So I'm beginning to fix some things on my series1 240Z #5837. One of the most obvious issues is the horn button. The black plastic behind it was 40 years old and cracked and crumbling to the point that no amount of glue or Zipties was going to hold that button on. So talking with a buddy of mine, he suggested maybe I could print up a fix. He gave me another busted up button to tear apart, so I did and created a new insert to replace the busted up 40 year old crappy plastic. I printed this out of ABS and worked it into my old button after removing the old plastic. I made it about 3mm wider OD to ensure a snug fit. It can be glued in place with rubber cement, but I'm not certain that's necessary, as it's fairly tight. It fits well on 240Z's and I can print it in about any color (not that you'd see it). Here it's printed in white so you can see the detail. It snaps on just the same as the original did, but ABS is a little more forgiving. If there's a market, I was thinking of selling the printed inserts for $20 ea.
post-4150-0-04803500-1372113616_thumb.jpg   post-4150-0-99110200-1372113595_thumb.jpg
It's very interesting to think of recreating various classic S30 parts that are difficult to come by, especially NOS. Let me know if there's any other parts you might like to see recreated.
Phar
Share this post
Link to post
Thanks,  Send me a PM, this isn't the right location for selling stuff.  Much more I want to know what other parts people are looking for so that we may be able to start a 3D printable data base of parts that are no longer available (NLA) or way too expensive for average joes in NOS.   I was looking at printing the Series 1 hatch Drain covers/internal drains that mount inside the hatch.   Now I want to be clear that though reproductions are good, they are not the same as original OEM, but certainly they're much less expensive.  If you have a 3D printer, I could share my Models so you could print your own.
Share this post
Link to post
What are the limits regarding heat and chemical resistance of the plastics available for this? I've had a project in mind that this would be great for, but it would be under hood (and close to the exhaust manifold) so perhaps not?
Edit: It would also be in direct contact with oil...
Edited by LanceVance
Share this post
Link to post
Hmm Well I've been printing in ABS, so pretty much whatever ABS can stand up to. Not a lot of heat, I think exhaust would be a bit hot for it. Oil, probably in limited exposure, since acetone quickly melts ABS it may not be the best solution.  A lot of people are beginning to print in Nylon which is much better for temperature, oil and flexibility.  Some of the bigger 3D print houses are using it.  Nylon is also more flexible, but it's also a bit more expensive.    Another possibility is having a part printed then cast in whatever metal you'd like. that's been done successfully, but it's much more than I am capable of in my hobby production.  Lastly metal parts can be laser Sintered 3D printed, but that's not cheap either, but that's direct printed in metal.
I'm using a Prusa Mendel, 3D printer. It's hobby level, but still very good.  I'm certain it's good enough for reproducing most S30 parts within a reasonable size. (200mm*200mm*100mm tall)
Share this post
Link to post
Socorob also mentioned the Plastic piece under the horn was broken on his friend's car, I'm not sure how often that part breaks too, but if anyone is interested, I could work up a model for it as well.
I was also thinking about the Combination switch, I seem to remember a part in that that breaks easilly, does anyone remember which part that is? We may be able to redesign one a little stronger.
Share this post
Link to post
The carrier the two buttons ride in is made of the same plastic, but does
not suffer as much as it is not in direct contact with the copper bus plates
that complete the electrical connection.  I suppose they could get brittle with
age, but the buttons and springs are impossible to find, printing buttons
would solve half the problem.
I've had two of the buttons melt, with no obvious damage to the rest of the switch.
The first time I was able to find a damaged switch to scavenge the buttons and
springs.  The second time I ended up carving up a drip line sprinkler nozzle until
it fit the pocket and had the correct height and profile to let the switch work.
Share this post
Link to post
hmm well if it's melting then something is geting hot.  ABS can't handle too much heat. (your sprinkler parts are probably ABS) but if we can see why it's heating up it shouldn't be a big deal to print more pads.  The glass bed on the printer is actually really good for making a surface on each part really smooth.   I need to go to the local Z junkyard n see if they've got any busted ones to take apart.
Share this post
Link to post
Nice, I didn't think of that one, that's a great idea. I'll add that to my list of things to model. Modelling the door and printing in black should work well.  My series 1 console is pretty cracked. Too bad I don't have the ability to print things like an entire console. That would be nice.  I'll look for a Series1 Door, as I need one too.
Share this post
Link to post
The switch internals get worn and loose contacts conduct poorly,
heating up.  A headlight relay harness eliminates the melting, but
the buttons are still brittle and the springs have sagged a bit.
The sprinkler bit worked better than expected as I ended up with
it being a bit tall, which tightened up the stalk and applied more
pressure to the contacts.  The second item was obvious due to the
much brighter headlights.
A relay harness and slightly taller buttons would be a killer combo
(pardon the pun)
Share this post
Link to post
Thanks. Received the part yesterday and it looks good and fits in the horn pad nice and tight. While steering wheel is apart I'm refinishing the pwood so I won't be able to test the function for a little while longer.
Share this post
Link to post
I need to replace the small white plastic mount that holds the horn contact brush to the combination switch. Mine is cracked at the screw hole and loses contact. It is not a part that appears to be readily available without buying a combination switch, but should be simple to fabricate as its pretty simple.
Share this post
Link to post
Well I recieved your Picture, and this is what I came up with.  I'll probably have to get the original, (or at least the pieces) to get the scale/ dimensions more correct.  Let me know if you think we should look further into this.  A part this size should only take about 20 min to print, but I already spent an hour on this model.
Phar
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
