Autocross and oil pressure... impending doom??
The flaking paint, like leaves in a pool collects on the strainer screen, reducing flow and therefore pressure. Since it obstructs the screen, it doesn't fall off until you shut the car off and stop the pump. It then falls to the bottom of the pan where idle pump suction does not disturb it.
When you rev it, and slosh the oil around, it gets floaty again, and sucks to the screen. Causing the problem again.
Clean the pan, and try it again.
The Schmutz should not be an issue downstream...it would be macerated in the pump...
That's my theory...I'm stickin to it!
  • Replies 61
  • Created
  • Last Reply
Top Posters In This Topic
