PICS of Rear Hatch Rust Patching
It all began with a cleaning... then as I started to grind away the small rust spot on the tailgate, the hole kept getting bigger.
the plastic cover was hiding a huge hole.
Here is how I fixed the rust holes, and rear hatch:
I cut out the areas that had rust with an angle grinder
I cut out matching pieces of 16 GA steel and bend to match existing
I painted all the parts and all around the hatch with POR-15, doing the whole cleaning and etching process
and installed NOS inner weatherstripping and the top portion of outer weatherstripping
Re-installed rear tail pieces, and lights
Then I turned my attention to the hatch hinges, which were ripping off at the seams.
I welded them on the top
And underneath
And that was about a weekend of work, for an amateur.
