1969 Datsun 510 2Dr Z22 turbo EFI build
  • Please log in to reply
29 replies to this topic
#21 FricFrac
FricFrac
    Member
  • Members
  • PipPipPipPipPip
  • 712 posts
  • LocationVictoria, BC
Posted 12 December 2012 - 09:41 PM
Yes I've done all the head and manifold work myself.  I've been reading on HybridZ here for three years before I dove into my first engine build.  I like learning how stuff works then adapting that knowledge to my own applications.  I can't find anyone that's Mega Squirted and turboed a Z22 yet (although I'm sure they are out there).  Most guys turf the NAPS Z head but I think it will work well for a boosted application.  We'll see :)  I can only be better than a stock L16.... I hope....
1969 Datsun 510 2dr Z22ET, 1972 Datsun 510 2dr L28, 1972 Datsun 240Z, 1981 Datsun 280ZX, 1981 Datsun 280ZXT 3.1l stroker, 1983 Datsun 280ZX, 1983 Datsun 280ZXT, 1993 300ZX Convertible, 2009 Nissan 370Z
#22 FricFrac
FricFrac
    Member
  • Members
  • PipPipPipPipPip
  • 712 posts
Posted 12 December 2012 - 09:42 PM
Pretty much done with the head now.  Lapped the valves in and hot tanked the head.  There's one seat that has a nick in it we'll try to polish out then a quick clean and install the valves and cam.  Had the old piston wrist pins pressed out and the new pistons and wrist pins installed.  Sent that to the machinist which is the only machine work so far for a total of $62.  Pistons are installed and started painting the block.  One coat of primer over the old paint and a coat of semi gloss black engine enamel.
#23 FricFrac
FricFrac
    Member
  • Members
  • PipPipPipPipPip
  • 712 posts
Posted 21 December 2012 - 02:12 PM
Fixed the last valve seat with the nick in it.  All the valve springs and valves are re-installed.  Spark plugs gaped and semi-indexed (picked the best of for the eight).  Painted the head with high temp exhaust manifold paint to match the block.  Ready for cam reinstall.  The hot cam for the L28ET is the L28E NA cam.  Hopefully the Z22 NA cam works well for a turbo application.  Still undecided as to what turbo to run on this build.  Probably will start with a T3 from an L28ET.  I think a GT28 or GT30 would likely be a good final build turbo for this application.  Big returns from a methanol injecton for the L series head and a boosted application - not so sure the hemi style head here will need the methanol as badly.  Something to ponder for the future....
#24 FricFrac
FricFrac
    Member
  • Members
  • PipPipPipPipPip
  • 712 posts
Posted 23 December 2012 - 01:47 PM
Cleaning out the garage (SLOOOOOWLY...) and found a scrap Z22 head - side by side of the exhaust ports:
Edited by FricFrac, 23 December 2012 - 02:14 PM.
#25 FricFrac
FricFrac
    Member
  • Members
  • PipPipPipPipPip
  • 712 posts
Posted 10 January 2013 - 09:47 AM
So apparently when I was told to use the L20b ARP set on the Z22 the person was assuming I was building a LZ. The L20B studs are WAY too long for the Z22 with the stock head and they don't make a Z22 kit (or any NAPS Z kits for that matter). I think I've found a stud that will work. ARP sells these as a individual stud - M10 x1.25 x 1.50 x 109mm PN: AM 4.300-2LB so 10 of these, 10 washers and nuts should make a Z22 ARP head bolt kit :) Just talking with ARP to find out if they'll make a kit of these to buy direct from them or through their suppliers so I can get this thing together!
#26 FricFrac
FricFrac
    Member
  • Members
  • PipPipPipPipPip
  • 712 posts
Posted 16 January 2013 - 11:16 PM
Picking away at the endless "little things" while I try to get the head studs squared away. Did some more porting and polishing on the exhaust manifold. I already matched the ports but I wanted to transistion and take some of the roughness of the casting out and round off any sharp edges going into the turbo flange. Cleaned it up and painted it satin black with some header paint to match the head.
#27 FricFrac
FricFrac
    Member
  • Members
  • PipPipPipPipPip
  • 712 posts
Posted 31 January 2013 - 07:53 PM
OK I've finally sourced the head bolts.  My local parts place wanted 4x as much for the nuts, etc with a four to six week lead time.  Ordered them from Regal at Northern Auto Parts for a fraction of what the local shop wanted and 7-10 days to get them in.
Working on the turbo manifold a bit.  Got a heavy blanking plate cut and had made a copper gasket and had it annealed to make it soft.  I'll use these to block off the wategate flange on the turbo as I'll be using a stock T3 from a 280ZX with an internal wastegate.
Got an old 280ZX turbo cast downpipe and hacked off the flange.  Port matched it to the T3 outlet then tapered out for a mandrel bent 2 1/2" down pipe which I'll likely flare to 3".  The turbo flange is a little rounded so it looks like there is a lip but it matches up perfectly.
Edited by FricFrac, 31 January 2013 - 07:56 PM.
#28 FricFrac
FricFrac
    Member
  • Members
  • PipPipPipPipPip
  • 712 posts
Posted 13 February 2013 - 11:02 PM
Fuel rail almost done :)
#29 LanceVance
LanceVance
    There are some who call me... Tim?
  • Members
  • PipPipPipPipPip
  • 635 posts
  • LocationEl Paso, Texas
Posted 14 February 2013 - 04:51 AM
Looking good, I especially like the fuel rail brackets.
2011 Subaru Impreza STI Limited Sedan - Daily Driver
1973 Datsun 240z - Running tripples, getting the L28ET!
1975 Datsun 620 Pickup - Future SR20/Ratrod project
#30 FricFrac
FricFrac
    Member
  • Members
  • PipPipPipPipPip
  • 712 posts
Posted 16 February 2013 - 01:18 PM
Looks better polished and anodized red :)  Under the sodium vapour lamps makes the colours look funny but you get the idea.
My blue toolbox is in the background - you can see how the light from the blue reflects off the polished anozided part making it look purple (red + blue)
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
