1976 280z ...electrical issue?
cesar280z
Hello Again
at last after months of trying ,2 fuel pumps, and a lot of cuts on my hand, i got my beauty running.
HOWEVER...
the idle is really high(the little pron to adjust the idle is not responding at all), the gauges are not working, and the side marks and tail light are not working,
what did i do to make this chain reaction of failing electrical issues?
it really doesn't make any sense!!
BTW, this is all i did to make the car run again
clean fuel tank replace rubber fuel lines replace fuel filter put a filter between fuel tank and pump new fuel pump(255lph) new injector connectors replace the AMF replace the thermostat enclosure new thermotime new temp sender new temp sensor new NGK spark wires i have two ECU ,and when i use either one of them the car starts
as you guys can see i don't see where i messed up, please let me know your thoughts
thanks again to all for the help!
