Best oil for a 280Z?????
  • Please log in to reply
34 replies to this topic
#21 PR280z
PR280z
    Member
  • Members
  • PipPipPipPipPip
  • 514 posts
  • LocationSan Sebastian, Puerto Rico.
Posted 25 August 2012 - 09:00 PM
In my 280zx I run Valvoline VR1 20w-50, the conventional kind. That engine was rebuilt with forged pistons, but I'm using stock ECU and such.
In my old 260z with webers I used to run Royal Purple 10w-40 on a fresh rebuild.
VR1 20w-50 for my turbo also. ;)
Z E T T O - B A S T A R D
#22 srgunz
srgunz
    HybridZ Supporter
  • Donating Members
  • PipPipPipPip
  • 347 posts
  • LocationWisconsin
Posted 27 August 2012 - 07:58 PM
Go by John Coffey's post number 6. You have an old motor that is loose as a goose.
Do not waste money on these expensive oils. Will do you no good.
Steve
72 240Z, second owner.
L28. Mikuni's. 5speed. MSD. Koni's
#23 ryan95i4
ryan95i4
    Always Here
  • Members
  • PipPipPipPip
  • 208 posts
  • LocationFL
Posted 29 August 2012 - 05:32 AM
Same here.
73 240Z, Haltech powered L28ET
95 Avenger, Holset HX40 @ 26psi
06 CTS-V
HRFy1aL.jpg Promo code DATSUN10 to save 10% at DapperLighting.com
#24 johnc
johnc
    Administrator
  • Administrators
  • 9739 posts
  • LocationLa Habra, CA, USA
Posted 29 August 2012 - 07:54 AM
I've changed my mind! The best oil is anything from Motul! 'Course, it looks like I'm going to be a Motul dealer, but that had nothing to do with me changing my mind... :-)
----- John Coffey, Fabricator at Benton Performance, LLC
#25 Leon
Leon
    Tremendous grasp of the obvious.
  • Donating Members
  • PipPipPipPipPipPipPip
  • 2303 posts
  • LocationSan Bruno, CA
Posted 29 August 2012 - 01:06 PM
:lmao:
#26 Gollum
Gollum
    Tree Killer
  • Members
  • 2922 posts
  • LocationVacaville, CA
Posted 29 August 2012 - 01:15 PM
I'm converted! I've been changed, born again even! John, when can I order some Motul oil from you? Posted Image
'75 280Z, L28ET, Street going rat rod
http://forums.hybrid...ms-dd-l28et-75/
#27 z-ya
z-ya
    Member
  • Members
  • 2982 posts
  • LocationBuzzards Bay
Posted 30 August 2012 - 09:41 AM
For a street L6 I would run the Valvoline VR-1, as it has High zinc/phosphorus content, and is reasonably inexpensive. Pick the weight according to the climate you live in.
For my vintage racer I use the Brad Penn 20W50. Sticky, gooey, good stuff. If you buy by the case, not too expensive. The Joe Gibbs is probably just as good, but I think Joe is getting a big chunk of the purchase price as his name is on it.
"I finally found my old blue jeans. I could tell that they was mine from the oil and the gasoline."
- ZZ Top
#28 ozconnection
ozconnection
    HybridZ Supporter
  • Donating Members
  • PipPipPipPipPip
  • 625 posts
  • LocationSydney, Australia
Posted 02 September 2012 - 02:13 AM
I now use Prad Penn 20w-50 too. I was sold on the higher zinc content, something that's important so I've been told. A close mate of mine who runs an 800hp small block in his race car swears by it too. Good enough for me. :)
'78 280C sedan P30 Y70 L4N71B 4.11 H190 131 rwhp. NA
'71 240C coupe N42 E88 FS5W71B 4.625 H190LSD Megasquirt V3.57 NA 225 rwhp
'Nissantiques - join the club'
#29 tyler031734
tyler031734
    Member
  • Donating Members
  • PipPipPipPip
  • 144 posts
  • LocationPortland, Or
Posted 09 September 2012 - 06:16 PM
Why so thick BluDestiny? What is your pressure like? Cold/Hot.
EDIT: now I read the rest of the thread and see a lot of people are running 20w/50w?
Isn't that a bit hard to push through the oil galleys? The thinner it is the more oil you get over your parts, returning to the pan faster and remaining cooler due to a few factors. my 0.02
Edited by tyler031734, 09 September 2012 - 06:24 PM.
73 240z, hopefully new home of a vh45de.
#30 z-ya
z-ya
    Member
  • Members
  • 2982 posts
Posted 09 September 2012 - 07:58 PM
It really depends on your application and the ambient temperature you run at. If you run at all in cool weather, no need for 20W50.
- ZZ Top
#31 Oblithian
Oblithian
    Newbie
  • Members
  • Pip
  • 16 posts
  • LocationCanada
Posted 28 November 2016 - 10:12 PM
So I've been running 10W-30 for about a year and a half with no issues. However, in Australia they mainly run 60 weight oil, and the late-80s L28 Patrols run 10w-40. Is the low viscosity going to increase wear?
Also, would it be worthwhile moving to 5W-30 in the winter (if it is often -20 Celsius or colder)? Not that 10W would even matter if you can run 20w-60 at -3 degrees....
Edited by Oblithian, 14 December 2016 - 04:41 PM.
#32 S30Stig
S30Stig
    Newbie
  • Members
  • Pip
  • 8 posts
  • LocationNew Jersey
Posted 08 December 2016 - 03:17 PM
Because there aren't enough options for you to choose from already, I run Joe Gibbs Driven conventional 10w-40 break-in or hot rod oil on recommendation from my engine builder. I have a Datsun Spirit 2.7L 'stage 1' motor and the car seems very happy with that syrup. It is $10-11 a quart off amazon and supposedly the 'hot rod' oil is the 'brake-in' oil with a different label for the same price.
#33 rundwark
rundwark
    Regular
  • Donating Members
  • PipPipPip
  • 56 posts
  • LocationMenlo Park, CA
Posted 17 January 2017 - 11:11 PM
Maxima Racing Oils makes a nice conventional oil that has higher zinc content than Valvoline VR1 and costs less. I'm running their 10W40 in my L-series: http://www.maximausa...ct/performance/
#34 HowlerMonkey
HowlerMonkey
    Member
  • Members
  • 1381 posts
  • LocationWest Palm Beach
Posted 08 April 2017 - 08:24 AM
Been swapping from rotella 15w40 and castrol standard 20w50.
Staying now with 20w50 since all my stuff is now super high mileage.
At another forum is a good text only post of test results.
This same testing lies elsewhere and has pretty pictures but it loaded with advertisements in between.
http://www.speedtalk...php?f=1&t=31363
#35 jacky4566
jacky4566
    Always Here
  • Members
  • PipPipPipPip
  • 107 posts
  • LocationCalgary, AB
Posted 3 weeks ago
Using Rotella T6 5-40. Good stuff but the detergents are so strong i actually developed new leaks in the old engine.
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
