HendoZ, 1uzfe/6mt 240z
  • Please log in to reply
49 replies to this topic
#21 docaam
docaam
    Always Here
  • Members
  • PipPipPipPip
  • 280 posts
  • LocationDubai
Posted 07 February 2013 - 10:13 AM
Subscribing
#22 HendoZ
HendoZ
    Moving Up
  • Members
  • PipPip
  • 35 posts
  • Locationhenderson, Ky
Posted 25 March 2013 - 03:54 PM
484348_10151555206115350_1048385859_n_zp
$200 off ebay. mckinney motor sports I believe.
#23 HendoZ
HendoZ
    Moving Up
  • Members
  • PipPip
  • 35 posts
Posted 07 May 2013 - 04:21 PM
Not a problem, on my Z when I did my RB20 swap, I pulled switch power from the ignition switch.  However, since you are combining three of them you may want to run an external relay.
I would run the relay out to engine bay, and tap a wire from the ignition switch to the relay.
So relay wiring would be:
85 -> ground
86 -> Ignition switch
87-> Battery
30-> Three wires from EB2 and IJ1
The start harness will be coming from the factory lower harness.  Keep in mind the factory lower harness has the oil pressure, starter signal and something else important in there (I think the water temp?).  So you'll swap over your oil pressure sensor to the UZ's location.  And the starter signal will go to Black wire on EB2.  This of course is from my 280Z, I don't know how it be different it will be on your chassis.
Also, on my car the fuel pump wiring was under the passenger seat.  You'll have to find the fuel pump wiring and wire up a relay there too.  If I remember correctly the ECU should output a GROUND signal.  So you're relay will be pinned out the same with the exception of 85 and 86.  85 will be switch 12v or constant 12v and 86 will be from the ECU, and 30 will go to fuel pump power.
That's how I would do anyway, in theory this should fire up.  However I have to put a disclaimer that you'll want to verify my work, and if your car or yourself has damages then it's all on you.
-Steve
Okay, I looked at a few things I have from when I did the swap.
http://imageshack.us...esuprawirin.png
First save this image, you'll need the plugs EB1, EB2, and and IJ2.
To get the car to run:
You need switched power to EB2. This is a black and orange wire.
You need switched power to EB2. This is a black and red wire
You need switched power to IJ2. This is a black and orange wire.
You need constant power to EB1. This is a black and yellow wire
To start you need to supply "start" power to EB2(1) which is a black wire.
This information is both from SuperRunner (whom I got the flywheel for) and Chambers from supramania.
This will get the car to run, you'll have to figure out the fuel pump wiring though.
On the SC400 it uses a fuel pump ecu to power the fuel pump.  So pretty much use the ECU output to a relay, and fuel pump power.  That should be to get the car up and running.
I know there hasn't been  any updates lately. Sorry.  Any way I'm tackling wiring this week. plannin to have a start up by the weekend! OH and Many thanks to Ihiryu!
Edited by HendoZ, 07 May 2013 - 04:22 PM.
#24 Homeboyx
Homeboyx
    Newbie
  • Members
  • Pip
  • 11 posts
  • LocationLos Angeles, CA
Posted 07 May 2013 - 04:36 PM
Wow! Awesome build! Subbed.
#25 HendoZ
HendoZ
    Moving Up
  • Members
  • PipPip
  • 35 posts
Posted 07 May 2013 - 06:31 PM
Thanks man. Its taken quite a bit to get to this point. but its all been worth it!
#26 Homeboyx
Homeboyx
    Newbie
  • Members
  • Pip
  • 11 posts
Posted 07 May 2013 - 08:22 PM
I still can't believe the mk3 mounts work by simply turning them over. Haha!
#27 ihiryu
ihiryu
    Always Here
  • Donating Members
  • PipPipPipPip
  • 327 posts
  • LocationKilleen, TX
Posted 09 May 2013 - 11:33 AM
I'm excited for you!  I've been thinking about ditching my RB20 for another 1uz in the stable
Contact me for cheap prices on speedhut gauges, many, many, other things
http://tinyurl.com/SpeedHut-Group-Buy
If we've done business and you were satisfied, a simple "Like" on our facebook page would be all the "thanks" I'd need!
https://www.facebook.com/KRMotorsports
#28 HendoZ
HendoZ
    Moving Up
  • Members
  • PipPip
  • 35 posts
Posted 24 May 2013 - 11:34 PM
And she runs. trying to figure out how to upload video now.
#29 HendoZ
HendoZ
    Moving Up
  • Members
  • PipPip
  • 35 posts
Posted 27 May 2013 - 08:29 AM
A few quick revs to 3k then shut her off. shes open header right now.
<iframe src="https://www.facebook...657306727616923" width="1280" height="720" frameborder="0"></iframe>
Edited by HendoZ, 27 May 2013 - 08:31 AM.
#30 78zstyle
78zstyle
    Can Charge Rent
  • Members
  • PipPipPipPipPip
  • 542 posts
  • LocationDenton, Texas
Posted 27 May 2013 - 01:55 PM
Sounds great.
#31 HendoZ
HendoZ
    Moving Up
  • Members
  • PipPip
  • 35 posts
Posted 04 June 2013 - 09:18 PM
Sounds great.
Thanks man.
Just got GC sleeve overs and AW11 rear struts for the front of the car. Hope to get pretty low with this set up.
#32 ihiryu
ihiryu
    Always Here
  • Donating Members
  • PipPipPipPip
  • 327 posts
Posted 04 June 2013 - 11:32 PM
Sweet, how was the wiring portion of it?  Hopefully I didn't give you any wrong info.
#33 HendoZ
HendoZ
    Moving Up
  • Members
  • PipPip
  • 35 posts
Posted 08 June 2013 - 07:03 PM
Pretty simple actually. Info was spot on. I did a lot of research on it all too. also had a factory 94 sc400 wiring manual to fall back on.
#34 HendoZ
HendoZ
    Moving Up
  • Members
  • PipPip
  • 35 posts
Posted 16 June 2013 - 07:10 PM
B4A97E11-00F3-47DB-947E-F5BDA17237A9-137
A6FA280E-0D26-4896-A9AC-B0B044B81E25-137AA1F0B43-A6E8-422D-8AC9-29CEBEE57E94-137
Front suspension set up. AW11 Rear strut cartridges. and GC sleeve overs. with strut sectioning. not a job for the faint at heart.
#35 HendoZ
HendoZ
    Moving Up
  • Members
  • PipPip
  • 35 posts
Posted 19 June 2013 - 07:59 PM
So the CSC that came with the 350z 6 speed couldn't handle the ACT stage 3 pressure plate... this means i had to pull the motor and trans AGAIN.
Well any way I fixed the problem and put it all back together and got the car back on the ground.
553AEDF1-D4BE-4250-A624-A3BEC0D3AB0C-437
1922AFEA-6494-4CC2-A284-4E9D5B789361-437
3AD04325-F215-4B89-B530-D165B497C803-137
0921ED6F-D28E-4B86-A7F3-A9091C230F84-437
9F8A46B8-8B21-4CF7-99DC-F6A65B3314A3-437
4BAF3DC8-7C8E-4134-BD18-88BF63860E2C-437
5DF06264-B9EF-4D68-B1BA-89194A8B7F30-437
E50EBD7F-157A-4FAC-BE27-A3D00552DBC1-437
More to come!
#36 ihiryu
ihiryu
    Always Here
  • Donating Members
  • PipPipPipPip
  • 327 posts
Posted 26 June 2013 - 06:35 PM
So you used MKIII 1uz swap mounts.  So does that mean you no longer have a rubber isolator?
Next how did you do the transmission mounts?
#37 HendoZ
HendoZ
    Moving Up
  • Members
  • PipPip
  • 35 posts
Posted 26 June 2013 - 06:59 PM
Correct. the swap mounts do have a bit of very rigid plastic between the mount and cross-member isolaters. and i fabricated a trans mount. ill have to take pictures of the trans mount.
#38 HendoZ
HendoZ
    Moving Up
  • Members
  • PipPip
  • 35 posts
Posted 27 June 2013 - 07:51 PM
"https://www.facebook...151723617170350
Edited by HendoZ, 04 July 2013 - 08:37 AM.
#39 78zstyle
78zstyle
    Can Charge Rent
  • Members
  • PipPipPipPipPip
  • 542 posts
Posted 28 June 2013 - 09:32 AM
Cant see the video T.T
#40 HendoZ
HendoZ
    Moving Up
  • Members
  • PipPip
  • 35 posts
Posted 30 June 2013 - 07:39 AM
Ran the car down the street last night. the video quality from my friend's phone was junk. hope to post some videos of it here soon,
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
