My custom made headers and exhaust system
Headers x-pipe V-Band Borla
  • Please log in to reply
25 replies to this topic
#21 Alliedperformance
Alliedperformance
    Newbie
  • Members
  • Pip
  • 2 posts
  • LocationColorado Springs, CO
Posted 07 December 2013 - 10:30 AM
Very nice work sir! How much time do you have in them?
#22 74_5.0L_Z
74_5.0L_Z
    HybridZ Supporter
  • Donating Members
  • PipPipPipPipPip
  • 938 posts
  • LocationRockledge, FL
Posted 10 December 2013 - 03:45 PM
I have way too much time in the headers.  There are a few reason that it took so long.  First, this was the first time I have made a set of headers.
Second, stainless steel is expensive, and I wanted to get every cut perfect the first time.  Lastly and most importantly, I was trying to finish my Masters Degree in Mechanical Engineering.  So, time to work on the car was in short supply.
The program that I wrote to calculate the bends actually began as a project for my Robotics class.  I convinced the professor that the procedure to calculate the bends for a header was the same as that required to solve the kinematics of a robot arm with seven degrees of freedom (which it is).  So, I spent a semester doing the math and writing the code to figure the header tube paths.
I finished that class in 2011,  but had several classes to finish for my degree so the headers went on hold while I collected parts and finished school.  I finished my degree in April 2013 and finished the headers in August.
#23 BLOZ UP
BLOZ UP
    Member
  • Members
  • PipPipPipPipPipPip
  • 1367 posts
  • LocationCentral Jersey
Posted 11 December 2013 - 07:55 AM
Hrm, I did a split grad/undergrad intro to robotics class for my CS bachelors... I distinctly remember the math for more than 3 degrees of freedom getting an order of magnitude more difficult with each additional degree of freedom added.
It was a fun class, but I'll stick to CS for a masters.
BLOZ UP.com
It is not recommended to confirm proper installation by driving into walls or other barriers as this could cause personal injury or damage to the vehicle.
#24 whatnow123
whatnow123
    Always Here
  • Members
  • PipPipPipPip
  • 120 posts
  • LocationArizona
Posted 22 January 2014 - 06:10 AM
Wow, your headers look awesome!
did you also build from the collectors back? That is pretty sweet as well. I'm doing the same 5.0 swap with a T5 and would love to run the same setup but with block huggers as I don't have your skill to build the headers.
5.0 V8 5 speed! Yeah Baby!
#25 madkaw
madkaw
    HybridZ Supporter
  • Members
  • 1786 posts
  • LocationBloomington, Indiana
Posted 22 January 2014 - 07:07 AM
Excellent work!!
Steve,
9/71 240z. 2.4 -.40 over, balanced. E-88 Bigger SS valves, stage 2, 6x2 header, true dual exhaust. BW t-5 , STI LSD 3.90- triple Mikunis 40mm
#26 kyle319
kyle319
    Moving Up
  • Donating Members
  • PipPip
  • 25 posts
  • Locationiowa
Posted 16 February 2015 - 10:11 AM
Those are absolutely amazing! And you got some seriously impressive gains from just long tubes and a tune. If you ever feel up to another design you should help out us 2jz guys! There would definitely be a market for a nice tubular header or at least designs for one. What kind of welder do you have? I'm looking to buy one soon for body work and was contemplating building exhaust but was kind of put off by the difficulty of a header but I'll most likely approach the header as a long term project like you have. Regardless, impressive work!
Also tagged with one or more of these keywords: Headers, x-pipe, V-Band, Borla
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
