Aftermarket fuel filler cap
240zdan
So a few years ago when I built my Z I decided to install a "fuel cell". Well filling up the gas through the interior is getting old, and I could never get my fuel level sender to work properly in the "baffled" foam cell. Its time for the fuel cell to eventually go. The issue is, while repainting the car, I decided it would be wise to shave the OEM gas door.
I am pretty much set on putting an LS1 plastic tank in the car, unless I find another suitable alternative. Since this part of the forum pertains to bodywork, lets talk about fuel filler caps/neck. What after market fuel filler caps have you seen that caught your interest? The Z has a slight curve where the cap would sit, so I think a recessed mounting would be a must. So far I have been eyeing the Sparco setup along with an ebay one. My car is white, and I don't want the fuel filler to stand out. I have thought about anodizing the pieces black. Other than finding a OEM door and welding her back in, what would you guys consider if you were to rework the fuel fill cap?
$T2eC16N,!zcE9s4g0-S!BQtcb,59bw~~60_1.JP
I bought a motorcycle fuel tank (GSXR I think) with the door and key for around $80. The tank was dented, but the area around the filler cap provided more than enough straight metal for grafting. It's still sitting in storage awaiting the bodywork stage of the build, so I don't have any pictures, but it's something for you to consider.
Socorob,
I'm really digging the aircraft fillers on the last page, did you ever price any of them?
Edited by LanceVance
I'm planning on going with large flares in the rear. I will relocate the stock fuel door to the flare, and then use a 280Z fuel filler because it is all metal, and aftermarket fuel filler hose can be easily attached to it. I'm going more a stock look.
$%28KGrHqF,%21i8E5dwB85Y4BOd-qZNg-w~~60_
  • 11 months later...
  • 4 weeks later...
