running a thermal plate in conjunction with your oil cooler....
1969 Datsun 510 2dr Z22ET, 1972 Datsun 510 2dr L28, 1972 Datsun 240Z, 1981 Datsun 280ZX, 1981 Datsun 280ZXT 3.1l stroker, 1983 Datsun 280ZX, 1983 Datsun 280ZXT, 1993 300ZX Convertible, 2009 Nissan 370Z
#29 BluDestiny
BluDestiny
    Member
  • Members
  • 2305 posts
Posted 01 April 2012 - 02:24 PM
What do you mean thermal plate? Like something to keep the hot air from the oil cooler from going into my rad?
So today I went AutoXing again and they recognized me and my car ( I still wanted to run novice and it was only my third time). They laughed at the fact that I was in novice and was outrunning quite a few cars today.
I'm now going to have to run in B street Prepared (BSP) because of my coilovers. This means I'll need a little more power, and what better way to make that happen than with a stock turbo transplant.
Gird your loins for updates.....
Posted Image
#30 FricFrac
FricFrac
    Member
  • Members
  • PipPipPipPipPip
  • 712 posts
Posted 09 April 2012 - 01:10 PM
Thermal plate doesn't flow oil to the cooler until the oil gets up to temperature (say 180 deg) It's not your oil pressure but oil flow that is important. You need to get the oil to where it is needed to lubricate parts to keep them from wearing. The viscosity of your oil drops as it's heated and it's not until it's up to temp that it's working optimally. The cooler will protect the oil and increase it's life as well as helping to manage engine temps by mainainting the 180 deg optimal temp. Without the thermal plate it will take much longer to get your oil to the operating temperature you want it to be running at. It works in a similar manner to your thermostat in your car but for a different purpose.
#31 BluDestiny
BluDestiny
    Member
  • Members
  • 2305 posts
Posted 09 April 2012 - 02:45 PM
Oh an Oil thermostat. That makes more sense now. I'm retarded. But yes I know what you mean now. That would just go at the output to the oil cooler right?
Edited by BluDestiny, 10 April 2012 - 08:04 AM.
Posted Image
#32 BluDestiny
BluDestiny
    Member
  • Members
  • 2305 posts
Posted 26 June 2012 - 04:44 PM
Its been a while, and I've only gotten a few things done. Painted the sideskirts, front end, and my fenders satin black. Only looks bad because the rest of the car is grey or white.
Fiberglass stuff
Posted Image
Bunch of crap inside the fenders, gross it had been hot and sunn for about a week prior and this stuff was still moist.
Posted Image
The red fender really got to me
Posted Image
Painted
Posted Image
And the half finished product
Posted Image
Posted Image
I'm planning on doing the entire roof and rear end as soon as tropical storm debby lets up. Its been raining nonstop for like a week.
Posted Image
#33 78zstyle
78zstyle
    Can Charge Rent
  • Members
  • PipPipPipPipPip
  • 542 posts
  • LocationDenton, Texas
Posted 03 July 2012 - 05:15 AM
What paint did you use to paint your car? And what rear wing is that?
#34 BluDestiny
BluDestiny
    Member
  • Members
  • 2305 posts
Posted 13 July 2012 - 06:30 PM
I just used some Krylon satin black, and the rear wing is the ZX-R homologation wing. Its a real urethane one, I believe just over 1000 were made ( 1009 iirc). I hate the fiberglass repros that MSA sells because they don't have the break in the middle like this one does. Downside is that it weighs like 25#.
Posted Image
#35 78zstyle
78zstyle
    Can Charge Rent
  • Members
  • PipPipPipPipPip
  • 542 posts
Posted 04 August 2012 - 02:21 PM
Sorry for asking more on the paint, I just think you did a really good job. Did you even sand or prime them or just spray?
#36 BluDestiny
BluDestiny
    Member
  • Members
  • 2305 posts
Posted 04 August 2012 - 04:22 PM
sanded heavily with 220 then 400. I used the can attachment to make it way easier. First time I've used one and it made a world of difference vs the time I tried it with my 2+2
Posted Image
#37 BluDestiny
BluDestiny
    Member
  • Members
  • 2305 posts
Posted 21 August 2012 - 10:57 PM
OK sooooo some things have changed. First things first is my whole debacle where my car was not running right.
http://forums.hybrid...-1980-280zx-na/
Turned out the diaphragm in my aeromotive FPR was torn and was leaking fuel into the intake, great.
Posted Image
So I ordered one and swapped it in. Ran great. 6 hours later I started my cross country drive back home to Los Angeles. This was August 9th
First day I drove 15 hours, with like 4 hours for breaks (eating, stretching, bathroom, gas etc..). No problems and I thought I was doing good. Stopped just before Houston TX to sleep for the night.
Wake up the next day at 7am to start off and I go through my checklist: Tire pressure, leaking fluids/puddles/ start her up and wait for sounds etc...Well I checked the tread on my tires since I knew they were wearing down on the inside. They had worn down so much in the 1100 miles I drove that they were cupping ( on the inside) and the deep parts were showing chord. Yeah wasn't gonna be finishing the trip on those. Called around tires shops and found a discount tire about an hour away that had a pair of Falken Azenies that would fit the rear. They were 255/50/16. They also had a set to replace the front (225/50/16) so I decided to buy a full set and keep the fronts to sell to my friend when I got back.
Posted Image
As I was travelling though texas, temps got up to 110* in some areas. In fact around 3 pm when I pulled off to a gas station my car just died. Couldn't start it at the stop sign, so I got out and pushed it into the gas station. Put some gas in and cleaned the windshield and it started, but there was a bad whirring sound coming from the fuel pump. so I parked it in the shade and let it cool off for about an hour. started up and it stopped making that sound, so I took off. I made it to about 150 miles outside of El Paso, right after it got dark, and then it happened.
I was trying to pass someone and as I was passing them a rock came out of nowhere on my lane. Couldn't switch so I lined it up and took it. Busted the hell out of my front end
Posted Image
I was super pissed. the turn signal housing actually started to drag about 2 hours later as I would find out when border patrol asked me what happened. I do most of the traveling at night when its cool, since I'm worried about the fuel pump. Haven't had a problem while it was cold though so I thought nothing of it.
I take a nap and make it to Pheonix AZ at 10am ( it's already over 100 by that time) and when I pull off the freeway, bam, car dies. get stuck in a major intersection, pull of as much as I could to let traffic pass and let it sit. Notify my uncle I'm in town with a broke down car. Right before he shows up I get it started, drive it to a parking lot and shut it off. They show up and I tell him about it and we agree to let it sit. Well when we come back it starts, but it makes it about half a block before it dies at a stoplight. So I figure the fuel pump is dead. We stop by an autozone and pick one up. Thankfully my Uncle paid. Swap that in and bam it works fine, but a dust storm has shown up so I get to spend the night at my Uncles. Leave at 3am and make it back to LA Sunday morning August 12th. Not to bad, but my fastest time yet and it would have been faster if my fuel pump hadn't gone out. At this point that engine, has made it cross country 7 times, and 2 times for the car.
So while I'm back I decide to look for a new front to replace my smashed up one. I end up getting new headlight buckets with covers, stock front bumper, and a front lip. Just got that on this morning actually. Here are some pics:
Posted Image
Posted Image
Now I look just like every other 280zx -_- Oh well.
Posted Image
#38 BluDestiny
BluDestiny
    Member
  • Members
  • 2305 posts
Posted 21 August 2012 - 10:58 PM
double post
Edited by BluDestiny, 25 August 2012 - 12:27 PM.
Posted Image
#39 BluDestiny
BluDestiny
    Member
  • Members
  • 2305 posts
Posted 21 August 2012 - 11:00 PM
double post
Edited by BluDestiny, 23 August 2012 - 07:37 AM.
Posted Image
#40 OldAndyAndTheSea
OldAndyAndTheSea
    Can Charge Rent
  • Members
  • PipPipPipPipPip
  • 765 posts
  • LocationHenderson Harbor, NY
Posted 23 August 2012 - 05:14 AM
That sucks about your gnose.....
But, I'm loving the most recent look.
Also a big fan of the headlight covers on s130's.
Awesome.
PM me for any composites related inquiries.
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
